[pivotCE] Next LuneOS stable release available: Antoccino
By pivotCE
3. Soldering iron and solder
2. Items 2-4 above
1.
2.
Prepare the Wires
Final Thoughts
#webos4ever
By pivotCE
Tools for the Job
– Needle nose pliers/tweezers
– Flush cuts
– Painter’s and kapton tape
Trim the USB C Board
Tape the USB C Board
Where To Get Power and Data
Put the Pieces Together
Congrats, You Now Have USB C
#webOS4ever
Company Announces Integration of Latest Intel Core Ultra Processor in the LG gram
Lineup at Intel Launch Event, Marking Giant Leap Forward for Personal Computing
SEOUL, Sep. 4, 2024 — LG Electronics (LG) is excited to announce that its newest LG gram laptop featuring the Intel® Core Ultra processor (Series 2) will be showcased at the Intel Core Ultra Global Launch Event from September 3-8. Renowned for its powerful performance and ultra-lightweight design, the LG gram series now integrates advanced AI capabilities powered by the latest Intel® Core Ultra processor. The LG gram 16 Pro, the first model to feature these new Intel processors, will be unveiled before its release at the end of 2024.
As the first on-device AI laptop from the LG gram series, it offers up to an impressive 48 neural processing unit (NPU) tera operations per second (TOPS), setting a new standard for AI PCs and providing the exceptional performance required for Copilot experiences.* Powered by the latest Intel® Core Ultra processor, the LG gram 16 Pro is now more efficient thanks to advanced AI functionalities such as productivity assistants, text and image creation and collaboration tools. What’s more, its extended battery life helps users handle tasks without worry.
The Intel® Core Ultra processor (Series 2) AI processor, which is three times more powerful than its predecessor, enhances a PC’s AI performance dramatically. With up to 48 NPU TOPS and up to 67 GPU TOPS, this next-gen processor offers up to 120 total platform TOPS to unlock new levels of productivity while maximizing user convenience. The new LG gram offers a smoother user experience, since the Intel® Core Ultra processor is optimized for Windows PCs.
“Together with LG, we are bringing to market the next generation of AI PCs that offer incredible performance, power efficiency and security capabilities for consumers. The LG gram 16 is a great example of an ultra-lightweight AI PC, powered by the all-new Intel® Core Ultra processor, that delivers an outstanding and seamless experience for creators, working professionals and everyday users. We’re thrilled for people to experience the wide-ranging benefits these AI PCs can enable,” said Michelle Johnston Holthaus, Intel executive vice president and general manager, Client Computing Group.
“Building on LG gram’s renowned ultra-lightweight design and powerful functionality, our newest model integrates Intel’s exceptional AI technology to push the boundaries of on-device AI laptops,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “The enhanced performance and productivity offered by the latest Intel® Core Ultra processor is poised to enrich the LG gram user experience with AI, ushering in a new era of on-device AI laptops.”
In line with the company’s AI vision of “Affectionate Intelligence,” an approach that seeks to understand customer needs and deliver differentiated experiences that go beyond traditional AI, LG plans to add more AI processor models to its gram lineup following the introduction of the LG gram 16 Pro with Intel® Core Ultra processors (Series 2).
* Rolling out gradually in preview within the latest update to Windows 11 in select global markets. Timing of availability varies by device and market. Learn more here: aka.ms/WindowsAIFeatures.
With the Theme of ‘Experience, Affectionate Intelligence Home,’
LG’s IFA Exhibit to Highlight Company’s ‘AI Home’ Vision and AI-Powered Appliances
SEOUL, Aug. 7, 2024 — LG Electronics (LG) is inviting consumers from around the globe to Berlin, Germany, to experience its latest AI appliance innovations at IFA 2024, taking place from September 6-10. Under the theme Experience, Affectionate Intelligence Home, the company will present its comprehensive and inspiring vision for the next chapter of the AI home.
At LG’s large-scale booth, located in Hall 18 at Messe Berlin, visitors can experience the elevated quality of life made possible by the company’s diverse lineup of AI home solutions. In addition to introducing its newest offerings powered by Affectionate Intelligence, LG will demonstrate its considerable progress in realizing the AI home of the future and reaffirm its strong commitment to leading a new era of AI innovation.
