LG Sound sync compatible headsets
I've just bough LG HBS-730 bluetooth headset with the hope that I can connect it to my LG TV LB650V via LG Sound Sync (wireless).
However the TV does not recognise the bluetooth headset and doesn't show up in the list of available devices.
Can anyone confirm of please let me know if this is possible ?
Optimus
14 answers to this question
I have a Hearphone original hbs730, the TV recognizes it, you have to enter the menu and select wireless audio, search, device. you have to press the little button with the circle in headphones on and the TV recognizes.
a problem however is that if you set the headset as a source of sound, when you turn off the l 'audio will automatically switch to the internal speakers, and if it's at night makes a big mess.
other thing is that if you put a headphone that they have not put on the list, all 5 Hearphone bluetooth, even if the others do not have the same characteristics listed in the TV does not recognize them, have obviously put a filter in it firmware .... improperly ....
Reply from LG:
We appreciate your interest in this television. To check compatibility with Bluetooth Headsets, review the SOUND menu for the SOUND OUT option. If your model has the LG SOUND SYNC option available, then certain LG Bluetooth Headsets should be compatible. These models are as follows: LG BTS1, LG HBS-700, LG HBS-730 and LG HBS-800. We cannot guarantee the compatibility of any other Bluetooth Headset
The consumer-test mentioned the fact that a Blue Tooth headset was necessary, but not that it should be one of these four from LG.
I first bought another Blue Tooth headset that did not work.
LG gave me by telephone the above advice, so I bought another headset from this LG collection: an LG HBS-800, for the sound sync connection with my LG TV :  55EG9A7V .
My telephone and my Tablet are easily paired and connected, but not My LG TV.  The TV keeps searching and does not recognize my LG HBS-800 telephone. How can this problem be solved?
Loek Drenth
As mentioned in the OP i was having a similar issue with my HBS-730 but it turned out I wasn't doing the steps correctly.
You'll need to put your headset in discovery mode (by pressing the small round button on one of the arms) and then go into your TV wireless sound menu (sorry don't 'have the TV right now in front of me to give you the exact navigation path) and let your TV search for nearby compatible BT devices..
It should hopefully appear in your list...
let me know how it goes.....
Thank you for your reaction.
I did everything exactly like you did, but the LG  HBS-800 in pairing mode was not found.
The TV does not recognize the LG  HBS-800 blue tooth headset and it doesn't show up in the list of available devices.
It is not simple to get these compatible LG headsets, I was happy to find this LG HBS-800, but now I still have this new TV set without a headphone connection. I already bought two blue tooth headsets without success.
Maybe someone has another idea?
I can totally understand the frustration in your case. can you check the following -
1) Are you able to connect your headset to other sources (phone, laptops etc) ?
2) Is your TV in the discovery mode and visible in the list of nearby devices on your phone/laptop ?
Thank you ss332 for your analytical approach! Sorry for the delayed answers,
Answer 1:  Yes, all my Bluetooth headsets, including the LG HBS-800, are easily paired and connected to my Samsung S4 phone and to my Asus Nexus tablet.
Answer 2: My LG TV was in the discovery mode not visible for my phone and tablet. The Samsung TV of my neighbor was visible and also his printer.
This result brings me to the idea that there is probably no Bluetooth signal at all coming from my LG TV!
  I downloaded the LG Wireless Sound Sync manual pages and found:
Manual 1: Check whether LG HBS / LG BTS1 is used in the name of the headphone.
My LG HBS-800 headphone is visible on my Tablet as HBS-800, without the name LG, but I suppose that the filter uses HBS-800.
Manual 2: For some models you need to connect a Bluetooth-dongle to use LG Sound Sync !! ( Accessory of the TV or separately sold.)
Question: I would like to know which Bluetooth specification  or which Bluetooth dongle model  I need ?
I've been able to connect an LG-HBS910 and a Jabra Move without any issues so far. Will try other bluetooth devices.
Edit: I've also been able to pair a Shure BT1. It seems any bluetooth headset/earphones are pairable.
Sent from my LG-H990 using Tapatalk
Thank you for the successful experiences with your smartphones. It might depend on the Web-OsS TV software version on the TVset.
My WebOS TV version is 2.2.0-158 (beehive-biscayne). I cannot choose a headset but only a speaker bar for the Soundsync connection menu on my TV.
A parallel channel with a  separate Bluetooth-USB dongle from LG is not compatible with my TV according to the LG-E service center.
The HBS-800 headset is not Soundsync compatible  according to the same service center for LGE benelux, although in an earllier LG-message it should be compatible.
I still want a Bluetooth-connection from my TV-set to my Headset, but it is not possible yet.
Maybe a software update would be the solution? And it could be the explanation that the problems are solved in newer software.
