[pivotCE] Preware.org woes: feeds/site down as domain slips away
Having trouble accessing Preware feeds in either Preware or WOSQI today?  Tried getting to www.preware.org and failed?  Well, you’re not alone.  Read on for the details.
UPDATE – Rod Whitby chimed in on the discussion (linked below). He confirmed the domain was newly expired and taken over. The webOS Internals team is contacting the individual for their demands but mentioned they also purchased preware.net to use as a backup if need be. Preware will be updated as well to reflect to domain change. He did offer a temporary solution for ipkg.preware.org. Edit your local DNS to point it to the IP 140.211.169.161.
pivotCE reached out to the webOS Internals team today on Twitter for answers.  It seems the sysadmin team has been alerted.  As for the course of action they’ll take, I’m not sure.  But while we all wait, have a look at your favorite “whois” site for the likely culprit. Don’t have one?  I did the hard work for you.
Simply put, someone snatched the domain.  See the “whois” result from
What does this mean for feed access?  Well, it’s hard to tell for the moment but for now we’ll just have to wait and see.  Hopefully some type of temporary solution can be put in place soon.
This has put the fear into some people (me included). You may remember when the and permanently closed.  Let’s hope history doesn’t repeat itself.  Speculation would say it won’t because will be using the same feeds for .
Folks are discussing this topic over at .  Feel free to chime in.
On a personal note, to the person who seems to have snatched the domain, not cool.  Seriously.  Not cool.
#webosforever
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By pivotCE
      link hidden, please login to view hold a number of events. This year’s will be of interest to fans of webOS phones, tablets and other computing devices of the past. The festival is held at the and runs over three days from the 12th to 14th of April. The festival includes three elements:
      – some with modifications to function in the modern environment. and . . For readers of this blog, representation of webOS devices will be in two of those areas. Jon W of the is attending over the weekend and will give a 50 minute talk at 900am on Saturday the 13th. The consignment shop will have a small selection of webOS devices for those who are interested.
      So if you are in the area, why not go along?
      If you can’t make it, you can follow along via the and TouchPads are available remotely at
      Discussion is at the . You can read more .
      Picture Credit: .
    • By kennyboom99
      hi Guys,
      My lg tv when set to live tv will show full screen for around 20 seconds and then show a very small shrunk screen in the top left corner of the channel
      i can switch channels but the screen stays mall
      netflix displays in full screen
      picutre test shows full screen
      i have tried resetting the tv, power cycling, changing cables (coax) and nothing is making a difference.
      anyone have any ideas on what causes this?
      this is what the screen looks like
      any help is much appreciated
    • By pivotCE
      Picture credit: from Pixabay
