1 TB Western Digital Passport HDD (NTFS format) not getting detected
 I am planning to buy LG 42LB6500 WebOS TV from Malaysia. Before finalizing the model wanted to Test with my HDD which is 1 TB Western Digital passport model. Interstingly the TV wasn't able to detect the HDD?? What could be the Issue?? HDD is USB 3.0, but compatible with USB 2.0. Could it be a firmware issue?
24 answers to this question
Hi Prabul
Could you please tell me if your solution is working. My LG 49UB850T has the same problem, could not detect my 02 HDDs (in NTFS, Allocation unit size default is 4096 byte)
Looking forward to your respose.
I too have the same issue with my LG 42LB750T+1 TB Western Digital passport.  The HD is detected on my laptop, it is in NTFS format but fails to show up on the TV.
I've tested with a 2GB USB Stick and 250GB WD Hard Disk(both FAT32), it is able to detect both of those.
Is it a problem with the WD Hard disk? I've read online that NTFS works properly for larger capacity drives for some people.
Any info will be helpful.
Komail
Hi Thuan1979/Komali,
 I got my 1 TB WD passport HDD detected and able to play 1080p movies on my LG 42LB6500 TV.
I did the following steps.
1) Take a back-up of your data in HDD.
2) connect to Laptop / PC. In My computer find you HDD, Right Click; select format.
3) In format Pop-up menu, change file system to NTFS, change Allocation Unit Size to 16 kilobytes.
4) Click Start.
5) Copy movies  to HDD after Formating. Connect to your TV's USB/HDD port (earlier LG models had USB ports marked also as HDD, try connecting to these ports if HDD is mentioned).
6) WebOs Models will detect the HDD as soon as you connect it to USB/HDD  port (try USB port 1).
Try these and let me know if it helps. WebOs will create a new folder in you HDD.
Interesting, but how can you copy additional media to the harddrive without connecting it? That is a main benefit of using a NAS or HTPC with file share.
Any way to do this in the world of LG?
/H
Hi Komali,
      I understand that you have lots of DATA in you 1TB HDD. Try to find a way to take a back up somewhere.
Or else buy a new HDD dedicatedly for TV. From my experience Segate HDD's were getting detected without all this formatting.
As of now i dont have any other solution with me for this issue?
Hi all
I think the problem is that there are so many small-sized file in the disk. Try to move those file to other hard disk and keep only video files in your hard disk. I should work for whatever format.
Please check and let me know the result.
Hi, prabul
I am from India and I have 42LB6700 Model. I have the same problem with my WD My Passport HDD and the issue was it was password protected.
I just removed password and it is working fine now. No need to format. Hope this helps.  :)
Hi Prabul/Pranav.
Thanks for your replies.
Pranav, how do we remove the password protection? I haven't given any such password protection when I use it with my laptop.
Komail
Hi Komail.
A program called WD Security is used to create/remove password from WD HDDs. I don't have any idea about seagate.
When you connect your WD HDD what happens? Means it runs WD Unlocker first or any other program or it opens explorer directly.
Hi Komail,
Your TV should detect your HDD as it supports upto 2TB(NTFS).
You should check it with another HDD. If your friend have one then try it. Also if any of your friend or neighbor have Smart TV then try connect your HDD on that TV.
If still this problem persist then you must format your HDD.
I am  a newbie. Recently I have purchased LG42LB6500. I have two 1TB WD my passport, whereas one is loaded with all movies,music,data and other is loaded with just some files less than 1GB. The strange problem I am facing is that one of my 1TB WD (which has only files) is getting detected when connected to TV whereas the other (which as all movies,music,data) doesn't. Can anyone help me on this.
Here is additional info: Later, after connecting, I just waited and then surprisingly the second 1TB WD (which as all movies,music,data) also got detected but has taken almost 20 mins of time. I could able to see the folder structure on the TV and even tried playing a movie. Noticed that the movie was running, I could see the seekbar is running but am not able to hear (or) see the movie. What could be the problem?
Hello Everyone ...
