    • By Fricassee
    • By Wondering
    • By BUB
      2 TVs, one OLED77CXPUA and the other just installed OLED65C2PUA. 77’ shows a program in 2160p while the 65’ shows the same program only in 1080p. Anyone know why ? Thank you.
    • By Girevik
      Hello all,
      I recently got a soundbar for my LG TV and have it connected with HDMI ARC on HDMI 2 I do my TV watching with a Firestick. I have this weird issue where if I switch apps on my Firestick using one of the buttons that go to an app, or (sometimes) using voice commands, the switches to the HDMI 2 input.  If I choose the app from the menu, it works fine.
      I have no clue why how I start an app makes a difference, but is there a way to set the TV to ignore HDMI when it comes to automatically switching inputs?  I looked through the settings and thought I figured it out when I turned off instant game response on HDMI 2, but the switch is still happening.
    • By Sabab
      Hello. I am from Bangladesh. I have an LG  television (LG UP7550 43'' UHD 4K TV). I want to play movies with Bengali Subtitle. My TV isn't showing the Bengali subtitle file (srt or ass) though I have renamed it as the same name as the name of the movie and kept it in the same folder. How can I get rid of the problem? Do I need to use any special player for this purpose? Or is it completely impossible to watch movies with Bengali Sub?
