EPG recordings start to late
By starwoodtech
By denisuu
Hi all,
I'm wondering how you can get into the service menu (In Start) on an old LG Smart TV (42LB630V) running WebOS 1.4. I have a Samsung Galaxy S6 (SM-G920F) with a IR blaster, I have tried sending '0x04FB 0xFB04' to I which should be IR code to enter the menu, but that doesn't work.
By Renver
When i power on my OLED55C8PLA TV it always starts at the source 'SET UP BOX' even there is no set up box connected. We only use HDMI2. That is also always the used source when we power down the TV. Its quite anoying the TV doesnt starts the input last used.
I hope someone can help me with this issue!
Thanks!
By Extra Celestial
Would love to auto start the Alexa app so my smart home can connect to it automatically when I turn it on from a plug since you can't turn on the tv with the hubs.
One small workaround instead of trying to figure out how to turn on the tv from a hub since it disconnects from the wifi when it powers off.
By margorjon
Hello, I would like to get our new TV to show the home screen at startup instead of a Rakuten channel were never interested in.
I have set the settings to show the home screen at startup yet it's still not working, at startup were still only getting Rakuten...
pelikano
If I plan a record by the EPG I miss the first minutes of the recording. I can not find any settings to adjust the start time as I am used to in my good old Kiss HD recorder.
How do I set the start time 5 or more minutes before the program should start?
Where can I send my feature requests to?
