I would like to have aspect ratio of smart share included in this
Every time I reboot my TV the settings of smart share aspect ratio is. Reverted back to defaults. Hope they fixed this issue.
    • By Low Grade
      many thanks in advance😃
    • By Magsing
    • By Itachi3431
      Hi all,
      TV details - 4K Ultra HD Smart LED TV 55UR7500PSC
      P.S., running latest Web OS
    • By LG user1
      I can't open settings on my LG B9 55" either from the remote (results in black screen) or from menu system (same). Also, when I click on any streaming app, nothing happens although the buttons on the remote otherwise work. I would like to try a factory reset, but can't do this without accessing the system menu. If you know how to factory reset without the menu or otherwise know a fix, please let me know!
    • Solution For That Pollution
    • By Cedric
      Since my TV updated to the last WebOS firmware 05.20.08, quick access key (Long Press 1 for HDMI1, Long press 2 for HDMI2) are reset each time i shutdown the TV, and i have to set them after each reboot...
      I tried to restore the factory default settings on the TV to see if there is any change, but sadly this didn't fixed my problem.
      Any idea please ?
