Is possible to have the correct code to set in AREA CODE from the ezadjust menu for my tv? I have an imported EU 60lb730v my actual code is 3122 but i need ITALIAN AREA CODE for set on the MHP function. Thank's
  • 1 month later...
  • 2 weeks later...
I also have an imported 42LB65 model from UAE to Bangladesh.
But as usual, can't connect the LG store & cant download apps.
Can anybody help me by manually changing the country code??
Big thanks in advance.
-Ripan
  • 2 weeks later...
-Ripan
Goto General > Location > change service country auto to UAE or South Africa because not every country has started LG Store yet.
Regards,
Adeel
    • By denisuu
      Hi all,
      I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4.  I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
    • By Ian_AW
      G'day,
      Many apps will bring up an alphabetised layout of keys rather than the more conventional QWERTY keyboard.
      Is there a way of overriding this so that a conventional QWERTY layout can be used?
      Thanks.
    • By petersteinmeijer
      Hello
      I keep getting this bar ( see below ) about twice a week. It doesn't require me to do something as far as I can tell. When I close it it disappears only to pop-up again two days later.
      Am I supposed to do something ? If not how do I get rid of it ? It is very annoying.
      My tv isn't the latest model. LG webOS TV UM 7100PLB
    • By Vincio
      LGE6 TV settings menu won’t open. Any settings just say loading when you click on them. I.e. picture mode, aspect ratio, and all settings
      this TV has done this before but it somehow fixed itself after a month. I’m wondering if anybody knows how to correct this problem with the settings menus stuck on loading.
    • By williamsats
      I recently got a 32LB650V from LG Hellas as replacement of my old 32LM620A where it had a serious damage that coldn't be repaired.
      Nice move from LG but....
      The new WebOS for the moment is a crap compared to the old menu.
      In the old menu i had:
      LG Premium with lot's of goodies
      LG Smart World where it was full of apps of anykind and i could find anything i want.
      LG 3D World with nice short movies, cartoons and documentaries in 3D.
      Where are all these in WebOS????????
      Now i have only youtube, facebook and 2-3 other useless stuff.
      OK the panel's quality is better, sound is better, the configuration menu is OK, but where are all the other things that made me buy my old 32LM620A????????
