There’s not been much popping up from the toaster lately, but there are still a few crumbs to sweep out.
  • link hidden, please login to view
    that had awarded LGwebOs reference status – a quality level for other Smart TV platforms to aim at.
  • I thought this happened ages ago, but it seems only Marc Aurelian over at was paying attention! . The end of phonegap support for webOS, Blackberry & Symbian. (en français, naturellement!). This is not necessarily a huge problem as discussed here: .
  • updated to version 1.5.4. Find it in Preware, but remember if you want to try this Twitter client for the first time, you need to add the special feed…
  • LG’s has also had a version update. No, it doesn’t work on Legacy webOS, but if you want to make apps that interact with webOS TV’s it’s a must. The new technology in means future support is a possibility…
  • Finally, : The Chubby Checker court case. The comments section of the article contains all the jokes you are likely to need on this matter.
I suddenly fancy a hot muffin…
    • By Charlie F
      Charlie
    • By DeeDeee
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
