Hi, I have anĀ 43LF590V (Italy).
A couple of apps I was using are now dismissed.
I red a lot of post saying "firmware update" in this thread.
Does LG WebOS updates fits also for my smart TV?
  • 4 months later...
  • 2 weeks later...
How can i downgrade from UJ6350 always i use Youtube, Amazon, Netflix or IPTV Smarters and always after a few minutes i need go to network settings to active again the wifi connection its very frustrating and LG never help in this i want downgrade to 04.70.85 this version its more stable thanĀ  06.00.04
  • 2 weeks later...
  • 1 month later...
  • 4 weeks later...
anyone having issues on synch DVB-T2 channels (no channel found on automatic scan, no signal at all on manual) on 2017 LED TV series? (eg: uj750v series). software is the last (6.00.25)
  • 4 weeks later...
anyone get the fw of a smart tv model 55uw660h i lost the wifi or ethernet settings, i use ethernet cable but no internet or factory reset its missing its a web os 3.0 any get the fw to flash in a usb ?Ā
I have this problem - when updating, the connection to the Internet on Wi-Fi is constantly "falling". This happens when downloading software. Has anyone had something like this? How did you decide?
Ā
Ā
You can try this Internet connection troubleshooting guide:
Are you all right with your router? Try downloading files from another device (phone or PC) for a long time.
Some of these solutions have been used. Others today. But unfortunately nothing has changed.
You can try to update via USB instead.
Here you can find how to update your TV manually using USB drive:
  • Thanks 1
The same problem is present. Wrote a letter to the support service provider. I am waiting for an answer.
What is the model of your router?
On 4/7/2022 at 9:33 AM, Foklen said:
TP-Link
In addition to what @WLSI said,Ā  you can try to change the WiFi encryption ( WPA/WPA2-Personal with AES encryption orĀ WPA/WPA3-Personal with Auto encryption are recommended).
Also make sure you aren't using Mixed Mode.
On 4/8/2022 at 9:47 AM, WLSI said:
Try changing the channel and mode of the router.
Ā
I can not enter the router settings. Once upon a time, I even went in through the phone. But that password is no longer the way I knew it.
11 minutes ago, Foklen said:
Ā
You can try to remember or "reset"
On 4/11/2022 at 8:30 AM, Foklen said:
Ā
Reset your router from the reset button to be able to log in with the default user/pass (press and hold the reset button for 10 seconds, then release it).
BUT
Only do this if you know how to reconfigure your router and know the ISP configuration or have a backup of it, or you can call your ISP support and ask them to help you.
  • 2 weeks later...
  • 3 months later...
  • 1 month later...
  • 1 month later...
As I posted earlyer in 2017, here's a list with ALL FIRMWARE OF LG TV UP TO DATE fromĀ
. You have to translate that. All LINKS is working if you are loged in.
  • For TV models 2014 year (webOS 1.0)
    • LB630-LB870, EC930:
      • FW for Northern Hemisphere -> from 05.2014, from 06.2014, from 06.2014, from 08.2014, from 09.2014, from 10.2014, from 12.2014, from 02.2015, from 02.2015, from 03.2015, from 03.2015, from 05.2015, from 05.2015, from 05.2015, from 05.2015, from 05.2015, from 05.2015, from 09.2015, from 09.2015, from 10.2015, from 10.2015, from 11.2015, from 12.2015, from 12.2015, from 05.2016, from 10.2016, from 10.2016, from 10.2017, from 04.2018, from 07.2018, from 07.2019, from 03.2022, from 04.2022
      • FW for Southern Hemisphere -> from 05.2014, from 05.2014, from 05.2014, from 06.2014, from 06.2014, from 08.2014, from 09.2014, from 10.2014, from 09.2014, from 10.2014, from 10.2014, from 11.2014, from 01.2015, from 02.2015, from 03.2015, from 03.2015, from 07.2015, from 07.2015, from 09.2015, from 09.2015, from 09.2015, from 10.2015, from 10.2015, from 10.2015, from 10.2015, from 10.2015, from 10.2015, from 11.2015, from 11.2015, from 11.2015, from 01.2016, from 01.2016, from 01.2016, from 04.2016, from 10.2016, from 07.2017, from 04.2018, from 04.2018, from 04.2018, from 07.2019, from 07.2019, from 07.2019, from 04.2022, from 04.2022, from 04.2022
    • UB850-UB980, UC970, EC970, EC980:
      • FW for Northern Hemisphere -> from 06.2014, from 08.2014, from 08.2014, from 09.2014, from 09.2014, from 08.2014, from 10.2014, from 10.2014, from 11.2014, from 12.2014, from 12.2014, from 02.2015, from 03.2015, from 03.2015, from 05.2015, from 05.2015, from 05.2015, from 05.2015, from 05.2015, from 05.2015, from 06.2015, from 07.2015, from 09.2015, from 09.2015, from 10.2015, from 10.2015, from 12.2015, from 01.2016, from 03.2016, from 05.2016, from 06.2016, from 10.2016, from 10.2016, from 10.2017, from 04.2018, from 07.2018, from 07.2019, from 03.2022, from 04.2022
      • FW for Southern Hemisphere -> from 07.2014, from 08.2014, from 09.2014, from 09.2014, from 10.2014, from 10.2014, from 10.2014, from 11.2014, from 01.2015, from 01.2015, from 02.2015, from 03.2015, from 03.2015, from 07.2015, from 07.2015, from 09.2015, from 09.2015, from 09.2015, from 10.2015, from 10.2015, from 10.2015, from 10.2015, from 10.2015, from 10.2015, from 12.2015, from 01.2016, from 04.2016, from 10.2016, from 07.2017, from 04.2018, from 04.2018, from 04.2018, from 07.2019, from 07.2019, from 07.2019, from 04.2022, from 04.2022, from 04.2022
  • For TV models 2015 year (webOS 2.0)
    • LF590-LF592, MT57S - 2015 year and LH480U, LH560, MT48S - 2016 year (webOS 2.0 Lite):
      • FW for Northern Hemisphere -> from 11.2015, from 11.2015, from 12.2015, from 02.2016, from 05.2016, from 09.2016, from 02.2017, from 02.2017, from 04.2017, from 10.2017, from 05.2018, from 07.2018, from 06.2019, from 05.2020, from 09.2020
      • FW for Southern Hemisphere -> from 07.2015, from 12.2015, from 12.2015, from 12.2015, from 02.2016, from 02.2016, from 02.2016, from 07.2017, from 03.2018, from 03.2018, from 05.2018, from 05.2018, from 05.2018, from 06.2019, from 06.2019, from 06.2019, from 05.2020, from 05.2020, from 05.2020
    • LF630-LF653, EG910 - 2015 year and EG9A7 - 2017 year (webOS 2.0):
      • FW for Northern Hemisphere -> from 04.2015, from 06.2015, from 06.2015, from 07.2015, from 08.2015, from 09.2015, from 09.2015, from 10.2015, from 12.2015, from 03.2016, from 05.2016, from 05.2016, from 09.2016, from 10.2016, from 10.2016, from 01.2017, from 04.2017, from 10.2017, from 04.2018, from 07.2018, from 09.2018, from 12.2018, from 05.2019, from 05.2020, from 09.2020, from 03.2022, from 03.2022, from 04.2022
      • FW for Southern Hemisphere -> from 03.2015, from 05.2015; from 06.2015, from 06.2015, from 07.2015, from 07.2015, from 07.2015, from 07.2015, from 08.2015, from 09.2015, from 09.2015, from 09.2015, from 09.2015, from 09.2015, from 09.2015, from 10.2015, from 04.2016, from 01.2017, from 07.2017, from 04.2018, from 04.2018, from 04.2018, from 05.2019, from 05.2019, from 05.2019, from 05.2020, from 05.2020, from 05.2020, from 04.2022, from 04.2022, from 04.2022
    • UF640 (webOS 2.0 Lite):
      • FW for Northern Hemisphere -> from 08.2015, from 05.2016, from 07.2016, from 09.2016, from 10.2016, from 10.2016, from 11.2016, from 11.2016, from 04.2017, from 10.2017, from 05.2018, from 07.2018, from 07.2018, from 06.2019, from 05.2020, from 09.2020
      • FW for Southern Hemisphere -> from 08.2015, from 08.2015, from 09.2015, from 12.2015, from 05.2016, from 05.2016, from 05.2016, from 06.2017, from 07.2017, from 05.2018, from 05.2018, from 05.2018, from 07.2018, from 07.2018, from 07.2018, from 05.2019, from 06.2019, from 06.2019, from 05.2020, from 05.2020, from 05.2020
    • UF630, UF680-UF685, UF770-UF778, UF830, UF840, EF950, EG920 - 2015 year and UH600 - 2016 year (webOS 2.0):
      • FW for Northern Hemisphere -> from 07.2015, from 08.2015, from 08.2015, from 11.2015, from 01.2016, from 05.2016, from 07.2016, from 09.2016, from 10.2016, from 04.2017, from 10.2017, from 05.2018, from 07.2018, from 12.2018, from 06.2019, from 05.2020, from 09.2020, from 03.2022, from 03.2022, from 04.2022
      • FW for Southern Hemisphere -> from 07.2015, from 07.2015, from 08.2015, from 08.2015, from 08.2015, from 08.2015 from 11.2015, from 11.2015, from 11.2015, from 11.2015, from 05.2016, from 05.2016, from 05.2016, from 06.2017, from 07.2017, from 04.2018, from 04.2018, from 04.2018, from 06.2019, from 06.2019, from 06.2019, from 05.2020, from 05.2020, from 05.2020, from 04.2022, from 04.2022, from 04.2022
    • UF690, UF850-UF940, UG870, EG960:
      • FW for Northern Hemisphere -> from 04.2015, from 04.2015, from 06.2015, from 06.2015, from 08.2015, from 11.2015, from 12.2015, from 03.2016, from 05.2016, from 09.2016, from 10.2016, from 04.2017, from 10.2017, from 05.2018, from 07.2018, from 12.2018, from 01.2019, from 02.2019, from 05.2019, from 06.2020, from 09.2020, from 03.2022, from 03.2022, from 04.2022
