Create PC share (Plex) Shortcut
    • By DavidSr
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
      At the heart of LG appliances lies its powerful Core-Tech, now enhanced with AI capabilities. This technology enables intelligent control of key components, enhancing energy efficiency, ensuring delicate performance and delivering tailored solutions that embody LG’s vision of a Better Life for All.
      For instance, LG washing machines feature AI DD, which combines deep learning technology with the company’s 6 Motion Direct Drive technology. This system analyzes fabric types and optimizes washing cycles, utilizing six unique drum motions to provide tailored care for all kinds of fabrics. This not only enhances washing efficiency but also minimizes damage to clothing. However, LG’s commitment to enriching lives extends beyond products. LG offices worldwide actively utilize the company’s laundry solutions to benefit local communities.
      In September, Typhoon Yagi ravaged large parts of Southeast Asia including Vietnam. In response, LG Vietnam took action to help the residents of Nam Định and Yên Bái by operating mobile and stationary laundry stations free of charge. This initiative allowed nearly 425 locals to clean approximately 3.5 tons of clothing and blankets.
      To handle this significant volume of laundry, LG deployed over 60 employees to operate the washing stations, which were fully equipped with advanced washers and dryers. This ensured that every item was thoroughly cleaned and deodorized after exposure to contaminated floodwater.
      This initiative builds on LG’s previous efforts to assist communities in central Vietnam affected by natural disasters in 2020, where free laundry stations across the Quang Binh and Quang Tri provinces cleaned nearly 1,000 kilograms of laundry.
      Once this vital campaign concludes, LG Vietnam plans to donate the washing appliances used to educational and medical institutions in Yen Bai and Nam Định, ensuring they continue to serve the community. In addition, the company provided residents in 24 northern provinces with a special warranty from September 12 to October 10, covering repairs for LG appliances and electronics damaged by the typhoon.
      In India, LG has embarked on a new business venture with the launch of LG Laundry Crew, a self-laundry service designed for college and university hostels, starting at Galgotias University in Greater Noida this February.
      This service delivers the convenience of LG’s washers via the user-friendly “Laundry Crew” application, which facilitates reservations, operations and payments. This first-of-its-kind IoT-enabled laundromat system alleviates one of the biggest challenges of campus life, allowing students to save time for their studies.
      To enhance students’ lives, LG India had opened around 100 self-laundry service centers in various college campuses across India and plans to further expand this service to reach 200 self-laundry service centers.
      LG is equally committed to enhancing convenience for its commercial business partners. In Thailand, the company has expanded into commercial washing machines with the launch of its first LG Laundry Crew laundromat in February, coinciding with its launch in India. This expansion highlights three key strengths: strong consumer trust in the brand, specialized commercial washing machines and dryers tailored for laundromats and comprehensive after-sales services for store owners.
      With Thailand’s flourishing laundromat industry showing significant growth potential, combined with LG’s 35-year market leadership in the washing machine segment, LG Thailand was inspired to introduce the LG Laundry Crew—a pioneering laundromat franchise prototype. As the first official LG-branded laundromat franchise in Thailand, LG stands as the sole provider of commercial washing and drying machines specifically designed for laundromats, enabling entrepreneurs to optimize their investments and reduce operational costs by avoiding oversized equipment.
      LG’s established consumer trust and efficient after-sales support system underscore the company’s confidence in the success of this laundromat franchise venture. LG Thailand offers franchise owners an extensive range of benefits, including comprehensive after-sales support featuring complimentary monthly maintenance services for the first two years and bi-annual drum cleaning services to ensure consistent cleanliness and odor-free operation.
      More importantly, in response to the recent devastating floods in northern Thailand that particularly affected Chiang Rai and Phayao provinces, LG Thailand launched the “#LGFreeLaundryService” initiative between September 19-30, providing the free laundry service to assist over 1,300 flood victims across three strategic locations in both provinces, helping communities cope with the aftermath of flood-damaged belongings and mud-soaked materials. This initiative exemplifies LG’s core brand promise of “Life’s Good,” demonstrating our commitment to delivering innovation for a better life that extends beyond mere service provision to meaningful community support.
      Stay tuned to
      link hidden, please login to view to see what other aspects of life the company is revolutionizing around the globe. Contributed by LG Vietnam, LG India and LG Thailand
      Company Outlines Direction and “Break Through Limits” Management Policy
      During Press Conference in Las Vegas
      LAS VEGAS, Jan. 10, 2024 — LG Electronics’ (LG) CEO William Cho and key company executives introduced the strategies LG is implementing to achieve its ‘Future Vision 2030’ goal, during a press conference held for Korean media in Las Vegas, Nevada, U.S.A., on January 10.
