There’s been a lot of big news in the last week, so time for a quick clean out!
  • Some app updates went through HP’s admin last week. We know there are a couple more in the pipeline. Thanks to all the developers still supporting webOS. Expect reviews soon on pivotCE.
  • Platform game,
    has new levels. See the pivotCE article .
  • is a must for earthquake… er fans?
  • let’s you share photos and slideshows across the wifi network. Why hand your phone around when you can beam to a bigger screen?
  • is an assistant for messaging, posting & tweeting. Expand words, add emoticons, pics, videos, shorten links, even translate! Is there a news crumbs mode? Maybe in the next update.
  • LG posted photos of . Owners of webOS TVs eagerly await the results of their efforts.
  • Meanwhile we were concerned to hear that two of the top designers had . Will this affect the progress of webOS? We hope not.
  • Further disappointment came from , claiming that all is not well in . Some disputed the fairness on twitter and . Have a read and decide for yourself.
I hope you enjoyed that, I fancy a nice to go with my .
    • By Charlie F
      Charlie
    • By DeeDeee
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