Thanks Digidog and George,
Loek
Optimus
Expand
I have the same problem t tried 3 bluetooth devices all of which work perfectly with multiple devices (apple) but non will sync with this "smart sync"system.  Frustrating  Latest headphones are Bluetooth version 4.1 with profiles A2DP, AVRCP, HSP and HFP.  any way to connect to this system please?
Expand
Which model of TV do you have Christopher?
Hi there to all.
I am also facing the same problem with my LG TV Model - 42LB6520-TB, WebOS version - 1.4.0-2529 which is the latest. None of the headphones are working with this TV. Is there any other way we can connect wireless headphones with the TV such as using Google Chromecast or Bluetooth transmitter etc...?
Thank you
Posted (edited)
same problems with LG OLED C6V and OLED 65c9mlb
edit: solved. reason was that my BT-Headset was not in pairing-mode (Sony WH-1000xm3). Had to switch on and hold the button for 7seconds)
Edited by DoubleD
solved
    • By informatiko
    • By Pranay Mokida
      All “xboom by will.i.am” Products Feature a More Balanced and Warm xboom Signature Sound
      LG’s New xboom Line Is Empowered by AI Sound, AI Lighting, AI Calibration and RAiDiO.FYI
      SEOUL, Jan. 6, 2025 — LG Electronics (LG) unveiled its new audio product line of Bluetooth speakers and earbuds at CES 2025, created in partnership with multi-platinum musician and tech entrepreneur, will.i.am. This marks the debut of the “xboom by will.i.am” line, following the partnership announcement in early December.
      LG recently appointed will.i.am as the “Experiential Architect” of the LG xboom brand, aiming to establish it as a culture-forward brand that elevates the listening experience to new heights through completely new sound and design values. All “xboom by will.i.am” audio products are professionally tuned by will.i.am, delivering the xboom signature sound – characterized by a more balanced audio profile with warmer tones. The product design is playfully compact and embodies will.i.am’s creative artistry that stems from his life-long experience in pop culture. Leveraging both his extensive experience in understanding what people love and developing technology for creatives, will.i.am fundamentally inspires xboom’s product development, design and brand marketing.
      The “xboom by will.i.am” line boasts a family of smart Bluetooth speakers – the xboom Bounce, Grab and Stage 301 – all fortified with seamless AI capabilities for a next-level listening experience. The xboom speakers conduct AI analysis on the content being played to automatically adjust AI Sound, switching to sound options that accentuate the melody, rhythm, or voice. The AI Lighting feature keeps the speakers’ bar lights pulsing in multicolored sync for added ambiance. AI Calibration allows speakers to instantly recognize their surroundings to fill various indoor or outdoor spaces with ample sound. And for the first time, xboom speakers now feature a dedicated button for users to instantly connect to will.i.am’s RAiDiO.FYI platform to enjoy various infotainment content tailored for each listener by an AI Radio Host.
      Also, users can enjoy their content with amplified sound through the LE Audio Auracast feature that connects multiple xboom units for a seamlessly synchronized audio output. Even without Auracast support on their smartphones, users can enjoy synchronized audio across multiple units with the xboom speaker serving as the master unit. Moreover, users can enjoy the xboom signature sound that is further enhanced by built-in tweeters and full-range units created by Peerless, the Danish premium transducer manufacturer with a legacy of almost 100 years.
      The 2025 audio product line is spearheaded by the xboom Bounce, which combines refined audio quality with stylish aesthetics. It boosts portable sound to a new level with its built-in, up-bouncing passive radiators, dual dome tweeters and track-type woofer. The Bounce is capable of delivering high-frequency stereo with precise highs and an expanded soundstage, surrounding listeners with enhanced clarity and depth. The name “Bounce” comes from its up-bouncing passive radiators that visibly bounce and light up in beat to the music. It incorporates a versatile strap that enables users to hold the speaker securely in one hand, hang it on a hook, or place it on a tabletop. With a water and dust resistance IP67 rating and Military Standard 810G durability, this robust speaker’s built-in battery lasts up to 30 hours.
      The xboom Grab presents an exciting take-anywhere audio experience, pairing powerful sound with a compact, travel-friendly design. Despite its relatively slim size, the Grab manages to pack dual passive radiators positioned on both sides of the speaker for dynamic bass and lively sound. As the name “Grab” suggests, this speaker is perfect to hold in one hand for use on the go. It can be placed in many orientations – standing upright, lying on its side, or securely nestled in the cup holder of a car or camping chair, or even in the water bottle cage of a bicycle. It also comes with versatile straps for securing snugly to the arm or slinging over hooks and handles. With a water and dust resistance IP67 rating and Military Standard 810G durability, the Grab offers up to 20 hours of battery life.