I have recently bought the LG 50LB6520, and since, it frustrates me everyday i use it ...
the Web Browser, i cannot play a music file or live streaming radio in one tab and open a new one, the player in the first tab stops
YouTube, if i put it in pause, and tried to resume, it starts from the very beginning of the video
And the worst disaster i had with it, was regarding my 2 External HDDs 1TB each, which I had for nearly 5 years now, and contains all my universe, Programs, Family albums (Scanned old images, weddings, camera photos, a total size more than 100 GB), Games, Movies, Cartoons, Songs and Music, downloads .. i've had them for 5 years .. Oh My Merciful God
first i connected the 1TB hdd of my brother, and played some movies to try the new TV set and its capabilities .. I tried to find the option to UnPlug them .. but couldn't find it, so I assumed that it supports the direct UnPlug normally like the pc and everything went normal nothing happen to his hdd, his hdd mostly had fewer number of folders and mostly was movies..
when i tried to connect mine for the first time
they didn't work in the first time .. (now from the post I knew that they may needed like 20 Minutes after they are plugged .. How Come .. to be ready)
Plug .. Un-Plug .. Plug .. Un-Plug exchanging on both of them .. but sure nothing of them has worked
the disaster was when i tried to attach it to my laptop ..
1- Toshiba: was detected on the computer, and the drive letter appeared, but no size bar, and trying to browse it, it gives an error in the disk, the disk may be corrupted
2- WD MyPassport: was detected and showed the disk size and the remaining disk space, but when browsed it, I found the folder structure i had appearing as Unknown file icons with 0 kb size, also i found 2 new folders i didn't had before, and in one of them i found 1 folder form the Family Album (Camera) and it had the sub folders of it .. where does this came from ..
later on .. after searching for the problem with the HDDs
i've been able to "chkdsk /f y:" for the Toshiba, and restored that drive
but this didn't affect the WD
and to be so stupid as normal people .. i tried to put the toshiba back to the tv ..
this time .. i've been connecting a thump stick and detaching it .. and in one of these times it showed me a warning .. not to unplug it with the tv on .. as this might cause some problems
so .. i kept the tv off, plugged the hdd, opened the tv .. didnt read it .. turned off .. unplugged the hdd .. plugged to the laptop and BOOOOM ANOTHER 2 FOLDERS APPEARS AS 0 KB FILES .. THE WEBOS MUST BE FAULTY ..
please if anyone can help .. it would be sooo much appreciated, i can even pay him if he demands .. i just want my data back
Hello Everyone ...
I am using my WD 1TB HDD without any problem. My TV model is LB6700. I am from India. WebOS version is different for different-different areas.
I don't know what is the problem but you might get your data back.
You mentioned that your HDD showing size correctly but files are missing; it is possible that your files are hidden (Also check show system files while viewing hidden files).
If that is not the case than you can use some good recovery tool i.e. MiniTool Power Data Recovery, Getdata Recover My Files. It is still possible that you might lost some files even after using recovery tool.
If that also don't work than try to contact Toshiba/WD customer care and ask them if they provide any facility for recovering data. They sure can get your data because they can go to very lower level of your drive.
Thank you Pranav for your response
but the hidden files are not the case, in fact i always show the hidden system files
and for the recovery tool, i didn't try this yet, but it might work, still needs new storage to try to restore to it...
what about fixing this as is
and what about the other people that says they found it was detected and were able to read it after 20 minutes and by the way, i found this mentioned in about 5 posts till now .. doesn't this make u question .. what is wrong
There is no doubt in my mind that WebOs is faulty and so many people are facing problems regarding HDD either of detection problem or corruption problem.
The read time is depended on how much files you have in your hard drive for example if you have 10,000 pictures total of 1GB size and one HDD with only one 1GB file than HDD contains pictures will take longer than HDD contains only single file. I don't know why but TV it is not working like PCs in HDD detection (I am not expert on this but I am telling you this by my personal experience)
And yes you need some extra space to recover your files; a big problem in your case because if I am not wrong you might have more than 1.5TB of data from both HDD together
Ooh dear Pranav .. both are nearly full, plus im checking the option to compress the files to save the disk space, so they may have more than 2 TBs of data
thanks alot
please if someone is expert or have something that could be of help
I was also facing the same issue with my 1TB Seagate HDD. Surprisingly, the device got detected in more than 20 minutes. Looks like LG WebOS is sluggish in terms of reading and detecting a large sized HDD.
Can someone from WebOS team help fix this and make it faster?
Even I too had this problem of late/failed detection of my Seagate 1 TB HDD on my LG TV webOS 2.0.