Those unable to attend IFA in person can still learn all about LG’s AI home appliance showcase through the LG Booth video, which will be available on the LG Global YouTube channel (
link hidden, please login to view) starting September 6. # # #
LG first incorporated Wi-Fi modules into its home appliances over a decade ago, and since then, the company has continued to enhance home living with its groundbreaking innovations. A leader in the fast-growing AI home appliance market, LG is now applying its proprietary on-device AI chip – the ‘DQ-C’ – to its latest lifestyle solutions, infusing them with the unique power of ‘Affectionate Intelligence.’
Introduced by CEO William Cho at CES 2024, Affectionate Intelligence underscores LG’s commitment to delivering differentiated customer experiences via cutting-edge AI technology that is more caring, empathetic and attentive.
Affectionate Intelligence is built on three pillars: Real-time Life Intelligence, drawing insights from real-life data gleaned from our global LG smart products and diverse IoT devices; Orchestrated Intelligence, seamlessly coordinating the operation of interconnected devices in alignment with customer preferences and intentions; and Responsible Intelligence, ensuring secure learning and adaptation, upholding privacy and integrity while delivering personalized experiences.
Enhancing Convenience with an Expanded ‘Affectionate Intelligence’ Lineup
LG’s expanded Affectionate Intelligence home appliance lineup now boasts 11 product categories: air conditioners, washing machines, dryers, Styler, air purifiers, robot vacuums, refrigerators, electric ranges, dishwashers, water purifiers and TVs.
Launched earlier this year in South Korea, the Affectionate Intelligence stand-type air conditioner offers unparalleled comfort with enhanced ‘AI Smart Care,’1 a feature that detects the user’s location in real time and automatically adjusts airflow directionality, intensity and temperature. Another innovative addition is the WashCombo all-in-one washer and dryer, which selects the optimal drum motions from LG’s 6Motion technology to gently yet thoroughly care for user’s laundry2 after analyzing each load’s weight, humidity level and fabric types.
Looking ahead, LG plans to evolve its Affectionate Intelligence into a generative AI-based service that extends beyond the smart home to diverse sectors and spaces, including mobility and online.
LG’s AI Home Appliances: From Wi-Fi Modules to Hyper-Personalized ThinQ UP 2.0
In 2011, LG became the first manufacturer to apply Wi-Fi modules to its home appliances. Six years later, in 2017, the company expanded Wi-Fi connectivity to most of its appliance lineups, introducing the LG ThinQ brand and ushering in the era of AI home appliances.
In January 2022, LG elevated customization and convenience with the launch of ThinQ UP, allowing the addition of new features to compatible LG appliances based on the analysis of customers’ usage patterns and habits. ThinQ UP home appliances operate intelligently, reducing the time and effort associated with household chores. They also offer flexible subscription options along with the ability to add new user-friendly services. With 336 downloadable ThinQ UP features now available3 – and more being added regularly – users can continually update their existing appliances for a tailored, always-evolving customer experience.
Last year, LG signaled the beginning of a new era for AI appliances with the South Korean debut of ThinQ UP 2.0. This latest smart life solution from the company offers hyper-personalization with advanced, new features plus a range of subscription services from LG and various partner companies.
Dedicated On-Device AI Chip Lineup and Expanded Application
In July 2023, after more than three years of research and development, LG revealed the DQ-C chip – a sophisticated on-device AI chip – and a brand-new operating system for home appliances. Last year, the company also established an organization specifically tasked with developing the next-generation of AI chips for future Affectionate Intelligence home appliances. This forms part of LG’s strategy to diversify its growing portfolio of state-of-the-art AI chips, and to bring the many benefits and advantages of AI-powered performance and features to more customers.
With ‘Affectionate Intelligence’ and impressive core technologies, LG has solidified its position as a global leader in the home appliances industry, and cemented its reputation as a smart life solutions company.
1 Products capabilities are currently available in Korean region only.
2 Availability for products, features and home services may vary depending on model and region.
3 Availability for products, features and home services may vary depending on model and region.
