Vtuner problem connection!
Hi!
I bought an lg 32lb650v and I have vtuner problems connection!
Sometimes is working sometimes not and I say the most of the times!
I've done the latest update!
I don't know what is the problem?
    • By PVD
    • By hollean
    • By AJO
    • By akhil7j
    • By BozaB
      I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
