TV Menus Not Showing Up
By Danster75
Hi all,
I'm Danny and have a problem with my LG OLED65C8;
since a few months when playing movies, either from my Syno NAS or just plain USB, subtitles are being displayed double (over or above eachother) or are displayed for sometimes minutes after the sentence's been spoken. The videofiles haven't got any hardcoded subs but either subs included in the mkv container or as separate srt of ssa file. Disabling subs removes the display of subs, enabling subs results in double or persistent subs.
Subtitles have been disabled in the accessability menu, factory reset did not help.
I searched but as far as I can see this problem has not been discussed yet, also googled and never came across this problem. Perhaps someone here can help?
Kind regards, Danny
SOLUTION, for me at least:
I used ColorControl to reboot the TV. It's weird that a factory reset did not work but a simple reboot did.
By andreluigo
I used to extend my screen from PC/Notebook to my TV but i stayed a long period without do it.
It happens that since a few days ago i am needing it and for my surprise is not working anymore. Tried other cables, updated the drivers and O.S. but nothing worked. So i decided test at the room's TV (LG as well) and worked perfetcly.
I looked for all internet and youtube for similar issues and a solution but couldn't find it, until i receive my weekly mail from this forum and remembered it.
I am suspicious that was one of the several updates since i extended for the last time that made this!
So, does anybody could help me, please?
Thanks in advance!
By HamidHX
During the last month, users of our website have informed us that their LG TVs do not display the site. According to the SSL/TLS certificate test, we didn't see any problem, please advise what is the problem that displays the error "This web page is not available" when enter the site with domain "www.itoons.ir"?
By Ramx
Hi, like the title says. Whenever I try watching Dolby vision content in my LG A2 it just shows a black screen. The sounds plays perfectly fine without any issue. It is just the video that is not working. I don't have any HDMI inputs connected. This content worked in the past, but for some reason is not working anymore. I have already tried power cycling the tv and deleting and reinstalling the apps I tried it on.
Thanks for any help!
crazyitalian
Hi. I'm having an issue where the TV worked fine last night; however, today the TV won't show menus. I turn it on, click the toggle on the bottom of the TV and the lower menu doesn't show up (usually gives power and input settings). Same with the home button on the remote....no menus. Power cycling does not change this behavior. Anyone have a similar experience?
