time machine question
Bought the 55lb6300 and can't find time machine anywhere. Was told by lg that this function isn't available on the 2014 models...does anyone know if this is true? Thanks for any help
15 answers to this question
On the 2014 models it is called "time machine 2", and as I understand it, it is only available once you connect an USB disk.
/H
Thanks guys for the responses.....hooked up a 500 gig hdd in usb1 but nothing shows up as a recorder or time machine...the hdd shows up under devices but I can't record to it...I do have to use a cable box and hdmi cable so was now wondering if that's the problem? Maybe can only record from LIVE TV which for me would require a regular house antenna.
Well you should be able to record when you use the built in DVB-T2 tuner (that is how we do it). Don't know about using external decoders and set top boxes... I doubt it will work, but the manual should provide assistance, or make a call to LG support.
/H
you may have to format it to ntfs file system as a lot of devices cant see it if the drive is more than 4 gig,i think
47LB630V-ZA Italy
I had time machine installed on my TV even if i didnt connect a usb hdd. I tried to have it work with usb stick but didnt record. Now it works properly with 500GB usb hdd.
I think your problem might be country services limitation. Don't know why, but LG limits some services in some countries.
My TV is imported and I am having problems with mhp services... LG customer service replied that if not present in menu settings it means that mhp is not supported in my tv due to country limitation... so disappointed!!!!
How to record cable TV with LG Time Machine?
I did all the LG instructions recommended, but when I press "Record" I get the error:  "Recording is not available for analogue channels".
What a nonsense? I got digital cable TV connected to my LG 32LV5500 model. Is there something I can do to overcome this problem or is
"LG - Life is really that bad?  Thank you in advance for your good advice.
Warm Regards, from Joh in St'go de Chile
Only now I found out that... cable TV cannot be recorded with LG TM for personal viewing!! What a load of bull that is!  - Now I feel cheated by LG, because they did not inform or warn me in their user manual... that TM is can only record TV from an antenna source.
Here in St'go de Chile TV signal are reflected/ badly distorted by mountains and so, TV viewers are forced to buy cable and so, unable to record the TV program with TM.
Now what? LG offers no help at all! All they told me is that only antenna TV can be recorded and that cable TV is blocked by HDCP.
Question: How to solve this problem? Do I have to seek China's help...? Is there a filter, which cleans this coaxial TV cable of this HDCP filth/madness for private use?
How to record some sheduled program on time machine ? When you add some shedules from epg and turn off tv nothing happens in predefined time. Any suggestion ?
Sent from my SHV-E160L using Tapatalk
The short and the long suggestions:
Short:  use an HDMI-to HDMI splitter to connect to your TV (even though you are only using one of the output connections). The splitter will nullify HDCP.  (Google online for splitters known to work this way. In theory only all splitters should work this way, but a few have built HDCP in.)
Long: buy a recorder such as the magnavox MDR867H. Since the only input to the recorder is RCA (yellow-white-red), attach a HDMI-in RCA-out splitter. Now send your input to the recorder. For output use an HDMI cable. Because the input was RCA, the output is not blocked by HDCP. So you can watch and record on TV. The picture looks pretty good, but not as good as the "short" solution above.
On 30/06/2016 at 9:45 PM, jxrich said:
Quote
 I would be surprised if the LG allows you record from an input (although I admit, I don't know for sure) as I would expect the feature is tied in to the DVB (digital terrestrial) decoder, and intended for timeshiftimg programs.
    • By Gene680
      It turns my channel off at random times exactly 11 minutes after the hour. I checked and double checked the settings looking for timers, etc. any fixes that I’m missing?  It’s when I’m streaming on Sling.
      LG SIGNATURE OLED T and CineBeam Q Honored
      for Their Groundbreaking Innovation and Unprecedented Design
      ENGLEWOOD CLIFFS, N.J., Nov. 1, 2024 — This week, TIME revealed its annual list of the Best Inventions, naming the
      link hidden, please login to view to the list which features 200 groundbreaking innovations changing the world. Debuted at CES 2024, the LG SIGNATURE OLED T is the world’s first consumer transparent TV with transparent 4K OLED screen and LG’s wireless video and audio transmission technology, transforming users’ viewing experience with unprecedented freedom. Additionally, the  received a special mention for its sleek design, light form factor and performance. TIME’s Best Inventions of 2024 list is compiled by nominations from TIME’s editors and correspondents around the world, and through an online application process, evaluating a variety of industries and sectors such as consumer electronics, education, sustainability and robotics. Each submission is evaluated on several key factors, including impact, reach, creativity and effectiveness. See the full list here:
      Of this year’s list, TIME’s editors write: “The result is a list of 200 groundbreaking inventions (and 50 special mention inventions)—including the world’s largest computer chip, a humanoid robot joining the workforce, and a bioluminescent houseplant—that are changing how we live, work, play, and think about what’s possible.”
      Revolutionizing the world of home entertainment, the LG SIGNATURE OLED T transforms how we experience screens in our homes. This groundbreaking innovation not only delivers stunning visuals but also features a breathtaking transparent display that seamlessly blends into your environment when not in use. With its ultra-slim design, the LG SIGNATURE OLED T transforms into an elegant piece of art, enhancing any room’s aesthetic. Advanced wireless technology enables the transmission of 4K video and audio without the clutter of cables, offering a truly immersive viewing experience. The TV boasts exceptional picture quality, showcasing vibrant colors and deep contrasts, setting a new standard in home entertainment. With the LG SIGNATURE OLED T, LG is pioneering a future where technology and design coexist beautifully.
      With its compact design and powerful performance, the CineBeam Q delivers stunning 4K resolution and vibrant colors, transforming any space into a captivating theater. This state-of-the-art projector features advanced laser technology, ensuring exceptional brightness and clarity, even in well-lit environments. The LG CineBeam Q also offers versatile connectivity options, allowing seamless streaming from various devices, making it perfect for movie nights or gaming sessions. With its user-friendly interface and compact form, the LG CineBeam Q is designed to enhance your entertainment experience, setting a new standard for home projection.
      Furthermore, Signature Kitchen Suite’s 30-inch Combi Wall Oven, a product in the latest Transitional Series delivering a chic, minimalist appearance, has also been recognized as one of the Best Inventions of 2024 in the Household category.
      To learn more about the LG SIGNATURE OLED T and CineBeam Q, visit .
    • By JohnoFon
    • By coltaz
    • By Aventiled
      Hey
      I have an OLED C3 evo
      A Pioneer amplifier is connected to the optical output.
      I want to connect Bluetooth headphones and use them at the same time as the amplifier.
      The thing is, I haven't seen such an option on TV. It is possible to play simultaneously with the Bluetooth headphones and the internal speakers on the TV.
      There is no option for Bluetooth and the optical port at the same time.
      Am I missing something here?
      Dani