      • FW for Southern Hemisphere -> from 05.2015, from 06.2015, from 06.2015, from 06.2015, from 08.2015, from 08.2015, from 08.2015, from 11.2015, from 11.2015, from 11.2015, from 12.2015, from 12.2015, from 12.2015, from 12.2015, from 05.2016, from 05.2016, from 05.2016, from 07.2017, from 05.2018, from 05.2018, from 05.2018, from 05.2019, from 05.2019, from 06.2019, from 06.2020, from 06.2020, from 06.2020, from 04.2022, from 04.2022, from 04.2022
    • UF950, EF980:
      • FW for Northern Hemisphere -> from 04.2015, from 06.2015, from 06.2015, from 07.2015, from 09.2015, from 09.2015, from 10.2015, from 03.2016, from 05.2016, from 09.2016, from 09.2016, from 10.2016, from 10.2016, from 04.2017, from 10.2017, from 05.2018, from 07.2018, from 01.2019, from 06.2019, from 05.2020, from 09.2020, from 03.2022, from 03.2022, from 04.2022
      • FW for Southern Hemisphere -> from 06.2015, from 06.2015, from 06.2015, from 07.2015, from 07.2015, from 07.2015, from 10.2015, from 10.2015, from 10.2015, from 12.2015, from 12.2015, from 04.2016, from 09.2016, from 09.2016, from 09.2016, from 07.2017, from 05.2018, from 05.2018, from 05.2018, from 06.2019, from 06.2019, from 06.2019, from 05.2020, from 05.2020, from 05.2020, from 04.2022, from 04.2022, from 04.2022
  • For TV models ТВ 2016 year (webOS 3.0)
    • LH590-LH595, LH604-LH609, LH615, LH630:
      • FW for Northern Hemisphere -> from 07.2016, from 08.2016, from 10.2016, from 10.2016, from 02.2017, from 04.2017, from 04.2017, from 08.2017, from 08.2017, from 06.2018, from 07.2018, from 07.2018, from 01.2019, from 05.2019, from 01.2020, from 07.2020, from 01.2021, from 04.2021, from 04.2021, from 08.2021, from 10.2022
      • FW for Southern Hemisphere -> from 08.2016, from 08.2016, from 08.2016, from 08.2016, from 10.2016, from 06.2017, from 07.2017, from 08.2017, from 06.2018, from 06.2018, from 06.2018, from 05.2019, from 05.2019, from 05.2019, from 01.2020, from 01.2020, from 01.2020, from 08.2020, from 08.2020, from 08.2020, from 04.2021, from 04.2021, from 04.2021, from 04.2021, from 04.2021, from 04.2021, from 08.2021, from 08.2021, from 08.2021, from 10.2022, from 09.2022, from 09.2022
    • UH603-UH605, UH610-UH619, UH620:
      • FW for Northern Hemisphere -> from 06.2016, from 08.2016, from 10.2016, from 10.2016, from 10.2016, from 10.2016, from 11.2016, from 03.2017, from 04.2017, from 08.2017, from 08.2017, from 06.2018, from 07.2018, from 07.2018, from 01.2019, from 01.2019, from 04.2019, from 05.2019, from 01.2020, from 07.2020, from 09.2020, from 12.2020, from 12.2020, from 02.2021, from 08.2021, from 08.2022
      • FW for Southern Hemisphere -> from 08.2016, from 08.2016; from 08.2016, from 10.2016, from 10.2016, from 10.2016, from 05.2017, from 07.2017, from 07.2017, from 08.2017, from 09.2017, from 06.2018, from 06.2018, from 06.2018, from 01.2019, from 01.2019, from 01.2019, from 04.2019, from 04.2019, from 04.2019, from 01.2020, from 01.2020, from 01.2020, from 08.2020, from 08.2020, from 08.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 02.2021, from 02.2021, from 02.2021, from 08.2021, from 08.2021, from 08.2021, from 08.2022, from 08.2022, from 08.2022
    • UH630-UH635, UH650-UH656, UH661-UH668, UH671-UH676, UH750-UH755:
      • FW for Northern Hemisphere -> from 05.2016, from 08.2016, from 10.2016, from 10.2016, from 10.2016, from 10.2016, from 04.2017, from 07.2017, from 08.2017, from 08.2017, from 06.2018, from 07.2018, from 07.2018, from 01.2019, from 01.2019, from 04.2019, from 12.2019, from 08.2020, from 09.2020, from 12.2020, from 12.2020, from 04.2021, from 07.2021, from 01.2022, from 09.2022
      • FW for Southern Hemisphere -> from 08.2016, from 08.2016, from 08.2016, from 10.2016, from 05.2017, from 07.2017, from 09.2017, from 06.2018, from 06.2018, from 06.2018, from 01.2019, from 01.2019, from 01.2019, from 04.2019, from 04.2019, from 04.2019, from 12.2019, from 12.2019, from 12.2019, from 08.2020, from 08.2020, from 08.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 04.2021, from 04.2021, from 04.2021, from 07.2021, from 07.2021, from 07.2021, from 09.2022, from 09.2022, from 09.2022
    • UH700, UH770, OLED B6:
      • FW for Northern Hemisphere -> from 06.2016, from 08.2016, from 09.2016, from 10.2016, from 10.2016, from 10.2016, from 10.2016, from 11.2016, from 03.2017, from 04.2017, from 07.2017, from 08.2017, from 08.2017, from 05.2018, from 07.2018, from 07.2018, from 01.2019, from 04.2019, from 05.2019, from 01.2020, from 07.2020, from 09.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 08.2021, from 08.2022, from 09.2022