      The xboom Stage 301 is designed for those who love transforming any space into a lively stage – hence the name “Stage.” Optimized for busking, karaoke night, or any sort of indoors or outdoors gathering, the speaker effortlessly fills big spaces with powerful sound. This robust model packs a punch with its 6.5-inch woofer and dual 2.5-inch midrange drivers, providing rich, full-bodied audio. The Stage 301 distinctly features a built-in handle for easy carrying and a clever wedge design that allows flexible positioning for various setups – flat on its base, tilted back, or seated atop a tripod. Highly durable, the xboom Stage 301 has an IPX4 water resistance rating as well as a replaceable battery that lasts up to 11 hours, allowing greater flexibility and uninterrupted listening pleasure.
      The xboom Buds employ lightweight graphene drivers, which are key to delivering pure, well-balanced sound with rich bass. As thin as paper yet strong as steel, graphene improves durability while supporting LG’s Active Noise Canceling technology, providing a more immersive listening experience. Featuring LE Audio Auracast, the Buds enable users to listen to open audio streams in public and permit multiple device connections so that several users can simultaneously enjoy the same audio. Designed for comfort and stability, the ergonomic ear tips adapt to various ear shapes, while the unique ear hook design provides a snug and stable fit on the go. It offers up to 30 hours of listening time with the support of its charging case, as well as IPX4 water resistance that protects against splashing water.
      “Working with renowned tech and lifestyle innovator, LG, opens the door to groundbreaking and dynamic experiences that speak to a broader community of music enthusiasts,” said will.i.am. “By bringing our cutting-edge technology and distinctive creative visions together with LG xboom, we want to foster an iconic culture where people can explore their passion for music with others on a whole new level.”
      “The xboom by will.i.am line marks the beginning of a dynamic, collaborative journey for the xboom brand and will.i.am, and we are more than thrilled to showcase the first fruits of our partnership at this year’s CES,” said Lee Jeong-seok, head of the LG Media Entertainment Solution Company’s audio business division. “Beginning with the new xboom line, we will continuously aim to elevate every aspect of the listening experience.”
      The all-new “xboom by will.i.am” audio products, which will roll out in global markets in 2025, will be on display during CES 2025 from January 7–10 at the LG booth (#15004, Las Vegas Convention Center).
    • By Kane Murphy
      SEOUL, Dec. 10, 2024 — LG Electronics (LG) has announced a partnership with creative artist, multi-platinum musician, and tech entrepreneur, will.i.am, to launch a new line of audio products under the brand “
      link hidden, please login to view.” The partnership aims to transform xboom into a culture-forward brand with an urban aesthetic, providing an all-new audio experience. In this partnership, LG has appointed will.i.am as LG xboom’s “Experiential Architect.” He will play a pivotal role in carving out a new space for xboom in the audio industry. Drawing inspiration from his pop culture and technological know-how, will.i.am will provide strategic counsel for LG xboom’s product development, design and brand marketing. By combining LG’s advanced technologies with will.i.am’s unique insights as a world-renowned music artist and tech entrepreneur, this partnership will infuse LG xboom products with fresh creative aspirations.
      The 2025 line of “xboom by will.i.am” products, including Bluetooth speakers and wireless earbuds will be unveiled at CES 2025. The xboom Buds will be the first product available in the market.
      All “xboom by will.i.am” products bear the mark of will.i.am, who took part in creating LG xboom’s signature sound that boasts a rich bass with a balanced and warm tones. It comes in two distinct modes for listening: one mode provides stimulating sounds that gets you moving with powerful bass while a second mode offers a soothing sound with harmonious tones. The overarching design for LG xboom aims to elevate music enjoyment. Speakers incorporate clever embellishments such as easy-to-hold straps and colorfully interactive lighting that is in sync with the beat of the music being played. Earbuds are designed ergonomically with ear tips and ear hooks for a comfortable fit that also delivers the best sound experience.
      “This launch marks the integration of our wireless earbuds and Bluetooth speakers into one audio brand, LG xboom,” said Lee Jeong-seok, head of LG Media Entertainment Solution Company’s audio business division. “We are thrilled to announce this partnership with will.i.am that will play a critical role in solidifying LG xboom’s new identity.”
      All “xboom by will.i.am” products will be integrated with will.i.am’s RAiDiO.FYI, an AI-powered interactive audio experience, to introduce a new generation of listeners to infotainment. RAiDiO.FYI empowers listeners with unique abilities to immerse, personalize and have a two-way real-time conversation with their favorite topic-based STAiTiONS. This conversational media platform transforms radio as we know it into a new dimension, connecting consumers deeper with the music, talk radio and cultural content they love.
      LG and will.i.am will celebrate this new partnership with product showcases and tech demonstrations at CES 2025 (January 7-10). To know more about “xboom by will.i.am”, please visit .