      The CEO began the proceedings by noting that LG had identified three major inflection points – electrification, servitization and digitalization – that will ultimately reshape business and the customer experience. The company aims to overcome challenges, such as persistent market and supply chain uncertainties, and accelerate growth by building a high-performance, results-oriented organization with a winning spirit.
      “If 2023 was the year in which we set the direction for new changes, we will make 2024 the year in which we truly accelerate these changes,” said CEO Cho. “Future Vision 2030 is our promise to the market and to our customers, and we will strive as a company to deliver on this promise.”
      Announced by the CEO last year, Future Vision 2030 is LG’s long-term goal to transform into ‘Smart Life Solution Company’ that can connect and expand the customer experience across various spaces, including home, commercial, mobility and virtual.
      Strengthening Future Competitiveness Through Investment
      CEO Cho set ‘Break through Limits’ as the key phrase for, and underlying philosophy of the company’s management policy in 2024. Having already established three focus areas for future growth – a non-hardware business model, B2B expansion and the development of new businesses – LG will now make an all-out effort to further refine its portfolio.
      To start with, the company will maximize the potential of its future growth engines by expanding investment based on the strategic priorities of the business. This year, the company will more than double its level of investment; putting USD 8 billion* into R&D and other critical areas to strengthen competitiveness, moving forward.
      High-growth and high-profit core businesses will also see larger investment in 2024. These include B2B businesses, such as vehicle components, HVAC, built-in appliances and digital signage, as well as the webOS platform business. LG will continue to invest in new businesses, such as electric vehicle (EV) charging and robotics, and has already announced plans to invest more than USD 40 billion* by 2030 to transform its portfolio for qualitative business growth.
      Furthermore, beginning this year, LG will actively seek inorganic growth opportunities, such as mergers, acquisitions and partnerships, in addition to adopting strategies designed to invigorate its internal growth engines. Emphasis will also be placed on game-changing areas of technology that add customer value, such as AI and mixed reality (MR).
      The CEO identified the newly established Overseas Sales and Marketing Company as a valuable asset for helping LG “break through limits.” Already playing an important role in LG’s global success, the new organization accounted for approximately two-thirds of the company’s total sales. The Overseas Sales and Marketing Company implements specialized strategies that take into consideration the unique characteristics of each region and market. Its efforts have maximized the performance of the business, worldwide, and have played a significant role in strengthening the capabilities and growth of LG’s international subsidiaries.
      Achieving ‘Triple Seven’ Goals for Growth, Profit and Value
      With platform-based service businesses, the B2B business and new businesses as its three, main growth engines, the company aims to reach its goal of ‘Triple Seven’: an average growth rate and operating profit of seven percent or more, as well as enterprise value that translates to an EBITDA ratio of seven.
      Last year, despite a decline in market demand, the company performed impressively thanks to the growth of its B2B business. Over the past five years, the compound annual growth rate of LG’s B2B businesses has easily exceeded double digits, with the average annual growth rate of overall sales reaching around eight percent.
      The Vehicle component Solutions (VS) Company has likewise emerged as a key business for LG, achieving annual sales of USD 8 billion* in its 10th year of existence. The global transition to EVs is expected to increase the demand for high-value EV parts, one of the VS Company’s core areas of expertise.
      Based on the three pillars of in-vehicle infotainment (IVI), e-powertrains and vehicular lamps, the VS Company is projected to enjoy continuous, rapid growth. From 2024, it will focus primarily on securing software-defined vehicle capabilities, expanding its EV parts customer-base, and strengthening its leadership in smart lamps. To respond to the increasing number of new orders, the company will invest in boosting production capacity in Central America, South America and Europe.
      The HVAC business, another important part of LG’s B2B portfolio, is growing quickly in emerging markets such as Asia and Central and South America, while in advanced markets, including Europe and North America – where demand for high-efficiency, eco-friendly products is strong – it continues to uncover new opportunities.
      LG’s HVAC business aims to leverage the competitiveness of its technologically advanced components, such as motors and compressors, to expand its product lineup. After establishing a consortium for advanced heat pump research in Alaska, U.S.A., last November, LG plans to build an R&D base in Europe this year. The company also intends to broaden its business with the introduction of differentiated air conditioning products, such as the Dedicated Outdoor Air System.
      Recognizing that B2B companies are impacted less directly by the economy than B2C companies, LG is actively bolstering its B2B business as a means to maintain sales and profit stability. The company has announced plans for the expansion of its B2B businesses, and is seeking to raise sales volume to more than USD 32 billion* (double the current level) by 2030 through launching a variety of new, value-added solutions.
      LG will also fast-track the evolution of its overall business model, entering non-hardware areas, such as content, services and subscriptions, to complement its existing product-centric home appliance and TV companies. Leveraging the hundreds of millions of LG products already in use around the world as ‘platforms,’ the company expects to generate continuous sales and profits.
