- 3
AREA CODE on EZ-Adjust menu
By 43UR81006LJ
By Sol Harold
Hi All,
i’ve got an OLED 55C1 with webOS 6.0 and a service remote in South America.
I’ve been able to find working area codes for almost all regions using the service remote based on previous posts and tables.
Of most use to me were:
Brazil: 26895 (local DTV transmission settings) /22800 (BR/US DTV transmission settings)
US: 1843 / 1793 / 22287
UK/EU/Turkey: 3122
AU Australia: 767
JP Japan: 23439
I’ve also found working codes for China (CN), Taiwan (TW), Hog Kong (HK), Philippines (PH), Australia, NZ & South Asia incl. India (AJ), certain African and Middle Eastern countries (JA or JA ME IL regions: note Israel is not an option even though IL appears in the code) , Canada (CA), Mexico (MX), Panama and Central America (PA), Ecuador (EC), Colombia (CO), Peru (PE), Chile (CL), and Argentina (AR).
Notably absent were working codes for;
Israel (IL)
Korea (KR)
Russia and CIS countries (RU CIS)
Eastern Europe (ETC?)
Does anyone know the working area option service codes for these countries?
I am mostly interested in working IL and KR codes.
thank you so much!
By Ramya Shyam
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
By glendvd100
Hi there, I have the following tvs:
OLED55C26LD
OLED42C24LA
And I'm trying to change the area code using the service remote, so I can download apps from USA (I'm currently in the UK), such as Max, HULU etc. I'm trying the codes which are bandied around the internet, but the area just stays as EU. I've noticed on youtube videos etc that the older models with the older OS have no issued with this, but mine seems unable to change.
Does anyone know if perhaps the newer models have newer codes? I've used 1793, 1843 and 22287 (as found in this very forum). But nothing happens. Any help from users who may have got this working would be appreciated, thank you.
peppeve
Is possible to have the correct code to set in AREA CODE from the ezadjust menu for my tv? I have an imported EU 60lb730v my actual code is 3122 but i need ITALIAN AREA CODE for set on the MHP function. Thank's
15 answers to this question