      • FW for Southern Hemisphere -> from 08.2016, from 08.2016, from 08.2016, from 10.2016, from 10.2016, from 10.2016, from 11.2016, from 11.2016, from 11.2016, from 06.2017, from 07.2017, from 07.2017, from 09.2017, from 05.2018, from 05.2018, from 05.2018, from 04.2019, from 04.2019, from 04.2019, from 01.2020, from 01.2020, from 01.2020, from 08.2020, from 08.2020, from 08.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 08.2021, from 08.2021, from 08.2021, from 08.2022, from 08.2022, from 08.2022, from 09.2022, from 09.2022, from 09.2022
    • UH780, UH850-UH855, UH950-UH955, OLED (C6, E6):
      • FW for Northern Hemisphere -> from 06.2016, from 08.2016, from 10.2016, from 10.2016, from 10.2016, from 10.2016, from 10.2016, from 10.2016, from 04.2017, from 06.2017, from 06.2017, from 07.2017, from 07.2017, from 07.2017, from 06.2018, from 07.2018, from 07.2018, from 01.2019, from 04.2019, from 12.2019, from 07.2020, from 09.2020, from 04.2021, from 04.2021, from 07.2021, from 01.2022, from 09.2022
      • FW for Southern Hemisphere -> from 08.2016, from 08.2016, from 08.2016, from 05.2017, from 09.2017, from 06.2018, from 06.2018, from 06.2018, from 04.2019, from 04.2019, from 04.2019, from 12.2019, from 12.2019, from 01.2020, from 08.2020, from 08.2020, from 08.2020, from 04.2021, from 04.2021, from 04.2021, from 04.2021, from 04.2021, from 04.2021, from 07.2021, from 07.2021, from 07.2021, from 09.2022, from 09.2022, from 09.2022
    • OLED G6:
      • FW for Northern Hemisphere -> from 06.2016, from 08.2016, from 10.2016, from 10.2016, from 10.2016, from 04.2017, from 06.2017, from 06.2017, from 07.2017, from 06.2018, from 06.2018, from 07.2018, from 07.2018, from 01.2019, from 05.2019, from 12.2019, from 07.2020, from 09.2020, from 01.2021, from 03.2021, from 03.2021, from 07.2021, from 09.2022
      • FW for Southern Hemisphere -> from 05.2016, from 08.2016, from 08.2016, from 08.2016, from 08.2016, from 10.2016, from 10.2016, from 06.2017, from 06.2017, from 09.2017, from 06.2018, from 06.2018, from 05.2019, from 05.2019, from 01.2020, from 01.2020, from 08.2020, from 08.2020, from 01.2021, from 01.2021, from 03.2021, from 03.2021, from 03.2021, from 03.2021, from 07.2021, from 07.2021, from 09.2022, from 09.2022
  • For TV models 2017 year (webOS 3.5)
    • LJ480, LJ540, LJ550-LJ555, LJ570, LJ594-LJ595, LJ600, LJ610-LJ615, LJ622-LJ625, MT49S - 2017 year and 28LK480U - 2018 year (webOS 3.5):
      • FW for Northern Hemisphere -> from 04.2017, from 06.2017, from 09.2017, from 09.2017, from 10.2017, from 11.2017, from 01.2018, from 02.2018, from 03.2018, from 05.2018, from 09.2018, from 10.2018, from 11.2018, from 12.2018, from 01.2019, from 06.2019, from 11.2019, from 08.2020, from 01.2021, from 03.2021, from 10.2021, from 09.2022
      • FW for Southern Hemisphere -> from 06.2017, from 01.2018, from 10.2018, from 10.2018, from 10.2018, from 12.2018, from 12.2018, from 12.2018, from 01.2019, from 01.2019, from 01.2019, from 06.2019, from 06.2019, from 06.2019, from 11.2019, from 11.2019, from 11.2019, from 03.2021, from 03.2021, from 03.2021, from 10.2021, from 10.2021, from 10.2021, from 09.2022, from 09.2022, from 09.2022
    • UJ620, UJ630-UJ635, UJ650-UJ655, UJ670-UJ675, UJ701 - 2017 year and UK6100 - 2018 year (webOS 3.5):
      • FW for Northern Hemisphere -> from 03.2017, from 05.2017, from 08.2017, from 09.2017, from 11.2017, from 01.2018, from 02.2018, from 03.2018, from 05.2018, from 05.2018, from 05.2018, from 06.2018, from 06.2018, from 07.2018, from 07.2018, from 08.2018, from 09.2018, from 10.2018, from 10.2018, from 11.2018, from 01.2019, from 02.2019, from 03.2019, from 05.2019, from 12.2019, from 08.2020, from 08.2020, from 03.2021, from 04.2021, from 10.2021, from 09.2022
      • FW for Southern Hemisphere -> from 09.2017, from 06.2018, from 06.2018, from 06.2018, from 07.2018, from 07.2018, from 07.2018, from 07.2018, from 08.2018, from 10.2018, from 10.2018, from 10.2018, from 11.2018, from 01.2019, from 01.2019, from 01.2019, from 01.2019, from 03.2019, from 03.2019, from 05.2019, from 05.2019, from 05.2019, from 09.2019, from 12.2019, from 12.2019, from 12.2019, from 02.2020, from 03.2020, from 03.2021, from 03.2021, from 03.2021, from 04.2021, from 04.2021, from 04.2021, from 10.2021, from 10.2021, from 10.2021, from 09.2022, from 09.2022, from 09.2022
