This model is not specifically retailed in the UK.  Can anyone who has this TV please confirm:
a) One can install UK apps like BBC iPlayer, 4OD... from the app store.
B) Freeview HD (DVB-T2) is supported.
I tried contacting LG about this and they would not confirm either.
    • By MaheshD
      What is the latest LG web os support for TV model 49UJ752T-TB. Currently in this model of my LG tv showing 3.9.2, also neither I am not getting automatic updates not manual. Because of this certain apps are not available to my smart tv. Some of these apps are sony liv, jio, tata binge etc.
      I req to plz help me how I can update lg web os for my TV model and which is the latest supported currently.
    • By MaheshD
    • By techguy noob
      My LG TV model number 32LM560BPTC is having an issue where the Sun NXT app is no longer available on the LG Content Store. I was able to watch it before, but starting yesterday, the app disappeared. However, on my other OLED LG TV, the Sun NXT app is still available in the LG Content Store. Is this issue specific to the 32LM560BPTC model TVs?
      Sarath
    • By SailorMoon
    • By Puja aingh
      Dear LG TEAM,       Kindly update my content store because I can't find the HOTSTAR APP AND JIO CINEMA ZEE5 AND SONY LIV   THANK & REGARDS VIKASH SINGH