HDD works fine when connected to my laptop(NTFS format) . I checked my HDD content and found that there were some files created with name "ntfschk....."  on root folder of HDD(i dont remember creating them). I deleted them and connected back to TV and it is working smoothly. :D
Hope this helps some of you.
Hello Everyone ..
let me describe my experience in this subject
1- how fast the HDD is read on the TV is relative to the a. Content Types, b. Folder Structure, c. amount of data
           My HDD had mixed content, and very deep folder structure, I'm talking about the daily usage of Personal and Business staff, documents, programs, pictures, movies, music, games, downloads, ... etc., this is how I've been using it, and wanted to play the movies on the TV
currently now I turn on the TV, attach the HDD, and do whatever for about 10-20 mins, while its being read and appear in the SmartShare app.
2- I've attached other HDDs that has only Movies on it, and/or has some other few content types but not large amount, and it worked in a flash, just plug it in and pooof it is on the SmartShare
3- @Rajc123, these "ntfschk....." folders you deleted:
    a- they are there - most probably - because you have plugged then unplugged your HDD before being read probably, unplugged the HDD with the TV Turned on, which is a very serious mistake that threatening you will loose your precious data on the HDD
    b- Do Not Delete Them Again before you explore their content and make sure that they are Really Empty or has data you don't need anymore, in my case they always had pictures, documents, or files from various location on the HDD, like one time i found a folder of my brother's images, which originally was on the Family Photos Folder ...
    c- How did they get to this folder?? honestly i don't know ... but I do know that the folder named "ntfschk...." is being created when the HDD is being checked and contains like the fragmented files on the disk ...
4- the correct way to use the HDD on the TV is:
     a. Attach the HDD, doesn't matter the TV is on or off
     b. Wait .. Wait ... Be Patient, Wait until you are sure it is working and appear in the smart share or whatever application you are intended to use.
     c. to unplug the HDD, Turn off the TV, and wait until the light indicator is off, or you are sure that it is stopped.
     d. even if it wasn't yet appeared on the TV, Turn off the TV before unplugging the HDD
      Company Continues to Strengthen Its Industry Leadership With
      Advanced Commercial Display Technologies and Customized Solutions
      SEOUL, Feb. 4, 2025 — LG Electronics (LG) is unveiling its latest digital signage innovations at Integrated Systems Europe (ISE) 2025, taking place in Barcelona, Spain, from February 4-7. LG’s exhibition booth, themed “Customized Solutions, Optimized Growth,” features dedicated zones for business sectors including retail, corporate, education, transportation and hospitality. The tailored display solutions on show leverage the company’s state-of-the-art technologies to meet the diverse needs of B2B clients and enhance and expand the customer experience.
      Presenting Elevated Visual-spatial Experiences with LG’s AI-powered Kinetic LED
      LG is set to capture the attention of ISE visitors with its gigantic “shape-shifting” Kinetic LED display. Installed at the entrance of the company’s exhibition booth, the Kinetic LED employs cutting-edge AI technology to enthrall, entertain and amaze. The impressive screen, composed of 88 connected LED panels, measures 7,180 x 4,090 millimeters. Combining LEDs and mirrors, the cube-shaped modules that make up the Kinetic LED can rotate 360 degrees horizontally to create dynamic and mesmerizing movements.
      Visitors to LG’s booth can also enjoy an AI-powered “image transformation” experience with the Kinetic LED. After they’ve taken a photo with their smartphone and uploaded it via scanning the provided QR code, their picture is transformed by LG’s generative AI into a Pop Art-style image, which is then displayed on the Kinetic LED. This fun, interactive feature, developed by LG and its Kinetic solution partner, Easywith, serves as an engaging advertising solution that invites direct participation from audiences.
      In addition to the captivating Kinetic LED, LG is showcasing a wide range of advanced technologies developed in collaboration with its domestic (South Korean) and global partners. Among LG’s key partners are Triplet, an AI-driven customer behavior analytics company; Kokomo 24/7, a firm specializing in school access management and emergency response solutions; and companies such as Megapixel VR, Mo-Sys Engineering and Brompton Technology – industry leaders in the areas of broadcast equipment and virtual production. LG is also teaming up with corporate video conferencing solutions providers Logitech, Cisco and Crestron, and signage-specific content management solutions provider, BrightSign, to demonstrate the latest innovations in collaboration technology.