    • UJ740, UJ750-UJ752, SJ800, SJ810, SJ850, SJ930, SJ950-SJ957, OLED (B7, C7, E7, G7, W7) - 2017 year and SK7900 - 2018 year (webOS 3.5):
      • FW for Northern Hemisphere -> from 05.2017, from 09.2017, from 09.2017, from 11.2017, from 02.2018, from 03.2018, from 03.2018, from 05.2018, from 09.2018, from 09.2018, from 10.2018, from 11.2018, from 12.2018, from 01.2019, from 03.2019, from 06.2019, from 12.2019, from 02.2020, from 08.2020, from 08.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 07.2021, from 08.2021, from 09.2022
      • FW for Southern Hemisphere -> from 03.2017, from 09.2017, from 03.2018, from 05.2018, from 05.2018, from 10.2018, from 10.2018, from 10.2018, from 11.2018, from 11.2018, from 11.2018, from 01.2019, from 01.2019, from 01.2019, from 05.2019, from 03.2019, from 03.2019, from 06.2019, from 06.2019, from 06.2019, from 08.2019, from 12.2019, from 12.2019, from 12.2019, from 01.2020, from 01.2020, from 02.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 09.2022, from 09.2022, from 09.2022
    • Bang & Olufsen BeoVision Eclipse:
      • FW for Northern Hemisphere -> from 09.2017, from 03.2018, from 03.2018
      • FW for Southern Hemisphere -> from 01.2018
  • For TV models 2018 year (webOS 4.0)
    • LK5400, 32LK540B, LK5900-LK5990, LK6000, LK6100-LK6190, 32LK610B, 32LK615B:
      • FW for Northern Hemisphere -> from 04.2018, from 05.2018, from 07.2018, from 09.2018, from 10.2018, from 11.2018, from 06.2019, from 10.2019, from 11.2019, from 03.2020, from 12.2020, from 12.2020, from 01.2021, from 06.2021, from 07.2021, from 08.2021, from 12.2021, from 01.2022, from 06.2022, from 08.2022
      • FW for Southern Hemisphere -> from 03.2018, from 09.2018, from 09.2018, from 09.2018, from 09.2018, from 11.2018, from 06.2019, from 07.2019, from 07.2019, from 10.2019, from 11.2019, from 11.2019, from 11.2019, from 03.2020, from 03.2020, from 03.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 12.2021, from 12.2021, from 12.2021, from 01.2022, from 01.2022, from 01.2022, from 08.2022, from 08.2022, from 08.2022
    • UK6200, UK6300-UK6390, UK6400-UK6470, UK6500-UK6550, UK6710-UK6750, UK6950, UK7500-UK7550, UK7700:
      • FW for Northern Hemisphere -> from 04.2018, from 05.2018, from 05.2018, from 06.2018, from 07.2018, from 08.2018, from 08.2018, from 08.2018, from 10.2018, from 03.2019, from 05.2019, from 06.2019, from 07.2019, from 10.2019, from 11.2019, from 03.2020, from 07.2020, from 08.2020, from 11.2020, from 12.2020, from 12.2020, from 01.2021, from 06.2021, from 06.2021, from 07.2021, from 08.2021, from 01.2022, from 05.2022, from 06.2022, from 08.2022, from 08.2022
      • FW for Southern Hemisphere -> from 03.2018, from 06.2018, from 09.2018, from 11.2018, from 11.2018, from 01.2019, from 01.2019, from 03.2019, from 07.2019, from 07.2019, from 07.2019, from 10.2019, from 11.2019, from 11.2019, from 11.2019, from 03.2020, from 03.2020, from 03.2020, from 07.2020, from 07.2020, from 07.2020, from 08.2020, from 08.2020, from 08.2020, from 09.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 01.2022, from 01.2022, from 01.2022, from 08.2022, from 08.2022, from 08.2022, from 09.2022, from 09.2022, from 09.2022
    • 86UK6500, 86UK6750, SK8000, SK8100, SK8500, SK9000, SK9500, OLED B8:
      • FW for Northern Hemisphere -> from 04.2018, from 05.2018, from 07.2018, from 07.2018, from 07.2018, from 08.2018, from 09.2018, from 10.2018, from 10.2018, from 11.2018, from 11.2018, from 03.2019, from 04.2019, from 06.2019, from 07.2019, from 09.2019, from 10.2019, from 11.2019, from 03.2020, from 07.2020, from 08.2020, from 11.2020, from 12.2020, from 12.2020, from 01.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 01.2022, from 05.2022, from 05.2022, from 07.2022, from 08.2022
      • FW for Southern Hemisphere -> from 03.2018, from 05.2018, from 06.2018, from 09.2018, from 08.2018, from 09.2018, from 04.2019, from 04.2019, from 04.2019, from 07.2019, from 07.2019, from 07.2019, from 08.2019, from 10.2019, from 11.2019, from 11.2019, from 11.2019, from 03.2020, from 03.2020, from 03.2020, from 07.2020, from 07.2020, from 07.2020, from 11.2020, from 11.2020, from 11.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 01.2022, from 01.2022, from 01.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 08.2022, from 08.2022, from 08.2022
