- 1
Four Color Remote Buttons
By Tombanjo
Brand new LG OLED 65"G4 has color blotching (or banding), not sure what the official term is. Netflix & Prime especially on any picture setting, and the "vivid" setting on everything. I don't really use vivid anyway but should not be happening. Of course I tried all suggested online and tech supported fixes to no avail. I called LG and after many very frustrating routings to different agents, they refused to send a replacement because their policy says within "30 days of purchase." I pointed out that it was now day 28 and therefore is within your policy, the person stated that by the time they go through the process, it would be over the 30 day limit! I mean, talk about banging your head against a wall! How do you argue with such logic?? After a few more call routings, they connected me with a repair service. The man came out within days and replaced the board (I think that's what it's called) but no dice, the problem remained. He then ordered a new panel which I'm still waiting for. It would have been cheaper for LG to just send a new TV rather than replace a panel and pay a repair man for two house calls. Crazy! I've had 5 LG OLEDs without a problem. This is very upsetting.
By RJ Fischer
By u84six
By joepineapples90
So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors). So my question is, do any other LG remotes work with the G4?.
sensehack
I would like to know the four buttons of the remote and still haven't used them .
I pressed every one of them but nothing happened.
If only we have the option to configure these hot buttons for the settings or configurations we like
For eg.
Red color : would only turn screen off not the audio playback.
Green color: change aspect ratio of playing video (Smart share).
Yellow color: 3D settings
Blue color : Favorites Channel.
5 answers to this question
