By John Nguyen
By Nick Payne
By LG tv fan
Recently live channels stopped working with an error every 2-3 seconds.
Older media is still playing.
Now I noticed that new media like today's news aren't playing either. Same error.
News from Friday 3rd may still work.
Have tried on 2 LG tvs.. Oled from 2018 and LCD from 2020
By Trollpaw
Hello.
I have an issue with my tv losing connection.
It seems like it's not uncommon for it to happen from time to time. but is has gotten worse the past couple of months. It can happen several times per day. usually when using netflix, but it can happen whenever.
i regularly lose the bluetooth connection to my magic remote, and a lot of the times when this happens i also lose connection with the wifi, The remote is still usable, in a somewhat limited capacity(no pointer, and need to have a more clear line of sight to the tv)
when the wifi disconnects it sometimes connects automatically, sometimes i have to manually connect it again, and sometimes the wifi function gets turned off, and can't be turned on again. usually this solves itself by putting the tv on standby and starting it again. using cable instead of wifi is not possible for the moment.
the remote. what usually works is pulling the plug on the tv for a while, and then it functions again. sometimes it's enough just putting it in standby mode for a minute or 2. sometimes i have to unregister and re-register the remote. THere's not one thing that works all of the time, so i have to try several things, but i've found that pulling the plug usually works best.
it's rarely enough to un-register and re-register the remote, i usually have to either put the tv in standby for a couple of minutes, or pull the plug
it's getting very frustrating dealing with this, so i'm asking to see if anyone knows what to do as a more permanent solution. i have no issue with doing factory resets or anything like that.
Regards
Stoffe
By Shadowkatt
Watching anything on the FilmRise app, shows a “lost network connect, reconning error. The issue is that the video is running fine behind the error, you just can’t see the top part of the screen because of it. The answer to an earlier post was it works fine on Roku, but I don’t have that.
- 8 replies
- 35,872 views
- 0 replies
- 16,658 views
- 2,362 views
- 0 replies
- 2,098 views
nolan1985
I recently bought an 50LB650V-ZN and as they have been out for a while i assumed it woukd need updating straight away.
ive connected it to the internet and when i click check for update i get the message 'Unable to check for updates'
i also bought a magic remote and after about 5 minutes of using it a pop up will appear saying 'failed to update magic remote' then the magic remote will turn off and stop working until i remove the batteries and put them back in again.
ive asked at the shop where i bought it and they say the TV should need updating straight away as its been available for about 8 months and that the magic remote doesnt actually update, only the software on the tv will update to support the magic remote.
ive tried to download the software update from the lg website but cant get the files to unzip so my tv doesnt recognise the files.
anyone come accross this problem before or know how to fix it? any help would be appreciated
thanks
25 answers to this question