    • OLED (C8, E8, G8, W8):
      • FW for Northern Hemisphere -> from 04.2018, from 05.2018, from 07.2018, from 07.2018, from 08.2018, from 09.2018, from 10.2018, from 11.2018, from 11.2018, from 03.2019, from 04.2019, from 04.2019, from 06.2019, from 07.2019, from 09.2019, from 10.2019, from 11.2019, from 02.2020, from 06.2020, from 08.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 06.2021, from 07.2021, from 08.2021, from 01.2022, from 06.2022, from 08.2022
      • FW for Southern Hemisphere -> from 03.2018, from 06.2018, from 09.2018, from 09.2018, from 09.2018, from 04.2019, from 04.2019, from 04.2019, from 07.2019, from 07.2019, from 07.2019, from 08.2019, from 10.2019, from 11.2019, from 11.2019, from 11.2019, from 02.2020, from 02.2020, from 02.2020, from 06.2020, from 06.2020, from 06.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 01.2022, from 01.2022, from 01.2022, from 08.2022, from 08.2022, from 08.2022
  • For TV models 2019 year (webOS 4.5)
    • LM6300-LM6390, LM6500:
      • FW for Northern Hemisphere -> from 04.2019, from 05.2019, from 06.2019, from 09.2019, from 12.2019, from 01.2020, from 02.2020, from 02.2020, from 02.2020, from 10.2020, from 11.2020, from 01.2021, from 02.2021, from 06.2021, from 12.2021, from 02.2022, from 02.2022, from 03.2022, from 05.2022, from 07.2022, from 07.2022, from 09.2022, from 10.2022
      • FW for Southern Hemisphere -> from 06.2019, from 06.2019, from 06.2019, from 09.2019, from 09.2019, from 09.2019, from 12.2019, from 12.2019, from 12.2019, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 11.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 02.2021, from 02.2021, from 02.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 12.2021, from 12.2021, from 12.2021, from 02.2022, from 02.2022, from 02.2022, from 03.2022, from 03.2022, from 03.2022, from 05.2022, from 05.2022, from 05.2022, from 09.2022, from 09.2022, from 09.2022
    • UM7050-UM7090, UM7100-UM7110, UM7300, UM7400-UM7490, UM7500-UM7570, UM7600-UM7660, SM8000, SM8050, SM8100, SM8200:
      • FW for Northern Hemisphere -> from 05.2019, from 04.2019, from 05.2019, from 05.2019, from 09.2019, from 10.2019, from 11.2019, from 11.2019, from 12.2019, from 01.2020, from 02.2020, from 05.2020, from 06.2020, from 06.2020, from 08.2020, from 08.2020, from 10.2020, from 11.2020, from 01.2021, from 05.2021, from 06.2021, from 06.2021, from 07.2021, from 12.2021, from 01.2022, from 02.2022, from 05.2022, from 07.2022, from 09.2022, from 10.2022, from 11.2022
      • FW for Southern Hemisphere -> from 05.2019, from 05.2019, from 05.2019, from 09.2019, from 09.2019, from 09.2019, from 10.2019, from 10.2019, from 10.2019, from 12.2019, from 12.2019, from 12.2019, from 01.2020, from 01.2020, from 01.2020, from 02.2020, from 02.2020, from 02.2020, from 05.2020, from 05.2020, from 05.2020, from 06.2020, from 06.2020, from 06.2020, from 06.2020, from 06.2020, from 08.2020, from 08.2020, from 08.2020, from 10.2020, from 10.2020, from 10.2020, from 01.2021, from 01.2021, from 01.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 09.2021, from 12.2021, from 12.2021, from 12.2021, from 02.2022, from 02.2022, from 02.2022, from 05.2022, from 05.2022, from 05.2022, from 09.2022, from 09.2022, from 09.2022, from 10.2022, from 10.2022, from 09.2022
    • 82/86UM7600, 82UM7650, SM8500, SM8600-SM8610, SM9000-SM9010, SM9500, SM9800, OLED B9:
      • FW for Northern Hemisphere -> from 04.2019, from 05.2019, from 04.2019, from 05.2019, from 06.2019, from 06.2019, from 07.2019, from 07.2019, from 08.2019, from 10.2019, from 11.2019, from 12.2019, from 02.2020, from 02.2020, from 04.2020, from 05.2020, from 08.2020, from 09.2020, from 09.2020, from 10.2020, from 11.2020, from 01.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 12.2021, from 01.2022, from 03.2022, from 04.2022, from 06.2022, from 09.2022, from 10.2022, from 10.2022
      • FW for Southern Hemisphere -> from 05.2019, from 05.2019, from 05.2019, from 07.2019, from 07.2019, from 07.2019, from 08.2019, from 08.2019, from 08.2019, from 10.2019, from 10.2019, from 10.2019, from 12.2019, from 12.2019, from 12.2019, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 04.2020, from 04.2020, from 04.2020, from 05.2020, from 05.2020, from 05.2020, from 08.2020, from 09.2020, from 09.2020, from 09.2020, from 10.2020, from 10.2020, from 10.2020, from 01.2021, from 01.2021, from 01.2021, from 05.2021, from 05.2021, from 05.2021, from 07.2021, from 07.2021, from 07.2021, from 12.2021, from 12.2021, from 12.2021, from 01.2022, from 01.2022, from 01.2022, from 03.2022, from 03.2022, from 03.2022, from 04.2022, from 04.2022, from 04.2022, from 09.2022, from 09.2022, from 09.2022, from 10.2022, from 10.2022, from 10.2022
