Using keyboard with WebOS tv
Hello, new here. Just bought a LG 50LB650T TV. Like it quite a bit. Trying out the features on the tv and using MS 800 usb keyboard and mouse. I cannot key in search words in the Youtube. Mouse and some key functions like up, down, left, right works. The WebOS browser works fine using the keyboard when I type URL in. Just trying to key in search words in Youtube and it's not happening. Any help, or suggestion, or is this a bug in the OS?
Thanks.
I guess you should submit this complaint to the app developer, which in this case is google? Can't you submit feedback in the app store?
Youtube is definetly an app you want to input texxt to, and since the tv has support for BT keyboards, it is the ideal case.
/H
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Jaswinder Sandhu
    • By tarakdave
    • By AtWitsEnd696
