terrestrial + satellite
By OhmorrowSouthWales
By Tony Levy
I live in Spain hence the two systems. When I press the home button on the remote the list is at the bottom and displayed are LG Content Store HDMI3, LiveTV Freesat etc but no button with the aerial option, so the only way I can switch is to go into the main settings menu select Programme Tuning and switch the programme mode from Satellite to Antenna.
By leader6234
Hey guys !!!
Thanks in advance !!!