      In line with this shift in business direction, the Home Entertainment (HE) Company aims to become a media and entertainment platform company and accelerate the growth of its webOS platform business. The HE Company is rapidly reinforcing the foundations of its platform business by expanding the webOS ecosystem to include smart monitors, IVI systems, and other TV makers. LG expects the webOS platform business to become one of the most potential growth engines  in the near future.
      The Home Appliance and Air Solution (H&A) Company, whose success is playing a preeminent role in supporting LG’s organization-wide transformation, is also developing a smart home solution business that combines services and subscriptions. The H&A Company’s ultimate goal is to deliver on its ‘Zero Labor Home, Makes Quality Time’ vision, which goes beyond home appliances to make homelife smarter and more convenient than ever.
      The subscription business, encompassing ‘daily’ services that augment LG’s home appliance products, has been growing at a fast pace in South Korea. The overseas expansion of the subscription business is underway, with strategic markets in Asia the first outside of Korea to experience its many benefits.
      The percentage of LG’s total sales accounted for by its non-hardware businesses – such as the webOS platform-based content and service business, and the home appliance subscription business – has more than doubled over the past five years.
      Additionally, LG will aggressively promote the commercialization of intangible assets, such as its standard essential patents in critical areas of technology including communications, media, mobility and IoT connectivity. And, during its recent reorganization, the company established new business entities to commercialize its know-how in the construction of smart factories.
      Moreover, LG will secure growth opportunities offering high potential and a high degree of business synergy. As a prime example, the LG NOVA will increase its startup promotion fund to more than USD 100 million by the end of 2024, enabling the company to help discover new technologies and solutions to drive future innovation, and to lead new business segments.
      LG’s recently created EV charging business is emerging as a comprehensive EV charging solutions provider, boasting advanced charging units and control solutions, remote diagnosis and servicing capabilities, as well as vehicle battery diagnosis and robust manufacturing and sales infrastructure. Entering the North American market, the company has completed the construction of a charger production line in Fort Worth, Texas, U.S.A.
      In the digital healthcare segment, the company is expanding its telemedicine business in cooperation with Amwell, and will also review the viability of offering services in areas such as prevention, diagnosis, post-management and recovery. In virtual reality, another promising business area, LG is preparing for the commercialization of MR devices. At the end of 2023, the company established an eXtended Reality business unit within the HE Company, and is continuing to collaborate on augmented reality solutions with various technology partners.
      In addition, the company’s Chief Technology Office (CTO), which leads the development of future technologies, is conducting intensive R&D programs to strengthen business competitiveness and discover new core technologies. In particular, the CTO is focusing on eight areas of technology: software, system on chip, AI, robotics, materials and parts, standards, next-generation computing and cloud/data.
      Accelerating DX Through Data-Driven Practices and Next-Gen ERP Investment
      Through digital transformation (DX), LG will provide customers with F.U.N. – First, Unique and New – experiences, and further enhance its customer-centric management system.
      The company is making large-scale IT investments to establish DX across the entire organization. On top of this, LG is building N-ERP, or Next-generation Enterprise Resource Planning, to seamlessly integrate and link the company’s business processes and systems. Intellytics Customer 360, a customer data platform that enables integrated management of data gathered from diverse customer contact points, will be rolled out globally from this year.
      LG’s DX efforts extend beyond the innovation of the customer experience to the improvement of value chain efficiency; from purchasing and manufacturing to delivery and sales. Last year, by applying DX to each value chain, LG raised productivity and efficiency to the value of more than USD 240 million.*
      Transforming Into a High-Performing Organization and Spreading ‘Life’s Good’ Values and Philosophy
      When speaking with employees, CEO Cho often quotes noted American management scholar, Peter Drucker: “Culture eats strategy for breakfast.” The CEO truly believes that a strong organizational culture is essential to turning strategy into good performance.
      During his ‘CEO F.U.N. Talk’ with employees last December, Mr. Cho outlined the company’s vision for 2024, which includes becoming a high-performing organization. He stated that, “To accomplish this, we need to intricately connect our mission, vision and goals, and have a relentless focus on execution.”
      United under the brand promise of Life’s Good, a variety of integrated brand activities, spanning marketing, ESG and CSR, will be initiated starting this year. The company will spread the values and philosophy that underpin Life’s Good with the spirit of a brave optimist, while also infusing the brand with a youthful dynamism. A self-professed ‘brave optimist,’ LG is an innovator that daringly faces difficulties, believes in pursuing opportunities for improvement, even during tough times, and finds solutions by listening and paying attention to its customers and the market.
      Visitors can experience LG’s latest innovations at its CES booth (#16008, Las Vegas Convention Center) from January 9-12. For more information on LG products unveiled at CES 2024, please view the
      * Exchange rate: KRW 1,250 per USD.
    • By bogeyman62
      Has anyone been able to run Screen Share from a Windows 10 PC? Mine will not connect to the LG TV.
