Hi!
I have been trying to install the WebOS SDK to a MacBook Pro (OS 10.10.0) but it always stops at the installing process. Its just says "Copying "Resources" .../java.1" There it just stops and doesn't go any further.
I have tried to have the computer on all night but with no success.
So i really hope there is someone there that can help me with this problem.
More information:
Here is the exception that i get every time that i try and install the WebOS SDK
Exception in thread "Thread-3" java.lang.NullPointerException
at com.lge.sdk.ngtv.installer.controller.Controller.shortcutURLMac(Unknown Source)
at com.lge.sdk.ngtv.installer.controller.Controller.createShortcutsMAC(Unknown Source)
at com.lge.sdk.ngtv.installer.controller.Controller.shortcutsAllPlatforms(Unknown Source)
at com.lge.sdk.ngtv.installer.controller.Controller.performPostInstallationTasks(Unknown Source)
at com.lge.sdk.ngtv.installer.controller.Controller.installComponents(Unknown Source)
at com.lge.sdk.ngtv.installer.installerscreen.InstallationProgressPageLatest$2.run(Unknown Source)
at java.lang.Thread.run(Thread.java:745)
    • By John Nguyen
    • By Nick Payne
    • By LG tv fan
      Recently live channels stopped working with an error every 2-3 seconds.
      Older media is still playing.
      Now I noticed that new media like today's news aren't playing either. Same error.
      News from Friday 3rd may still work.
      Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
    • By Alex
      webOS TV SDK V1.2.0 Download Installer
      Download the proper installer. With the installer, you can choose whether to install with network installer or SDK package. Available packages:
      Windows 32-bit Installer_win32.zip (8.13M) Windows 64-bit Installer_win64.zip (7.52M) MacOS 64-bit Installer_maxosx.zip (7.38M) Linux 32-bit Installer_linux32.zip (7.94M) Linux 64-bit Installer_linux64.zip (7.59M)   SDK Package
      Download the proper SDK package. To use network installer, you don't need to download the SDK package. Available packages:
      Windows 32-bit webOS_SDK_win32.zip (1462.29M) Windows 64-bit webOS_SDK_win64.zip (1466.67M) MacOS 64-bit webOS_SDK_mac64.zip (1451.31M) Linux 32-bit webOS_SDK_linux32.zip (1463.35M) Linux 64-bit webOS_SDK_linux64.zip (1462.28M)
      Please visit the LG site for complete link hidden, please login to view.
      See the for step-by-step instructions.
    • By cpattap
      Bonjour sur un Web OS TV UJ 620 V , comment lire et installer une application ?
      Le lecteur USB ne lit pas les fichiers ou APK.
      J'ai activé le mode développeur, créé un compte, mais ne parviens pas à la section "sources inconnues" pour la cocher et permettre l'autorisation d'installer des fichiers APK.
      Dans Developper Mode, j'ai
      IP Adresse (Wireless) 192.168.1.29 ONE Dev Mode Status
      IP Adresse Disconnected OFF Key server
      Passphase 3B6D27 Extend Extend Session Time
      Remain Session 49h:53mn OFF Clear Cache Data
      Si je valide par OK , rien de plus !
      1_Comment continuer la procedure ?
      2_ Existe-t-il une autre façon de procéder ?
      Cordialement.
