@Zibri
@Zibri On 7/7/2018 at 5:25 PM, Zybiax said:
Hello.
Thanks for sharing, however it says on my tv that It cannot be downgraded. Like It just won't apply yet I've followed every step and a factory reset won't do the trick either. I've done factory resets about 8 times now without any success or more. Also since my tv is a 2017 model, I highly doubt that it can be downgraded as I've read. It is probaly locked in the firmware, so hopefully somebody will find out a bypass for this anytime soon.
have the same problem...cant roll back 5.30.15 to 5.30.01 (it says on my tv that It cannot be downgraded) -on lh6047(2016)  .......plz help on PM
On 7/4/2018 at 5:45 AM, Zibri said:
Did you try 4.70.70?
  • link hidden, please login to view
P.S.
I see no difference between .45 and .55. So I think the slowdown is due to something else.
Probably is better if you reset to factory settings.
Updated with new version.
On 7/15/2018 at 4:04 PM, Zibri said:
I have sent it to Zybiax not to you.. but wait.. if you need I send it to you too.
Hi, could you also send me a PM how to downgrade my LG B7? Last year i changed my NSU Server to Engineer to receive beta updates, unfortunately, I´m now stuck on 4.80.45 which is actually older than 4.70.xx
Done :)
P.S.
Note:
Version 4.80.72 is a downgrade to a verision similar to 04.70.70 of May 2018.
post updated with 2 new firmwares. Anyway everything is slower and I suggest version 4.70.04 or 4.70.55...
P.S.
Note:
Note:
Version 4.80.95 and 4.70.95 are the same firmware.
I updated the post with the last 2 versions...
The real version of a firmware is the one after 573... 4.70.95 and 4.80.95 have both 57322.
  • Thanks 1
4.80.95 zip???
ASUS_T00J cihazımdan Tapatalk kullanılarak gönderildi
19 minutes ago, murattkn3 said:
4.80.95 zip???
why do you need it? the zip just contains the EPK...  so copy the EPK to pendrive and flash...
I did it but he does not see the TV
You have to rename the downloaded file to the full name in the URL (starfish.....)
59 minutes ago, murattkn3 said:
I did not do it
I know... do it and it will work. The name is from starfish...to .epk at the end of the URL...
On 8/14/2018 at 7:32 AM, Craig Lenti said:
Is it possible to reinstall the WEBOS?  Mine is no longer working at all.  Cannot connect.  Live in USA.
Yes, by resetting to factory defaults.
Don’t know if its aplicable but have you tried setting the time and date, mine randomly changes and refuses to load any internet based apps. Worth a try  before a reset if you haven’t already done so.
P.S.
Note:
Note:
Note:
 Seems a good firmware (as it was 04.70.45).
Updated.
  • 2 weeks later...
P.S.
Note:
Note:
Note:
Updated with latest K3LP platform firmware 5.90.01 (which also seems to be a good firmware.
  • 4 weeks later...
I have a OLED65C7P Canada and all firmware doesn't work for me only official webiste US or CA
 firmware is 4.71.00
 firmware is 4.71.00
As I wrote, these firmwares (which work perfectly) are for platform K3L(P)  so your tv has different ones.
K3LP platform usually is in UJ models (and some others)
Before saying "it doesn't work" recheck my post. You TV is not compatible with these firmwares I posted.
2. Applicable model list
43UJ651V-ZA
49UJ651V-ZA
55UJ651V-ZA
60UJ651V-ZA
65UJ651V-ZA
43UJ670V-ZD
49UJ670V-ZD
55UJ670V-ZD
65UJ670V-ZD
43UJ675V-ZC
49UJ675V-ZC
55UJ675V-ZC
65UJ675V-ZC
43UJ6517-ZA
49UJ6517-ZA
55UJ6517-ZA
60UJ6517-ZA
65UJ6517-ZA
43UJ6519-ZA
49UJ6519-ZA
55UJ6519-ZA
60UJ6519-ZA
65UJ6519-ZA
43UJ701V-ZC
49UJ701V-ZC
55UJ701V-ZC
65UJ701V-ZC
43UJ655V-ZC
49UJ655V-ZC
55UJ655V-ZC
65UJ655V-ZC
43UJ630V-ZA
49UJ630V-ZA
55UJ630V-ZA
60UJ630V-ZA
65UJ630V-ZA
43UJ634V-ZD
49UJ634V-ZD
55UJ634V-ZD
60UJ634V-ZD
65UJ634V-ZD
43UJ6307-ZA
49UJ6307-ZA
55UJ6307-ZA
60UJ6307-ZA
65UJ6307-ZA
43UJ6309-ZA
49UJ6309-ZA
55UJ6309-ZA
60UJ6309-ZA
65UJ6309-ZA
43UJ635V-ZF
49UJ635V-ZF
55UJ635V-ZF
43UJ631V-ZA
49UJ631V-ZA
43UJ639V-ZE
49UJ639V-ZE
43UJ620V-ZA
49UJ620V-ZA
55UJ620V-ZA
65UJ620V-ZA
70UJ675V-ZA
75UJ675V-ZA
75UJ651V-ZB
65UK6100PLB
65UK6100PLA
55UK6100PLA
55UK6100PLB
I wrote doesn't work for ME, not for every one :)
  • Confused 1
On 7/15/2018 at 3:46 PM, Zibri said:
officially it can't be downgraded.
Unofficially, I am the only one able to do it without hacking the TV and without setting up a fake server or anything
Believe it or not...
Could you send me a PM? Thank you
