Knocking back Antoccinos is best with a few pastries so there are some crumbs to sweep out:
  • Another nod to the simplicity of LG’s TV interface with a
  • RSS Reader app, Feedspider seeks . Can you translate 112 strings of text into Bengali, Breton, Italian, Portuguese or Tamil?
  • It seems forum user, 1whocs has got the project working. Instructions are .
  • Grabber5.0 has identified another minor. Check your settings.
  • Hedami has released an update for location-based reminder app,
  • Retro-styled puzzle adventure game, has an update.
  • Both the apps above were released on the forums as app catalogue approval appears to have become extremely slow…
  • Finally, October 20th sees an HTML5 developer conference featuring an appearance from discussing JavaScript on TV.
That’s it until the next toaster notification!
    • By Charlie F
      Charlie
    • By DeeDeee
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
