47LB650V: How can I turn off subtitles in MKV file?
By u84six
By MURAD
By Low Grade
hi,
By MinoDc
Hi to all.
What do you think
By dzoole
Silly question by me, but it seems that I can't find subtitle button on LG ThinQ app on my mobile phone? Anyone knows if we can select subtitles through the LG ThinQ app?
Raiker
Hi!
While playing MKV files via SmartShare (LG 47LB650V) I get subtitles turned on by default. The Subtitles button on remote does nothing. How can I turn them off without modifying the file?
Thanks.
6 answers to this question
