Vtuner problem connection!
I bought an lg 32lb650v and I have vtuner problems connection!
Sometimes is working, sometimes is not working and I have this problem most of the times!
I've done the latest firmware update!
I don't know what is the problem!
Please I need your help for this issue!
I'm experiencing the same. Seems like vTuner stops working after last firmware upgrade. Every time you try to launch app, it stays forever on loading screen. Previous to update was working perfectly. I hope someone at LG look at this, it's a shame that every update brings that kind of issues. It's not the first time updates breaks things.
    • By PVD
    • By hollean
    • By AJO
    • By akhil7j
    • By BozaB
      I need help, I bought LG Oled 65 C41 LA tv two days ago, tv is working mostly fine, except when I watch LG installed streaming platforms ( Netflix and MAX tested ) tv freezes and after about 10 seconds it restarts. It does not have any pattern as far as I know, sometimes I can watch 20 mins, last two times after six minutes it crashed and restarted automatically. Can someone please help me, how can I resolve this issue? Did someone had sam problems already? Is my tv broken or I can do something to fix it?
