Few questions about LG 42LB700v fw update/restore plex etc.
Lg 42lb700v-za
FW 3.25.15
It offers 4.30.16 do I update?
Will I still be able to see plex media server that is on my pc or only the LG smart share application..
Will the menus and smart menus be more responsive or more sluggish
Will I get the erros that everyone is complaining about like - not enough memory and such.
Is it possible to restore to 3.25.15 if I dont like the 4.30.15 update?
Thank you in advance
    • By Trev
      1. For well over a year the Antenna Channel Guide has been incomplete. Is there a way to manually update the guide?
      The Prime app has suffered from two problems:
      2. No subtitle option on movies, fixed by app uninstall/reinstall. Is there an easier fix?
      3. 4K movies downgrade to SDR or SD momentarily, app uninstall/reinstall did NOT fix this?
      TV software is upto date. Internet speed is good. Cache has been cleared by power disconnect/reconnect.
      I have not tried Reset To Original settings, will that wipe out antenna channel & HDMI input name customizations?
      Thanks.
    • By The Old Man
      Hey LG
      Yes I am NOT happy
    • By DavidSr
    • By Lgrump
      Is it just me or is the plex app just unusable on webos.  When I try to select dvr items with the magic remote they just don’t play.  I am not sure if this is a plex issue or an lg webos issue.  Anyone know which it is?
    • By Jason Worthen
      I need to set my plex app settings to allow insecure connections. and I have tried everything to find a menu to the plex app settings. But I cant seam to find a way there.