      Upgraded LG MAGNIT Micro LED Displays to Meet Growing B2B Demand for Ultra-High-Definition Screen Solutions
      LG has upgraded its acclaimed LG MAGNIT micro LED displays to improve ease of installation, content compatibility and energy efficiency. Thanks to a new design, installers can now adjust the spaces between LED modules from the rear of the display; a task that could only be performed from the front on previous models. Additionally, compatibility with content controllers has been enhanced to ensure optimal colors and image quality, while standby power consumption has been reduced by up to 98 percent compared to earlier models, significantly improving overall energy efficiency. LG’s latest innovations in micro LED technology, including the newest MAGNIT solutions, can be found in the dedicated LED Tech Zone.
      Introducing LG’s High-Brightness Outdoor Signage with Anti-Discoloration
      At ISE 2025, LG is debuting its high-brightness outdoor signage solutions featuring the company’s own Anti-Discoloration technology. On show to the public for the first time, this advanced tech helps to protect LG’s high-brightness signage for outdoor spaces against the negative impacts of screen-yellowing – a common issue caused by prolonged exposure to direct sunlight.
      In 2024, LG’s Anti-Discoloration technology became the first solution of its kind to receive verification from Underwriters Laboratories (UL), the globally respected standards and testing organization. To highlight its impressive lineup of customized displays with yellowing-resistant tech, LG has set up a number of simulated outdoor environments within its ISE booth, such as a bus stop, sports stadium and a drive-thru restaurant.
      Comprehensive Display Solutions for Retail: From Customizable Kiosks to Fire-Safe Digital Signages with Flame-Resistant Casing
      In the Retail Zone of LG’s ISE booth, visitors can explore a comprehensive selection of solutions tailored for retail environments. The display includes LG’s versatile and easy-to-install second-generation modular kiosks, as well as three digital signage models (US5P, UV5N and UP5Q) that feature outer casings certified to meet stringent international fire safety standards (BS476 in the UK and EN13501-1 in the EU).*
      LG’s booth also features the full lineup of LG CreateBoard solutions tailored for both educational and corporate settings. The lineup consists of three models: LG CreateBoard Pro, LG CreateBoard and LG CreateBoard Core, each designed to cater to a variety of user requirements. The LG CreateBoard Pro stands out as the premium model, offering advanced features for enhanced performance, while the LG CreateBoard Core delivers essential functionality in a cost-effective package.
      Additionally, LG is putting the spotlight on LG Business Cloud, an online platform enabling the convenient, centralized management and operation of the company’s commercial displays. Collectively, the innovations on display at ISE 2025 emphasize LG’s commitment to technological excellence and its dedication to delivering innovative solutions that empower businesses and enhance user experiences.
      “LG is committed to providing commercial display solutions tailored to the specific needs of diverse business environments,” said Park Hyoung-sei, president of the LG Media Entertainment Solution Company. “As a leader in the B2B market, our goal is to deliver innovative solutions that elevate the value of commercial, public and educational spaces, while also enabling transformative customer experiences and supporting the growth and success of our clients.”
      * Tested for flame spread and fire resistance by global testing organizations SGS and TÜV Rheinland, with certifications covering a total of 22 LG digital signage models.
      Discover a World of Art on LG Smart TVs With Artlume’s Rich Collection of
      15,000 Artworks, From Iconic Classics to Unique AI Creations
      SEOUL, Nov. 28, 2024 — LG Electronics (LG) has announced a new partnership with Artlume, a pioneering digital art and AI platform, to bring inspiring art experiences to the comfort of home through LG Smart TVs. LG TV owners will be the first to enjoy this extensive catalogue on the big screen. With a shared vision to make art accessible at scale, this new collaboration transforms over 200 million LG Smart TVs worldwide into virtual art galleries, offering a broad selection of artworks that enrich the ambiance of living spaces.
      Available globally on LG TVs running webOS 6.0 (2020 TV models) and above, Artlume’s expansive collection includes classic masterpieces, contemporary photography, AI art and works from renowned institutions like the National Portrait Gallery in London and the Ashmolean Museum. With over 15,000 artworks available to explore and stream, users can curate personalized playlists via the mobile app to display their favorite art on their LG Smart TVs.
      Artlume’s user-friendly features allow instant changes to displayed artworks for enhanced creative control. The platform also integrates AI art generation, empowering users to create and publish unique art with simple word prompts, which can then be proudly shared through the screen.
