Wireless connect to internet
I bought a LG 55LB730V and I connected it via ASUS RT-N56U to the internet. Both devices has the latest SW release i.e. TV: 04.30.16, ASUS: 3.0.0.4.376_1665.
The network gets connected according to the Advanced settings but I'm not able to surf. And using the Smartshare on my PC works very random and secondwise.
LG-store reports not connected to the internet.
Any suggestions?
Dennis
5 answers to this question
if your neighbour's on same wifi channel as your wifi router it could be causing interference and forcing the connection to drop.
The best thing would be downloading this to a laptop >
  and walk around the house,  it will display every wifi router it picks up and tells you which channels are available.
you would just need to login via a webpage to your router to change to a clear wifi channel - any kind of interference will cause a connection to keep dropping just like you outlined.
The next choice would be buying HomePlugs, they plug into the electricity and then into your tv - they don't use wifi so you won't get any interference.
I tried to move to channel 2 and 3 (2.4Ghz) and there I get some internet connection, but very unstable. I even swiched to 5Ghz and got a little more improvements, but still very unstable.
The ASUS used to be a good performing router but now I get this unstable connection.
Still believe ther's something miss-matching btw the router and the TV.
//Dennis
Had the same problem on a new LG WebOs TV, which connected OK to the wifi router but no internet access.  Not much help from the LG support (Denmark) who blamed the router (which works fine with every other one of the twenty other devices connected to it, including smart-tvs, droid and iphone, pc, iot gadgets...).
SOLVED by:
Settings - Network - advanced
Uncheck automatic
Change the DNS  server from the default (automatic, identical to the router IP, 192.168.1.1) to one of the DNS servers suggested in
  The openDNS server 208.67.222.222 worked fine for me.
    • By Mandx
    • By JamesH
    • By DavidSr
    • By Fredrik Andersson
      Transitioning Between Transparent to Opaque Screen, LG SIGNATURE OLED T
      Introduces New Viewing Possibilities and a New Era in Home Entertainment
      SEOUL, Dec. 19, 2024 — LG Electronics (LG) is set for the global launch of the 77-inch LG SIGNATURE OLED T, the world’s first transparent and true wireless 4K OLED TV. This groundbreaking model will be available in the U.S. this December, with additional markets to follow.
      Unveiled at CES® 2024, the LG SIGNATURE OLED T represents a monumental leap in both technology and design innovation, reflecting LG’s relentless drive to delivering new and better. Its cutting-edge self-lit screen can transform from transparent to opaque screen; a unique ability that provides the OLED viewing experience while offering greater freedom in living space. Recognized globally, LG’s transparent OLED made TIME’s Best Inventions 2024 list and received a total of five CES 2024 Innovation Awards, including a Best of Innovation honor.
      Users can effortlessly switch between transparent and opaque modes at the touch of a button, unlocking unique possibilities for entertainment and space design. When in transparent mode, the OLED T offers a futuristic content experience that must be seen to be believed. The screen not only creates the illusion of content floating in mid-air but also produces a mesmerizing effect by “merging” the on-screen visuals with the surrounding space.
      LG OLED T further elevates the user experience with a suite of versatile features that optimally leverage the unique advantages of a transparent OLED screen, enhancing its distinctive value.
      One standout feature is T-Objet, an Always-On-Display (AOD) mode that transforms the screen into a transparent digital canvas, ideal for showcasing artwork, videos or photos in outstanding color and clarity. Complementing this is T-Bar, a sleek info-ticker that appears along the bottom edge of the screen, providing sports results, IoT device statuses, weather forecasts or song title information. The rest of the screen remains unused when T-Bar is active, presenting a clean, uncluttered look and a clear view of the space behind LG’s “virtually invisible” display. For added convenience, T-Home offers a user-friendly interface that delivers a well-organized overview of available services, as well as quick access to apps, settings and other features.
      Despite its stunning 77-inch screen size, the LG OLED T enhances the feeling of space within a room, providing a sense of openness that conventional TVs simply cannot. Its transparency allows it to be placed centrally without being obtrusive or positioned in front of windows without blocking natural light or views of the outdoors.
      The transparent 4K OLED screen, combined with LG’s true wireless video and audio transmission technology, promises not only the aesthetic value but also an enhanced home entertainment experience. Free from tangled cables, the device delivers an immersive, distraction-free viewing environment.
      The OLED T advances innovation with LG’s proprietary Zero Connect Box, a visually lossless wireless video and audio transmission solution* without latency ensuring a seamless viewing experience. By supporting 4K at 120Hz variable refresh rate, OLED T has been certified by NVIDIA G-SYNC® Compatible and AMD FreeSync Premium to eliminate tearing and stuttering for the most dynamic, true-to-life gaming experience.
      The LG SIGNATURE OLED T carries forward LG’s legacy of providing superior picture quality and immersive viewing experiences – hallmarks of LG OLED TVs since the very first model hit the market in 2013. Building on over a decade of OLED innovation, LG’s one-of-a-kind TV brings images fully to life with vibrant, precisely reproduced colors and incredible contrast. Powered by LG’s advanced α (Alpha) 11 AI processor, the OLED T intelligently optimizes both picture and sound quality, delivering unparalleled visual and auditory experiences.
      “LG SIGNATURE OLED T is an exceptional user-focused innovation that offers a distinctive, multi-faceted viewing experience and unprecedented spatial flexibility,” said Park Hyoung-sei, president of the LG Media Entertainment Solution Company. “LG remains at the forefront of innovation by combining its industry-leading OLED technology with unique form factors, transparent screens, wireless connectivity and more, delivering unparalleled, life-enriching advancements no other TV maker can replicate.”
      * Wireless transmission refers to the transferring of video and audio signals between a TV screen and the Zero Connect Box. Visually lossless, based on internal test results with ISO/IEC 29170-2 and measurement results may vary depending on connection status.
