[pivotCE] TIP: preware.net solutions for WOSQI, Preware v1.9.13
You may have heard that
away from webOS Internals yesterday.  If not, what the heck?  You live under a rock?  I digress.
Long story short, preware.net is now the new home for all things Preware to include our beloved patches, homebrew apps, etc.  Don’t bother copying and pasting that as a link because until the ducks are lined up there won’t be much to see.  I’ve been assured that the app and get.preware.net will all be updated in the near future.  Come on.  This stuff takes some time.  Relax.
So this domain snatching business was pretty ugly.  Turns out “preware” means something very different to the folks that grabbed the domain and they have no intention of selling it back to webOS Internals which was the initial assumption.  No, in fact they plan to use it for whatever “preware” means to them.  Like you, I am waiting with bated breath for the answer to that mind boggling riddle. :|
But now that preware.net exists and more importantly, ipkg.preware.net, the home of patches, apps, etc., how do you fix your broken and Preware that point to preware.org?
Fix WOSQI
You’ve got a couple options here.  Until an official version bump is released you’re going to have to settle for some workarounds.  The good news is they are relatively simple.  The bad news is you’ll have to do more than just download a file.  What?  Work?  I know.  Sorry.
UPDATE: Jason Robitaille, creator of webOS Quick Install, has merged the commits by pattyland. He has not yet answered the question as to whether we can expect an updated build on the main WOSQI thread on webOS Nation Forums, however, pattyland went ahead and built a new version of WOSQI.  It is UNOFFICIAL! You can .
Option #1 – Edit your computer’s hosts file
This is probably not the simplest solution but it’s a solution nonetheless.  And I’m going to give you folks the Windows answer. Mac and Linux users, I assume you already know what you’re doing. Nerds. ;)
Hit the Windows key on your keyboard.  start_keyboard_windows_key
Type notepad.  Don’t open Notepad, right click on it and click Run as administrator.  Click yes on the box that appears or type in your admin password and hit yes.
In notepad, click File > Open and browse to C:/windows/system32/drivers/etc/. Change Text Documents (*.txt) to All Files (*.*).  Then click hosts and open.
Add 140.211.169.161 ipkg.preware.org like you see in the screenshot. Click File > Save and then close Notepad.  Now open WOSQI and all should be swell.
Note: If you go this route, you’ll have to do it for every computer you use WOSQI on.  You could also edit the hosts file on your webOS device(s) too found in /etc/hosts BUT same deal, every device and it does not survive a doctor.
Option #2 – Replace PackageFeed.class in WOSQI .jar
I thought I would go into a step by step detail about how to modify PackageFeed.class inside WOSQI’s .jar file here but instead I modified it for you and all you have to do is drop the file in place.  , open the PackageFeed.zip, and extract the PacakgeFeed.class file to your Desktop.  And then do this:
1. Get and install it. Run the .exe or the .msi and “next next next finish” yourself until it’s done. You can also use whatever compression tool you like.2. Find where you store WebOSQuickInstall-4.5.0.jar on your computer. Right click on it and choose 7-Zip > Open archive or Open with > 7-Zip File Manager
3. Navigate to .cacanucksoftwareipkg (see image). Find the PackageFeed.class file you downloaded and drag it into the 7-Zip window and click Yes when it asks you if you want to copy files to the archive.
4. Close 7-Zip and open WOSQI.  Ta-da!
UPDATE: I removed Option #2 for the WOSQI fix because for whatever reason I could not get the fix to duplicate on another computer.  Also, a couple nice folks pointed out their frustration with the fix since they couldn’t get it to work either. Must have been a fluke.  The good news is, the correct changes have been made to the  but will have to be accepted first. Hopefully, Mr. Jason Robitaille builds the updated WOSQI and adds it .
Preware
Preware’s version was bumped yesterday to 1.9.13.  It fixes the .org problem and also the birthday icon which never got updated after last year’s Preware birthday.  Anyway, to get Preware going again you have a few options.
Option #1 – If you jumped down here because fixing WOSQI seemed annoying…well, you can skip to here but IF you fix WOSQI first all you have to do to get the updated Preware that fixes all the old .org feeds to the new .net ones is click the globe, search for Preware, and install it.
Option #2 – Uninstall Preware on your webOS device first.  On your PC grab the .ipk , plug your phone or TouchPad into your PC, open your broken WOSQI, drag the .ipk into the WOSQI window and click Install. Done. Now scroll up and fix WOSQI.
