HP TouchPad with Android 5.0 Lollipop
  • 2 years later...
  • 2 months later...
33 minutes ago, joshua764 said:
Tell us how did you go?
Enviado desde mi XT1635-02 mediante Tapatalk
I haven't done anything with it yet.
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By coyote
      I'm surprised by how few Settings there are.  Is there an Android Settings App?
    • By Ayon Mondal
      Whenever I'm trying to run hotstar on my TV it is showing that NETWORK CONNECTION NOT STABLE TRY AGAIN.  Please solve the issue as soon as possible and let me know how to fix it.  This is the serial number of my TV :- 64387205122152TRFLJL
    • By SGray
