I wish there was one.
Keyboards
Works
  • link hidden, please login to view
    works on an LG 3D 4K TV UB8500
  • Wireless Keyboard  works on TV LB670V.
Don't Work
 does not work on an an LG 3D 4K TV UB8500
Webcams
Works
Don't Work
does not work on an LG 3D 4K TV UB8500
  • 4 months later...
    • By Evelynn
    • By matesz
    • By dolbnya
    • By odesanmi kolade
      I have been trying to downloading Aptoide TV on my LG smart Tv but keep showing File downloading not supported.. My goal is how I can get zoom conference app running on my Smart Tv. Please help!!!
    • By Cpetro
      Application like Crunchyroll and Viki are not supported in webOS.
      Can they be added? Or at least accessible from the browser.