Option #3 – On your webOS device copy this URL http://ipkg.preware.net/feeds/webos-internals/armv7/org.webosinternals.preware_1.9.13_arm.ipk, open Preware, immediately swipe down for the menu and tap Install Package, paste the copied URL into the File box and click Install. Preware will close. Reopen it and you’re good to go.
Note: When I first fixed Preware I had old beta feeds added and some of them didn’t auto-update to the .net address.  To remedy the situation I uninstalled the new Preware, removed the beta feeds, readded the beta feeds, and reinstalled Preware.  Problem solved.
Well there you have it. Good luck!
#webosforever
      LG has once again left a lasting impression on visitors to ISH, one of the world’s biggest annual tradeshows for HVAC, water and sanitation solutions. Held in Frankfurt, Germany, the event highlighted LG’s extensive range of integrated heating solutions customized for diverse environments and spaces, including high-efficiency residential heat pumps and large-capacity commercial systems. Tailormade for the European market and compliant with the European Union’s F-gas Regulation, LG’s products exclusively employ refrigerants with a low Global Warming Potential (GWP).
      A major attraction at LG’s booth, the Hero zone introduced ISH visitors to the exceptional Therma V R290 Monobloc air-to-water heat pump (AWHP) for residential applications. Displayed beneath a captivating hanging façade at the center of the zone, the new Therma V boasts a sleek, minimalist design, quiet operation and outstanding cold-climate performance, thanks to LG’s advanced scroll compressor. Designed with user comfort and the health of the planet in mind, the Therma V employs R290 refrigerant, which has a GWP of 3, to reduce carbon emissions.
      LG also showcased the Monobloc G and Cascade Control Unit, two sophisticated solutions suitable for multi-unit apartment buildings and large homes. The Cascade Control Unit offers flexible scalability, allowing users to add up to eight outdoor units to their HVAC system. This adaptability not only meets varying heating demands but also optimizes energy efficiency, thereby contributing to the reduction of HVAC running costs.
      Another notable exhibit was the new LG heat pump water heater (HPWH) with R290 refrigerant. Displayed in a booth area designed to resemble a stylish European kitchen, the versatile HPWH R290 utilizes both air and electricity as energy sources, achieving greater efficiency than traditional electric or a gas-powered water heaters. Its simple design ensures compatibility with various installation environments and customer needs, offering seamless integration with various types of indoor units, such as control, hydro and combi.
      In response to recent EU restrictions on refrigerant usage, LG has launched a complete lineup of reliable commercial HVAC solutions utilizing R32 refrigerant (GWP of 675). Visitors learned about the innovative, large-capacity Inverter Scroll Chiller, which leverages twin inverter scroll compressors to maximize cooling power and operational efficiency. The Inverter Scroll Chiller can be integrated with LG’s Building Energy Control (BECON) CPM system, which utilizes advanced AI technologies to simplify control and monitoring of LG’s commercial HVAC solutions.
      The Multi V i R32 variable refrigerant flow (VRF) solution was another attraction at LG’s booth. Incorporating the company’s AI engine, the Multi V i intelligently manages temperatures across multiple indoor spaces. This VRF solution includes a full package of integrated solutions, including a number of safety features and systems designed to enhance stability and reliability, and provides time-saving troubleshooting assistance with Smart Diagnosis.
      LG, a pathfinder for innovative heating, has been at the forefront of HVAC innovation for several decades and continues to show the way forward. With its comprehensive exhibit of efficient and sustainable HVAC solutions at ISH 2025, the company reaffirmed its commitment to decarbonization and to paving the way to a better future for all.
      Company Offers Extensive Range of High-efficiency Heating Solutions for
      Diverse Residential and Commercial Needs
      SEOUL, March 17, 2025 — LG Electronics (LG) is presenting its latest heating, ventilation and air conditioning (HVAC) solutions tailored for the European market at the International Trade Fair for Sanitation, Heating and Air (ISH) 2025, taking place in Frankfurt, Germany, from March 17-21. LG’s showcase features high-efficiency solutions optimized for both commercial and residential spaces, including the large-capacity Monobloc G Air-to-Water Heat Pump (AWHP). The comprehensive exhibit underscores the company’s commitment to electrification and decarbonization, as well as its focus on providing first-class performance, flexibility and ease-of-installation.
