Please Help - Hiding Videos for TV
Hi Guys,
  I own LG 47B6500 SmartTV. I have 1TB HDD in which I have stored lots of videos. There are some videos I have hidden using tool called "WinFolder Lock Pro" and they are not viewable on a computer. But when I plug this HDD to my TV and start SmartShare, these vidoes show up in Videos which is big problem. I have tried using simple method of hiding files/folders chaning attribute to Hidden as well but still they show up. Does anyone know a way around this so that videos/pictures can be hidden from this (over)SmartTV...Please help!!
Thank you
7 answers to this question
This is linux you must name it to start with dot
Hidden must be .hidden
Dude it made matter worse!! Not only it still shows in SmartShare Videos of TV all files are now on the top of the list after prefixing with them dot. Any more suggestion please!!
Try using the HDD with Windows & then check the folder with properties & check "Hidden" . let me know if it works for you.
Thanks for replying buddy.. I have already mentioned that I have tried changing attributes for files/folders in my question which is nothing but same you mentioned here...
Tried other methods too, nothing stays hidden from Linux and this Smart(ass) TV :unsure:
Have you tried this command in CMD with the folder you want to hide
for eg.
I want to hide Folder "XYZ" in  Drive D
or hide a file "XYZ.mp4"
type  CMD :
D:
attrib +h +s XYZ
attrib +h +s XYZ.mp4
Commands:
"attrib -h -s *.* "      (for showing /unhiding )
"attrib +h +s *.* " (for hiding )
Regards,
Kautilya Save (SensehacK)
for eg.
type  CMD :
D:
attrib +h +s XYZ
Commands:
Regards,
Dude, again you are telling me to do the same thing which I think its most basic thing done by 99% of desktop users to hide their files. Attrib command = File Properties-Hidden option....webOS does not work like Windows operating system, it is based on Linux. And apparently nothing is hidden from Linux. Changing file name by prefixing dot does not even seem to work which would have worked otherwise in desktop linux.
    • By Jaswinder Sandhu
    • By ato53
      I have a new C4 TV.
      Thanks for the follow-up
    • By u84six
    • By keshav iyer
    • By John Nguyen
