Again the same question whitout any answered in the pass:
I have a
49LF590V
There's someone beta firmare or similar to can be resolve the so many devices created on windows 10 every time i turn on my tv ?
  • 4 weeks later...
Hello all,
have anyone already installed webos 2.0 version 4.05.45? Any information what was changed or some improvements?
LG50LF652V
hi all,
I've 3D TV LG42LB650T.
just got update this morning after quite so long..
Software version: 05.05.25
webOS TV version: 1.4.0-2523
but I don't know what has been changed, do not know where to find the changelog :(
Hello Dejan. Can post working hyperlink to 5.05.35 update please!!
Hi, just go to official web page of your specific model and download firmware file..
I have 42LB700V and all LB630-LB870 and EC930 models uses same firmware.
For these models (LB630-LB870 and EC930) latest official usb version 05.05.35:
Hi guys , my tv briefly showed an update was available but when i went into the settings later to check it said no update found , I was wondering if they pulled the update  , so mine is still on 5.00.55  65LB7500  NZ
Guys, skip the OTA update process (doesn´t work anyway), donwload ZIP from official server, unzip in folder LG_DTV on USB stick and do the update via USB. Safe and quick!
Btw, updated to 05.05.35 without problems. No changes visible or noticable.
K.
Updated via USB to ver.05.05.35 (55EC930V). I noticed several small (insignificant) changes ...
But there is one bigger: ON TV AND ALL INPUTS COLORS SHIFTED TO RED (skin colors are unnatural orange!) on my calibrated OLED TV!!!
Still cannot start some instaled application (LG Store, YouTube, AccuWeather ... - issues that started with 05.05.01 update)!
After instaled 05.05.20 web app is slower then before (same with 05.05.35). Slow, slow, slow .. fuckin' sloooow!!! And web app restart from time-to-time (memory full).
Still cannot start all instaled application (LG Store, YouTube, AccuWeather ... - issues that started with 05.05.01 update)!
Funny you mentioned that , I recall after a firmware update , cant remember what version my TV developed a red tint to everybody's faces , it took a lot of messing around to correct it . Factory reset did not help .
LGSAM, on 20 Dec 2016 - 02:35 AM, said:LGSAM, on 20 Dec 2016 - 02:35 AM, said:LGSAM, on 20 Dec 2016 - 02:35 AM, said:LGSAM, on 20 Dec 2016 - 02:35 AM, said:LGSAM, on 20 Dec 2016 - 02:35 AM, said:LGSAM, on 20 Dec 2016 - 02:35 AM, said:
... and that's visible on all color/picture modes, no mather is it cinema, standard, eco, vivid ... or calibrated isf1 & isf2 mode.
I'm very disappointed with this "update". Ooh, if I could only go back to 05.00.55 (05.05.01 slightly improved picture quality, but some apps stopped working)
Well got a suprise this morning. My 42LB731 auto updated to the new 05.05.35 software. Forgot that I'd ticked the check box for auto update. Working as normal at the moment, no noticeable difference. No full reset as can not be bothered setting up again, probably will do one when I get the urge. Good on LG they're still looking after us 1st gen WebOs owners even though we don't see any significant changes.
Anyone in NZ using the latest software 5.05.25 , im a bit concerned about updating as have had issues in the past that didn't seem to affect other country's .
Pessoal,
Eu sou do Brasil e a versão disponibilizada oficialmente é a 05.00.55. Eu fiz a cagada de atualizar para a 05.05.01 e esta versão é um lixo. Parou de funcionar o app que mais utilizo, o NetFlix. Queria fazer o downgrade para a versão 04.65.35, que dizer ser a melhor versão, mas não consigo. E pra piorar a situação, a LG não fornece uma atualização nova para o Brasil. Tipo, não tem uma versão 05.05.35 para o Brasil...
A LG está nos sacaneando...
Today my lg 55uc970v is update to 5.05.55? Web os 3?
Inviato dal mio SM-G935F utilizzando Tapatalk
Acredito que não seja WebOS 3, mas pra ficar claro, acesse o menu de atualização. Nesta tela além de dar a opção de atualizar o sistema, tem as informações de sistema.
Que? No pues esplicarte en engles?
I think it's not WebOS 3, but to be clear, go to the update menu. In this screen besides giving the option to update the system, it has the system information.
For example, my TV is a 42LB6500 and the firmware version is 05.05.01 and the WebOS version of this firmware is 1.42. In other words, it is not even WebOS 2.0
My 47LB6500 updated yesterday to 05.05.25 from 05.05.01
Enviado de meu SM-G935FD usando Tapatalk
For my surprise the LG launched a new update, the 05.05.25. How the 05.05.01 has too much bug, I'll not think twice and I'll upgrade right now.
Anyone having any negative experiences with this latest update . Someone mentioned color shift and apps not opening ,dont know if that is widespread or not .