      Enhanced Energy Efficiency and Advanced Heating with the New Therma V R290
      Located at the entrance of LG’s exhibition booth, the Hero zone introduces visitors to the new Therma V R290 Monobloc. This impressive residential solution boasts excellent energy efficiency and a premium European design. Winner of a 2024 International Design Excellence Award and rated “Good” by the German consumer organization Stiftung Warentest, the new Therma V utilizes R290 refrigerant, which has a low Global Warming Potential of 3. Designed to reduce energy usage and environmental impact, LG’s solution harnesses heat from the air to reduce carbon emissions and achieve an A+++ energy rating.1
      Made to withstand Europe’s tough winter conditions, the new Therma V AWHP leverages LG’s proprietary scroll compressor to deliver exceptional energy efficiency and a strong, reliable performance. The positioning of the compressor at a lower-than-usual height within the unit itself contributes to the Therma V’s ability to function at 100 percent capacity, even at temperatures as low as minus 15 degrees Celsius. It also leads to improved energy savings and operational stability. With a noise level of just 50 A-weighted decibels in Low Noise Mode, the Therma V produces minimal vibrations, helping to create a relaxing and peaceful environment both inside and outside the home.2
      In the multi-residential and large-scale housing zone, LG is presenting the Monobloc G large capacity AWHP and the Cascade Control Unit. The energy-efficient Cascade system offers flexible scalability, allowing the addition of up to eight units to cope with increased heating demand. The Cascade provides multiple benefits for multi-family dwellings, including low-noise operation, a space-saving design and continuous operation via backup systems.
      Efficient Heating and Cooling Solutions for Modern Homes and Multi-Residential Buildings
      LG’s ISH exhibition includes a variety of residential heating solutions that have been purpose-built for European kitchens, laundry rooms and living areas. The company’s latest Heat Pump Water Heaters (HPWH) with R290 refrigerant, which use electricity as well as energy from the air to heat water, offer higher efficiency than conventional electric or gas water heaters. Smart Grid ready, HPWHs can enhance energy efficiency by adjusting operation in response to electricity demand signals. Furthermore, to maximize suitability for a wider range of installation environments, LG’s water heaters are available in both floor-standing and wall-mounted types.
      The new DUALCOOL AI Air with AI DUAL Inverter provides optimized air conditioning by detecting the ambient temperature of a space and intelligently adjusting the set temperature and airflow direction and speed. The company offers three different DUALCOOL AI AIR indoor units with R290 refrigerant to suit any home, with each variant offering easy installation and maximum space efficiency.
      Advanced Commercial HVAC Solutions for Effective Energy Management
      Additionally, LG is introducing a range of cutting-edge commercial heating solutions at ISH. A standout among these is the LG Inverter Scroll Chiller – an energy-efficient system for heating (and cooling) commercial facilities. Equipped with twin inverter scroll compressors and plate-type heat exchangers, the LG Inverter Scroll Chiller offers a wide operating frequency range and excellent heat transfer efficiency. When integrated with LG’s Building Energy Control (BECON) CPM system, the chiller provides seamless control of all connected fan coil units and air conditioning systems. BECON CPM monitors and adjusts various control elements to maintain peak efficiency and allows users to track system status in real time. It even sends users helpful alerts if an issue arises, so that appropriate action can be taken to quickly remedy the situation. Set to launch in Europe, BECON CPM also employs LG’s advanced AI-based technology to prevent energy waste and to simplify control for system managers.
      One of the many highlights of LG’s booth is the R32 Variable Refrigerant Flow (VRF)-based integrated solution package. The LG Multi V i, an all-electric VRF solution, intelligently manages performance according to environmental changes and helps prevent unnecessary energy consumption. When connected to the Hydro Kit, the Multi V i supports floor heating and hot water supply while its compatibility with Air Handling Unit applications from various companies enables it to serve large warehouses and other specialized business-to-business environments. Along with exceptional scalability, the company’s all-electric system offers efficient management with convenient Smart Control features. Powered by LG’s advanced AI Engine, these features analyze the operational data of the Multi V i to improve indoor comfort and create significant energy savings.
      Also at ISH 2025, LG is introducing the LG All Stars program: a rewards program for HVAC installers that offers exclusive benefits, educational opportunities, continuous support and the chance to be a part of a growing professional network. Accessible via the LG All Stars app, the All Stars program lets users take advantage of the BECON Cloud maintenance service, which ensures fast and accurate issue diagnosis and allows the remote monitoring of connected heating systems from any location.
      “The groundbreaking LG residential and commercial HVAC solutions on show at ISH 2025 demonstrate our commitment to delivering energy-efficient, high-performance heating systems for the European market,” said James Lee, president of the LG ES Company. “As a key player in the global shift towards electrification, and a trusted provider of advanced HVAC solutions, LG will continue to pursue innovation that maximizes customer value while minimizing environmental impact.”