      “LG is the perfect partner for us, aligned with our goal to bring love, beauty and passion to people’s lives through the universal language of art,” said Patrick Ashworth, founder & CEO of Artlume. “We are committed to leaving a profound positive impact on humanity by educating future generations, supporting mental health through the beauty of art, and sharing museum art with the world.”
      “LG is dedicated to transforming how people experience art,” said Chris Jo, senior vice president of platform business at LG Media Entertainment Solution Company. “Through this partnership with Artlume, we are bringing a wide array of incredible art to LG Smart TVs, enriching living spaces.”
      As LG expands its collaborations with leading partners in the arts segment, users are invited to explore a diverse range of artistic expressions from around the globe, all from the comfort of home.
      Revolutionary Vision Display, Intelligent HMI and Connectivity & Content Solutions
      Redefine the Smart Mobility Experience
      SEOUL, Nov. 11, 2024 — LG Electronics (LG) is introducing the Digital Cockpit gamma, the latest addition to its Mobility Labworks Series, which showcases advanced technology concepts for the automotive industry. This new model is the third in the series, following the introduction of the alpha and beta models last year.
      The Digital Cockpit gamma is equipped with LG’s most sophisticated vehicle technologies and features three modular solutions: the Vision Display, Intelligent Human-Machine Interface (HMI) and Connectivity & Content. These modular systems offer significant customization options within the vehicle cabin, allowing automakers to tailor features to meet the specific requirements of each design. For end-users, the Digital Cockpit gamma delivers superior convenience and seamless connectivity, revolutionizing in-car entertainment, communications, and driver assistance systems. This innovation provides a compelling glimpse into the exciting future of mobility.
      Vision Display: Shaping the Future of Automotive Interiors
      Presenting a range of new possibilities for future automotive interiors, the Vision Display solution is designed to adapt seamlessly to dynamic environments. Its 12.3-inch Transparent OLED screen offers key data to inform and entertain passengers during autonomous driving, displaying real-time navigation, current speed and points of interest (POI). LG’s solution also features a 14.2-inch roll-in-and-out Plastic OLED (P-OLED) display embedded in the center console, which can be retracted when not in use, maintaining a clean and minimalist cabin space.
      Intelligent HMI Solution: Intuitive AI-Driven User-Vehicle Interaction
      The Intelligent HMI solution leverages AI and responsive touch technology to provide easy, intuitive user-vehicle interactions. A key feature is the adaptive controller, a touch-sensitive curved OLED display integrated into the steering wheel, allowing drivers to effortlessly manage navigation, multimedia and climate-control settings, complete with haptic feedback for a more tactile experience.
      In autonomous driving mode, the adaptive controller can make the journey more enjoyable by providing access to entertainment apps and games. Furthermore, LG’s AI-based virtual assistant offers smart support for various situations. For example, if it detects driver fatigue, it can order a coffee from a nearby location and facilitate quick payment via the screen’s built-in fingerprint-recognition sensor. The Intelligent HMI solution also supports the Advanced Television Systems Committee (ATSC) 3.0 standard, enabling system updates and real-time emergency alerts without requiring a network connection.
      Connectivity & Content Solution for Seamless Entertainment and Smart Mobility
      The Connectivity & Content solution transforms the rear passenger seats into an interactive entertainment hub, enhancing in-car experiences through 5G network connectivity and LG’s webOS platform. Passengers can stream high-definition content, access live broadcasts, interact with POI data, share their screen via the in-car screen-mirroring feature, and navigate content and control volume using hand gestures. Supporting a number of different ride-sharing apps, the webOS-based Connectivity & Content also represents a convenient solution for owner-drivers.
      “Digital Cockpit gamma demonstrates LG’s leadership in cutting-edge in-vehicle innovations and our dedication to creating working concepts of transformative technologies for future commercialization in the automotive industry,” said Eun Seok-hyun, president of LG Vehicle component Solutions Company. “We will continue to provide customizable vehicle solutions that enhance the in-car experience, ensuring seamless connectivity and a smarter, safer on-road environment.”
