IF Anyone is thinking of buying a new tv ... avoid a Smart LG TV!
Best advice you could probably get,   Maybe stick with (Non-Smart) televisions but stay well away from anything they suggest is Smart.
The current Problems are....
  • The LG store is 95% down for apps, when an app updates it could take a few days before you run it again.
  • You have to wait anything from 30 - 60 seconds when you turn on the tv to change channel.
  • The tv guide is basically an app, so that also takes ages to open (if it's not open)
  • LG Technical Support are a complete waste of time, they would rather blame the app developer when the LG store is down.
  • Did I say it takes 30 - 60 seconds before you can use the telly? (it's the 1950's all over again)
  • Watching something on Iplayer at random times ' out of memory error ' pops up.
  • Sometimes the audio is out of sync.
5 answers to this question
Depends if it's WebOS or Netcast.
And the webOs hasn't got Flash Player.
Lg WebOS hasn't got Flash because i have talked with LG and they say that ADOBE doesn't want to provide them Flash, then i asked why Netcast has flash, they sayed that in that moment ADOBE provided them and as you can see netcast has flash 10 and can't be updated, and the actual version is Flash 15, they sayed that if i talk personaly to adobe, they could help me, so if we all send a mail to adobe, may be they can  provide flash on behalf of clients, so friends, one email can change the way of your TV, so please help me and also send emails to adobe. Hope it helped, 1 like also helps me
Really really disapointing this FLASG issue. Think i will return my TV.
It is really a TV failure that you cannot watch TV in the TV. And it is not mentioned anywhere.
Just want to echo what others say. I have an LG 55LB730V
It is a dirty screen effect, buggy load of rot and LG don't allow negative reviews on their site but pass the positive ones on to sellers to put on their websites.
Earlier this year we bought a 65 inch LG smart TV. We are so disappointed with it on discovering that so many of the things we want to watch require Flash Player which is not supported, that the smart TVs we have bought (today) for our kids Christmas presents are not LG. LG just lost three sales and that's just from me. Try watching any of the commercial free to air TV websites in Australia such as 9jumpin or 7plus and they all require Flash Player to work. Prior to buying the LG "smart" TV we were loyal LG purchasers.
    • By skan
      Hello.
      Some tutorials explain how to do it.
      We first need to root the TV with scripts such as RootMyTV, and then install dts_restore.
      Both tools are free and available at github.
      I'm not writing the links because I don't know if it's allowed in this forum and because I take no responsibility.
      My question is:
      Has anybody tried this process? Does it work?
      The documentation says if you have any problem you can just factory reset the TV, but I don't dare to do it.
    • By Surojit Bhattacharjee
      The sales person in showroom pushed for LG saying it has better sound and picture richness. But obviously didn't reveal big shortcomings of non-android smart TV in today's ecosystem. This is useless as you are not having freedom to install apps of your choice from playstore. I can't even get Sonyliv. Horrible OS. Now I am trapped for years after buying this TV. Don't buy LG or other non-android TV unless you can affford to throw it in weeks. When will LG grow up?
    • By DeBC
      Anyone looking at getting a LG TV I would recommend look to different company. LG do not provide any good webOS TV support
    • By Kieran Bryons
      I'm looking to buy an LG AI Thin Q TV, how do the sports alerts work -
      link hidden, please login to view I literally watch loads of sports, does it update you on only certain sports or all sports?
    • By Phaedrus
      On an LG CX 55, two minutes into episode 4 -- "The Tomb" -- of the series Moon Knight on Disney+ there is a scene with statuettes in niches each lit by an oil lamp. As the flames flicker, dark blotches jump around some of the niche walls.
      These are certainly unintended artifacts.
      Can someone confirm wether this is a CX (only) issue?