      Visitors to ISH 2025 can experience the latest LG HVAC solutions at the company’s exhibition booth (E69, 12.1 Hall, Messe Frankfurt).
      1 Seasonal space heating efficiency rating of A+++ at 35 degrees Celsius LWT and A+++ at 55 degrees Celsius LWT, in accordance with EN 14825 in the European Commission Regulation (EU).
      2 The sound power level of 50 decibels A at 9 kilowatts in Low Noise Mode was measured in accordance with EN 12102-1 and ISO 9614 under an outdoor air temperature of 2 degrees Celsius. This mode reduces noise by limiting the compressor frequency and fan speed, which may affect performance.
      Company Presents Expanded Range of Solutions for Home Design and
      Residential Builder Markets at Major Industry Tradeshows in Las Vegas
      SEOUL, Feb. 25, 2025 — LG Electronics (LG) is showcasing its cutting-edge residential space solutions at the 2025 Kitchen and Bath Industry Show (KBIS) and 2025 International Builders’ Show (IBS), both taking place in Las Vegas from February 25-27.
      As a regular exhibitor at KBIS and a first-time participant at IBS – the world’s largest annual B2B construction tradeshow – LG introduces a range of innovative products and solutions designed to meet the evolving needs of home designers and builders in the American market. Aligned with America’s latest lifestyle and housing trends, LG’s offerings combine thoughtful design with cutting-edge technologies.
      At KBIS 2025, LG is set to captivate and inspire attendees with its rebranded SKS (SIGNATURE KITCHEN SUITE) ultra-premium built-in kitchen solutions. Visitors will experience the passion and authenticity behind SKS’s True to Food philosophy through the brand’s latest innovations, including the SKS 36-inch Cook-zone-free Induction Pro Range and the revolutionary Island System concept.
      Executive Chef Nick Ritchie, from the SKS Experience & Design Center in Napa Valley, Calif., will host live culinary demonstrations featuring the SKS Pro Range and Combi Wall Oven. These cutting-edge appliances feature Gourmet AI, which analyzes available ingredients and suggests optimal recipes and cooking modes for an elevated cooking experience.
      The SKS showcase will also highlight “Technicurean” concept kitchens – where culinary expertise meets advanced technology. Designed for different facets of the Technicurean lifestyle, these kitchens seamlessly integrate SKS’s latest innovations, including the 24-inch column wine cellar with LG ThinQ-enabled wine curation and the stylish SKS Transitional package.
      Maximizing Space, Energy Efficiency and Everyday Convenience with LG
      Beyond SKS, LG’s KBIS exhibit presents a range of premium LG-branded solutions designed exclusively for the U.S. market. Visitors can explore high-capacity, high-efficiency appliances across four dedicated zones – Zero Clearance, Zero Gas, Zero Venting and Zero Inefficiency – experiencing seamless connectivity and personalized comfort enabled by the LG AI Home hub, ThinQ ON and smart life solutions including ThinQ UP and ThinQ Care.
      Emphasizing the “Zero” theme, LG introduces innovations designed to optimize home spaces. The Zero Clearance Zone, styled as a chic, modern living environment, features appliances incorporating LG’s space-efficient Zero Clearance technology. Showcasing the benefits of electrification, the Zero Gas Zone highlights a variety of electric kitchen and laundry appliances, including induction cooktops and ovens. The Zero Venting Zone, demonstrates LG’s leadership in heat pump dryers. The dryers provide enhanced efficiency with the company’s DUAL Inverter heat pump and accurate fabric-type and load-weight analysis with the AI DirectDrive (AI DD) Motor and 6 Motion technology. A cutaway model provides an inside look at LG’s advanced heat pump dryer mechanics.
      The Zero Inefficiency Zone introduces the “Zero Labor Home” lifestyle with LG ThinQ ON AI Home hub and a suite of AI-powered appliances. This includes spacious, high-capacity solutions ideal for larger households, such as the LG SIGNATURE 29-inch washer and dryer pair and the 29-inch WashTower. Enhancing everyday convenience, LG ThinQ ON simplifies home management, ThinQ UP offers continuous service upgrades and ThinQ Care delivers premium, proactive support, creating a smarter and more efficient living experience.
      Accelerating Expansion into the U.S. Builder Market with Total Space Solutions
      Debuting at IBS, LG is showcasing an array of solutions for builders, designed to meet the evolving needs of homebuilders and the unique demands of their customers. LG’s comprehensive IBS exhibit features concept spaces designed to accommodate various lifestyles and preferences, each offering an optimized package that reflects the company’s intimate knowledge and understanding of the latest American housing trends.
