who use LG WebOS TV? I need some help
Hi? Anybody in US use LG Webos Smart TV with a smartphone with IR Port? (Galaxy Note 3/S4,S5 or LG G3 or HTC One) plz help me :D
Just download this:
When done, open it and Press Menu - dwl a remote ctrl- manuf section: LG, type: TV and press Search button in the right of Manuf box, scroll down and find LG Service Menu, choose this and press download.
Then press EzAdjust and use a normal LG remote (or use Samsung WatchON LG remote, HTC remote, QRemote LG...) go to section 7: Area Option and tell me the code in the first line, thanks.
Passcode if it need when press EzAdjust: 0413
I just found some code: 3122 in UK, 4834 in VN, change it if you want to try :), In Australia/Asia model change code to UK will enable Freeview,DVB-C and some apps: Spotify, Netflix, BBC...
Just download this:
I didn't find the app of the link you've posted.
