Does someone knows why 42la620-za model has flash player in the browser and 42lb700v-za doesn't?? nor lb670
The one that has Flash Player is running Netcast Operating System, LG stopped working on it. and the other without is running WebOS, and they don't have flash player and you calso can't install it, that's because i have contacted LG and they say that ADOBE doesn't want to provide Flash Player for the WebOS because the latest version of flashplayer is 15 and netcast has the version 10 and it can't be updated. They say that you personaly can talk with them or complain, but that's the company's policy.
I recommend you buying a cheap Android Mini PC and watching multimedia from it, because with the one that has WebOs, you are not going to br able to watch the video for more than 15-20 minutes because it will say "out of memory, app is closed" becaus Netcast uses less RAM than WebOs, and RAM can only be refreshed by swithing off and on again in Smart TV's. Hope it helped, 1 like helps me.
    • By Jack1151
    • By mycop
      Greetings.
    • By Prakash Sahoo
      Hi Team,
      Prakash Sahoo
    • By Lesbo
    • By wallyricks
