Here's an email I recieved from HP..
Important information regarding your HP TouchPad order
_____________________________________________________________________
HP Small and Medium Business Customer,
Thank you for your interest in webOS and the HP TouchPad -- the
response to our price reduction has been overwhelming -- both in
terms of volume and in the energy and enthusiasm it has generated in
our customers.
It has taken us longer than anticipated to work through the high
volume of orders that were received. We apologize for any
uncertainty this caused, but we are now in a position to understand
our ability to fulfill your order.
Your order will be fulfilled at the discounted price. However, we
do not have enough stock to satisfy your order at this time. It will
take 6-8 weeks to build enough HP TouchPads to meet our current
commitments, during which time your order will then ship from this
stock with free ground shipping. You will receive a shipping
notification with tracking number once your order has shipped. We
apologize that these timelines are longer than indicated on the
website at time of purchase.
At the significantly reduced price, the HP TouchPad does not
qualify for our standard 30 day return policy and is not returnable.
If this delay is not acceptable, please send an email to
[email protected] with your instructions for cancellation within
a week. Be sure to include your HP order number and the name and
ship-to address on the order. Also please indicate clearly if this is
the only order requiring cancellation or if you wish all orders in
your name to be canceled. You will receive an automated cancel
notification when your order cancellation request has been
processed. Please be aware, however, that cancellations cannot be
reversed, and our US SMB store has sold out of HP TouchPad and will
not make any further available for sale.
We are pleased that we will be able to fulfill your order and look
forward to you joining the exciting community of webOS!
Sincerely,
Your HP Small and Medium Business Team
  • 3 weeks later...
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By ajmboy
    • By Alex
    • By pivotCE
      webOS friend and LuneOS project aficionado, , recently embarked on an unlocking adventure.  His HP TouchPad 4G gave up the ghost and passed away quietly.  So he did what anyone would do and got a new one!  That’s what you’d do if your TouchPad died too, right?
      His TouchPad was special though.  In fact, you probably read his article right here on pivotCE about with an unlocked Sierra 7710 card in it.
      Why not just crack open the new one and pop in the 7710 and throw away that crappy “3.5G” Ericcson card?  Well, the TouchPad pretty much breaks when you open it.  The little clips that keep the back connected weren’t designed to be opened once engaged.
      After Herrie contacted, paid for, and was reimbursed by several unlocking services over the course of about a month he finally stumbled upon which was able to get him an unlock code.  The catch?  It took 2 weeks but it only cost him about $10.50 USD.  Not bad!
      Need your TouchPad 4G unlocked?  Head over to www.unlockfusion.com and I’m certain they can help you.  Or crack yours open and pop in a Sierra 7710 (EU) or a Sierra 7700 (NA).
      #webOSforever
      Related posts:
