- 1
LG web os TV and LG soundbar - sound drop/ Cutoff / issue wireless
By crct
By hollean
By DeeDeee
By Pranay Mokida
By Regis Wheeler
Matan Faragi
I'm not sure its the right place but at any case i will describe my issue here and maybe you will be able to help:
Recently I bought a a TV and a sound bar, and i have some issue from the moment i get the TV.
TV model - LG 55LB679Y with latest firmware version i have at my country (Israel) - 04.30.16
SoundBar - LG NB4540
the TV connected to sound bar by "wireless simplink" feature 'LG TV' and TV connected to My Wireless router.
every 5 - 15 minutes, i have sound drops / Cutoff / stooped / Interruption, seem like the TV loose connection to sound-bar for few seconds or something similar, it's happen from any AV source im using HDMI, USB...
and the local re-seller replace the sound-bar to a new one (same modal off course) and i didn't help.
i have try to troubleshot the problem in the last few weeks - but didn't succeed to solve it, and also the support / costumer service didn't have solution for this.
some steps i take when troubleshot this issue:
* different wireless configuration on router - different channels, SSID, Security - issue still persist.
* another wireless router - issue still persist.
* working with optical cable to sound bar - just for testing - working ok, but i need the wireless feature working this the reason i bought sound bar and TV from the same manufacturer.
* disconnect the TV from wireless network - looks like it's working ok, but didn't had chance to test it for long time.
from my point of view looks like it's issue with wireless device on TV not able to to work in parallel with soundbar and wireless network for some reason, It could be caused bysoftware issue on WebOS or Hardware issue with this TV model.
I really hope you be able to help me or throw some light on this case.
Kind regards,
Matan
Top Posters For This Question
7
6
3
3
Popular Days
Feb 1
5
Mar 3
3
Jul 27
Dec 5
Imparatul 7 posts
ViaSwiss 6 posts
iamover 3 posts
Matan Faragi 3 posts
Popular Days
Feb 1 2015
Mar 3 2015
Jul 27 2017
Dec 5 2016
Popular Posts
philb
I too am having same issues with intermittent dropping off of the sound volume. I am using a new LG OLED 55B6V TV with Orbitsound A70 soundbar. Both (top of range?) items newly purchased. Connecti
Matan Faragi
Hi, I'm not sure its the right place but at any case i will describe my issue here and maybe you will be able to help: Recently I bought a a TV and a sound bar, and i have some issue from the mom
Imparatul
Your network connection might interfere with the wireless signal between the TV and the sound bar. If possible try to use a 5GHz connection if your router is supporting this feature. I'm interested to
42 answers to this question