      To explore the futuristic innovations featured in the Mobility Labworks Series, visit
      Companies to Offer Comprehensive Package of Digital Office Solutions and Services
      Designed to Boost Productivity and Deliver Better User Experiences
      SEOUL, Sep. 19, 2024 — LG Electronics (LG) has signed a memorandum of understanding (MOU) with
      link hidden, please login to view, a global leader in workplace solutions, to collaborate on digital transformation solutions for modern office environments. The two companies will jointly drive sales and marketing activities for their collaborative efforts and will look to explore further business opportunities in the future. This strategic partnership is expected to strengthen LG’s position in the global B2B market. Ricoh, headquartered in Tokyo, Japan, and with locations in approximately 200 countries worldwide, supports the hybrid workforces of its customers across the globe through a broad range of solutions, from managed workplace services to document management and intelligence process automation, in addition to printers and copiers. As part of the new agreement, Ricoh will pair select offerings with LG’s premium digital signage products and various other B2B solutions. The combination of products and services from two of the industry’s most respected names will deliver an elevated user experience and exceptional customer value.
      According to a conducted by Market Research Future, a leading market research company based in India, the global digital workplace solutions market is expected to grow from about USD 33.7 billion in 2023 to USD 90.5 billion by 2030, with a compound annual growth rate (CAGR) of 15 percent. LG, which has identified the B2B sector as a key driver of business growth, aims to expand its presence within the sector and to increase its B2B sales to around 45 percent of total sales (from all business divisions) by 2030. The company is continuously expanding its B2B portfolio and is highly proactive in exploring new, high-potential business areas.
      “This global strategic partnership allows us to combine LG’s advanced displays with Ricoh’s communication services, delivering enhanced workplace experience solutions to customers,” said Takahiro Irisa, senior corporate officer and president of the Ricoh Digital Services Business Unit at Ricoh Company, Ltd.
      “The pairing of Ricoh’s workplace solutions with LG’s advanced display products will deliver impressive value to customers and further establish LG as one of the most trusted providers of integrated solutions in the B2B market,” said Paik Ki-mun, senior vice president and head of the Information Display business unit of LG Business Solutions Company. “LG will continue to pursue strategic partnerships with innovative global companies to create customized solutions for today’s business environment.”
      For more information, visit .
      Company’s Latest Innovation Provides Enhanced Protection Against Screen-Yellowing
      for Digital Signage Used in Outdoor Environments
      SEOUL, Aug. 1, 2024 — LG Electronics (LG) is introducing its advanced Anti-Discoloration technology for outdoor digital signage. Verified by respected standards and testing organization, UL Solutions, LG’s new tech helps prevent ‘screen-yellowing,’ a common issue for outdoor digital signage products caused by prolonged exposure to sunlight. This innovative tech simultaneously safeguards display quality and performance stability, ultimately helping extend the lifespan of LG digital signage used in outdoor environments.
      LG is the first company to achieve UL verification for the display anti-discoloration characteristic technology for digital signage. LG developed a comprehensive testing methodology and defect-evaluation criteria, and UL Solutions independently assessed the product to the criteria in support of LG’s marketing claim. Prior to this, there were no internationally recognized standards or testing methods for measuring a display’s resistance to screen-yellowing.
      The use of outdoor displays in settings such as drive-thru restaurants, bus stops, schools and sports stadiums has become commonplace in recent years and is steadily increasing across a variety of B2B sectors. However, prolonged exposure to sunlight can cause the screens of these versatile display products to turn a yellowish color over time. LG’s Anti-Discoloration technology helps address this issue, reinforcing the quality and durability of the company’s outdoor digital signage solutions.
      LG developed its protective technology to provide better value to B2B customers utilizing digital signage in outdoor environments. The company’s research indicated that customers were having to replace their outdoor signage products at a faster rate and experiencing service interruptions due to persistent discoloration issues. To address these pain points, LG’s outdoor displays with Anti-Discoloration technology also incorporate advanced thermal solutions and panel materials for added reliability, even in the toughest of conditions. UL Verified product incorporating Anti-Discoloration technology has already been implemented in several of the latest LG high-brightness outdoor signage products, with plans to expand its application to a wider range of solutions in the future.
      “Our UL Verification of products with Anti-Discoloration technology actively reinforces the performance and quality of our digital signage products,” said Paik Ki-mun, senior vice president and head of the Information Display business unit of LG Business Solutions Company. “Through targeted research and development programs, we will continue to identify and resolve any inconveniences that detract from the overall LG digital signage experience, thereby continuously enhancing customer satisfaction and trust.”
      To learn more about LG’s digital signage solutions with Anti-Discoloration technology, please visit