      Builders can explore a range of compelling home solution collections, including packages with ENERGY STAR-certified appliances with heat pump technology and premium built-in packages customized for single-family and multi-family homes. The exhibit’s central meeting area allows attendees to connect with LG Pro Builders, LG’s dedicated salesforce for the builder market, to discuss the residential solutions on display.
      LG’s IBS exhibit also highlights the benefits of its smart home management solutions. LG ThinQ integrates smart appliances and IoT devices into a unified smart home system, enhancing convenience and security for homeowners. Additionally, LG ThinQ Care offers proactive support, intelligently safeguarding appliance performance and reliability while helping to prevent costly and inconvenient service visits.
      “By participating in both KBIS and IBS, LG is reinforcing its commitment to delivering tailored, high-efficiency total space solutions for the U.S. built-in and housing markets,” said Lyu Jae-cheol, president of the LG Home Appliance Solution Company. “We will continue to provide innovative solutions that fully address the needs of both our B2C and B2B customers.”
      Visitors to KBIS 2025 and IBS 2025 from February 25-27 can experience LG’s latest innovations at the company’s booths (West Hall #W2417 and #W2931, Las Vegas Convention Center).
      Innovative Appliances Leverage Company’s Industry-leading Technologies to
      Deliver Exceptional Efficiency and Convenient Customer Experiences
      SEOUL, Feb. 19, 2025 — LG Electronics (LG) is presenting its state-of-the-art laundry solutions at the 2025 Kitchen and Bath Industry Show (KBIS). The new models leverage LG’s industry-leading inverter heat pump and AI technologies, delivering enhanced efficiency and a host of convenient energy- and time-saving features. Embodying LG’s Zero Labor Home vision and customized for the North American market, the latest lineup offers an extensive range of options to meet customers’ diverse needs.
      LG’s washer and dryer, powered by LG’s energy-efficient dual inverter heat pump, will be displayed in the Zero Venting zone of LG’s booth at KBIS. Featuring an innovative ventless design, these laundry solutions are easier to install than conventional vented models and optimize space utilization, making them easier to install. In addition, LG’s laundry solutions employ Artificial Intelligence Direct Drive (AI DD) technology that offers sophisticated clothing care with a simpler user experience, analyzing load weight and fabric type to automatically apply the optimal washing and drying motions to achieve the best results.
      LG will also showcase the SIGNATURE 29-inch laundry solution lineup, including a washer and dryer pair and the impressive WashTower. The new washer and dryer feature a sleek, luxurious design and boast the largest capacities in their categories – 5.8 cubic feet for the washer and 9.0 cubic feet for the dryer. To increase capacity without occupying additional floor space, LG’s mini wash and pedestal can be installed directly beneath the washer and dryer. The new LG SIGNATURE washer and WashTower both deliver exceptional performance and efficiency with advanced AI Wash and TurboWash 360° features, enabling users to complete more laundry in less time, leading to zero inefficiency in daily chores.
      In the Zero Gas zone, visitors can explore the benefits of LG’s latest heat pump-equipped laundry solutions. Unlike conventional gas-vented dryers, LG’s heat pump dryers use a closed-loop system that recirculates air within the drum. This innovative system not only facilitates effective low-temperature drying but also helps reduce fabric damage, boost efficiency and contribute to lowering the carbon footprint, setting a new benchmark for sustainable laundry care. Also on display in the zone is the 27-inch LG WashCombo. This all-in-one washer and dryer combines an inverter heat pump with a ventless design and a space-saving configuration. The WashCombo, when paired with LG’s diverse laundry solutions, provides a seamless and stylish laundry setup for any household environment.
      For added convenience, all of LG’s new laundry solutions can be remotely controlled and monitored via the intuitive ThinQ app. The app also lets users track their LG appliances’ energy consumption and offers access to ThinQ Care, which helps prevent costly and inconvenient service visits by alerting users to potential issues before they occur.
      “LG will continue to leverage its advanced heat pump technology to strengthen its leadership in the North American premium home appliance market,” said Lyu Jae-cheol, president of the LG Home Appliance Solution Company. “The new laundry solutions we’re displaying at KBIS 2025 illustrate our progress in, and commitment to, realizing the Zero Labor Home vision.”
      Visitors to KBIS 2025 can experience the new LG laundry solutions firsthand at the company’s booth (West Hall #2417, Las Vegas Convention Center).
