[pivotCE] Official Release of LuneOS and Project Updates
By Sqwazy
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
Company’s Industry-Leading LG UltraGear Gaming Monitors to Support the World’s
Top Pros at Global Festival of Esports in Riyadh
SEOUL, June 26, 2024 — LG Electronics (LG) has been announced as the official partner of the Esports World Cup (EWC) 2024, set to take place in Riyadh, Saudi Arabia, from July 3 to August 25. Formerly known as Gamers8, EWC is an annual international esports tournament. This year’s edition – the first under the EWC name – will host competitions for 21 of the world’s biggest online games, including League of Legends, Overwatch and Fortnite. The exclusive gaming monitor of the event for the third consecutive year, the LG UltraGear will take center stage at EWC 2024, supporting the world’s top gamers as they battle for victory in Riyadh.
Boasting the largest prize pool of any esports tournament, EWC 2024 promises eight weeks of thrilling gaming action, featuring over 1,500 professional athletes. The acclaimed LG UltraGear OLED gaming monitor (model 32GS95UE) will be prominently featured at the event. Additionally, more than 990 UltraGear gaming monitors will be utilized during league matches and showcased at LG’s booth at EWC.
LG UltraGear, the company’s premium gaming brand, provides next-level gaming experiences for both professional athletes and amateur enthusiasts alike. These gaming monitors offer high refresh rates, rapid response times, and vibrant, crystal-clear images; a combination that drives gaming immersion to dizzying new heights.
Along with its premium self-lit screen, the 32-inch LG UltraGear OLED gaming monitor (model 32GS95UE) features the world’s first VESA-certified dual-mode technology, ensuring an optimized gaming experience at both UHD 240Hz (ideal for visually stunning, narrative-rich games) and FHD 480Hz (a great choice for fast-paced FPS, MOBA and racing titles). It also incorporates LG’s Pixel Sound technology for more realistic and three-dimensional in-game audio.
LG’s involvement in EWC 2024 is part of the company’s ongoing efforts to advance esports worldwide. In addition to EWC and its predecessor, Gamers8, LG sponsors and actively participates in major gaming competitions such as the League of Legends Champions Korea and the League of Legends EMEA. Through consistent engagement with the gaming community and the exceptional performance and features of its UltraGear gaming monitors, LG has become a respected name in the world of esports.
EWC 2024 attendees can visit LG’s booth to try out the same UltraGear gaming monitors used by their gaming idols throughout the tournament. They can also improve their own gaming skills by taking part in coaching sessions run by the LG-sponsored Gen.G Global Academy. Furthermore, visitors to LG’s booth can win prizes by participating in exciting competitions and events.
“Saudi Arabia’s premier esports festival, EWC is the new destination for esports fans,” said Mohammed Al Nimer, Sales Director at EWCF. “We’re excited to work with partners like LG, who share our passion for gaming and esports-culture, and to have LG UltraGear as the official gaming monitor of the inaugural EWC.”
“It’s a real honor for LG UltraGear to be named the official gaming monitor brand of an esports event as momentous as EWC 2024,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “Designed to satisfy the needs of both professional and casual gamers, LG UltraGear OLED gaming monitors are tailor-made for next-level gaming experiences.”
For more information about EWC 2024 and the latest LG UltraGear gaming monitors, check out and follow LG UltraGear (
link hidden, please login to view). # # #
By pivotCE
link hidden, please login to view hold a number of events. This year’s will be of interest to fans of webOS phones, tablets and other computing devices of the past. The festival is held at the and runs over three days from the 12th to 14th of April. The festival includes three elements:
– some with modifications to function in the modern environment. and . . For readers of this blog, representation of webOS devices will be in two of those areas. Jon W of the is attending over the weekend and will give a 50 minute talk at 900am on Saturday the 13th. The consignment shop will have a small selection of webOS devices for those who are interested.
So if you are in the area, why not go along?
If you can’t make it, you can follow along via the and TouchPads are available remotely at
Discussion is at the . You can read more .
Picture Credit: .