    • SM9900-SM9970, OLED (C9, E9, R9, W9, Z9):
      • FW for Northern Hemisphere -> from 04.2019, from 05.2019, from 05.2019, from 06.2019, from 06.2019, from 06.2019, from 07.2019, from 09.2019, from 09.2019, from 10.2019, from 11.2019, from 11.2019, from 12.2019, from 02.2020, from 02.2020, from 04.2020, from 04.2020, from 05.2020, from 08.2020, from 09.2020, from 10.2020, from 11.2020, from 02.2021, from 03.2021, from 05.2021, from 06.2021, from 06.2021, from 07.2021, from 12.2021, from 01.2022, from 02.2022, from 03.2022, from 04.2022, from 06.2022, from 07.2022, from 09.2022, from 10.2022
      • FW for Southern Hemisphere -> from 05.2019, from 05.2019, from 05.2019, from 07.2019, from 07.2019, from 07.2019, from 09.2019, from 09.2019, from 09.2019, from 12.2019, from 12.2019, from 12.2019, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 02.2020, from 04.2020, from 04.2020, from 04.2020, from 05.2020, from 05.2020, from 05.2020, from 09.2020, from 09.2020, from 09.2020, from 10.2020, from 10.2020, from 10.2020, from 02.2021, from 02.2021, from 02.2021, from 03.2021, from 03.2021, from 03.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 12.2021, from 12.2021, from 12.2021, from 02.2022, from 02.2022, from 02.2022, from 03.2022, from 03.2022, from 03.2022, from 04.2022, from 04.2022, from 04.2022, from 09.2022, from 09.2022, from 09.2022, from 10.2022, from 10.2022, from 10.2022
  • For TV models 2020 year (webOS 5.0)
    • UN7100, UN7300-UN7390, UN7400, UN8000, UN8100, NANO79, NANO80, NANO81:
      • FW for Northern Hemisphere -> from 03.2020, from 04.2020, from 06.2020, from 06.2020, from 07.2020, from 09.2020, from 10.2020, from 11.2020, from 11.2020, from 01.2021, from 01.2021, from 02.2021, from 02.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 08.2021, from 09.2021, from 09.2021, from 12.2021, from 12.2021, from 01.2022, from 03.2022, from 03.2022, from 04.2022, from 05.2022, from 09.2022, from 10.2022, from 11.2022
      • FW for Southern Hemisphere -> from 03.2020, from 03.2020, from 03.2020, from 04.2020, from 04.2020, from 04.2020, from 07.2020, from 07.2020, from 07.2020, from 07.2020, from 08.2020, from 11.2020, from 11.2020, from 11.2020, from 11.2020, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 02.2021, from 02.2021, from 02.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 12.2021, from 12.2021, from 12.2021, from 12.2021, from 12.2021, from 12.2021, from 03.2022, from 03.2022, from 03.2022, from 03.2022, from 03.2022, from 03.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 09.2022, from 09.2022, from 09.2022, from 10.2022, from 10.2022
    • UN8500, NANO85, NANO86, NANO90, NANO91, OLED BX:
      • FW for Northern Hemisphere -> from 03.2020, from 04.2020, from 04.2020, from 04.2020, from 05.2020, from 05.2020, from 06.2020, from 06.2020, from 07.2020, from 07.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 10.2020, from 11.2020, from 01.2021, from 01.2021, from 02.2021, from 02.2021, from 03.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 08.2021, from 08.2021, from 09.2021, from 09.2021, from 12.2021, from 12.2021, from 01.2022, from 02.2022, from 03.2022, from 04.2022, from 05.2022, from 09.2022, from 10.2022, from 11.2022
      • FW for Southern Hemisphere -> from 03.2020, from 03.2020, from 03.2020, from 03.2020, from 04.2020, from 04.2020, from 04.2020, from 04.2020, from 04.2020, from 04.2020, from 05.2020, from 05.2020, from 05.2020, from 05.2020, from 05.2020, from 05.2020, from 07.2020, from 07.2020, from 07.2020, from 07.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 10.2020, from 10.2020, from 10.2020, from 11.2020, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 01.2021, from 02.2021, from 02.2021, from 02.2021, from 06.2021, from 06.2021 from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 12.2021, from 12.2021, from 12.2021, from 12.2021, from 02.2022, from 02.2022, from 02.2022, from 03.2022, from 03.2022, from 03.2022, from 04.2022, from 04.2022, from 04.2022, from 05.2022, from 05.2022, from 05.2022, from 09.2022, from 09.2022, from 09.2022, from 10.2022, from 10.2022
    • NANO95, NANO97, NANO99, OLED ZX:
      • FW for Northern Hemisphere -> from 04.2020, from 05.2020, from 05.2020, from 07.2020, from 09.2020, from 09.2020, from 12.2020, from 03.2021, from 04.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 08.2021, from 10.2021, from 10.2021, from 12.2021, from 01.2022, from 02.2022, from 02.2022, from 05.2022, from 05.2022, from 06.2022, from 09.2022, from 10.2022, from 11.2022
      • FW for Southern Hemisphere -> from 04.2020, from 04.2020, from 04.2020, from 05.2020, from 05.2020, from 05.2020, from 07.2020, from 07.2020, from 07.2020, from 07.2020, from 07.2020, from 04.2021, from 05.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 07.2021, from 09.2021, from 10.2021, from 10.2021, from 10.2021, from 10.2021, from 10.2021, from 12.2021, from 12.2021, from 12.2021, from 02.2022, from 02.2022, from 02.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 06.2022, from 06.2022, from 06.2022, from 09.2022, from 10.2022, from 10.2022, from 10.2022
    • OLED (CX, GX, RX, WX):
      • FW for Northern Hemisphere -> from 03.2020, from 04.2020, from 04.2020, from 05.2020, from 05.2020, from 06.2020, from 07.2020, from 07.2020, from 08.2020, from 08.2020, from 09.2020, from 09.2020, from 11.2020, from 11.2020, from 12.2020, from 01.2021, from 03.2021, from 04.2021, from 05.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 09.2021, from 09.2021, from 12.2021, from 01.2022, from 03.2022, from 05.2022, from 05.2022, from 06.2022, from 09.2022, from 10.2022, from 11.2022
      • FW for Southern Hemisphere -> from 03.2020, from 03.2020, from 03.2020, from 04.2020, from 04.2020, from 04.2020, from 04.2020, from 04.2020, from 04.2020, from 06.2020, from 06.2020, from 06.2020, from 07.2020, from 07.2020, from 07.2020, from 07.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 09.2020, from 11.2020, from 11.2020, from 11.2020, from 12.2020, from 12.2020, from 12.2020, from 01.2021, from 01.2021, from 01.2021, from 04.2021, from 04.2021, from 04.2021, from 05.2021, from 05.2021, from 05.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 06.2021, from 07.2021, from 07.2021, from 07.2021, from 08.2021, from 08.2021, from 08.2021, from 08.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 09.2021, from 12.2021, from 12.2021, from 12.2021, from 03.2022, from 03.2022, from 03.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 05.2022, from 06.2022, from 06.2022, from 06.2022, from 09.2022, from 09.2022, from 10.2022, from 10.2022
Ā
  • 1 month later...
Latest Update for these devices:
55UP7720PTCĀ  55UP7750PTBĀ  55UP7700PTCĀ  65UP7750PTBĀ  43UP7700PTCĀ  43UP7750PTBĀ  55UP7800PTBĀ  43UP7720PTCĀ  43UP7800PTBĀ  55UP7750PTZĀ  55UP7720PTYĀ  55UP7740PTZĀ  43UP7720PTYĀ  43UP7750PTZĀ  65UP7720PTCĀ  75UP7700PTBĀ  75UP7750PTBĀ  65UP7800PTBĀ  75UP7800PTBĀ  50UP7750PTBĀ  50UP7720PTCĀ  50UP7800PTBĀ  70UP7750PTBĀ  60UP7750PTBĀ  70UP7800PTBĀ  65UP7720PTYĀ  65UP7740PTZĀ  65UP7750PTZĀ  75UP7750PTZĀ  43UP7740PTZĀ  50UP7750PTZĀ  60UP7750PTZĀ  70UP7750PTZĀ  50UP7750PVBĀ  43UP7750PVBĀ  55UP7750PVBĀ  65UP7750PVBĀ  75UP7750PVBĀ  70UP7750PVBĀ Ā  Ā
WebOS Version 6.3.2-423
FW Version 03.34.55
Release date: 01/01/2023
Update file size: 1,159,516K
Ā
  • Thanks 1
  • 6 months later...
Greetings to all ! Unfortunately, today my TV LG 43UK6200PLA remained blocked. The logo lights up, the circles spin as if "thinking" then the screen goes black... It's an lg 43uk6200pla taken from Romania, produced in 2018. Do you have any advice for me please? Thank you !
  • 1 month later...
      Hello,Ā
      Thank you a lot in advance, help would be a lifesaver Ā Here I found online manualĀ  link hidden, please login to view
      It is MY home screen, not yoursā˜¹ļø
      Players can quickly find their preferred gaming experience by selecting either ā€œPlay with Remote Controlā€ or ā€œPlay with Game Padā€ from the left-side menu, eliminating the need to search through individual games.
      Enhancing the gaming experience further for PC or console games, LG TVs support 4K at 120Hz variable refresh rate (VRR) for fluid, tear-free gameplay and boast NVIDIA G-SYNCĀ® Compatible and AMD FreeSync Premium certification.
      1 Available in Austria, Belgium, Brazil, Canada, Chile, Denmark, France, Germany, Italy, Ireland, Mexico, Netherlands, Poland, Spain, Sweden, Switzerland,Ā Turkiye, UK and USA.
