Hello
I am working on a Windows Phone Remote control application for the LB670V Webos model.
As i am owning  this television i focused mainly on this television but it should work normally for the 650V and 630 Models too (as i dont expect a difference in the logic..)
As the development is almost completed i am looking for 3 beta testers (one for each models)
If you are already interested and ready to be provide me the required feedback please comment directly on the below post:
I will then provide the required details
Thank you !
Rgds
SylvainN
  • 3 weeks later...
  • 2 months later...
The first update has been released just now.
If not already, it should be already available in the Store in your region, else it should be in the hours.
Some of the new features included:
- a totally new design, making it much easier to use
- new option to keep the screen active (avoid going idle)
If you downloaded the application already you will get notified to update.
Else to download it here is the link :
Note: The application is now named : LG webOS TV Remote
Enjoy!
    • By David Daul
    • By RJ Fischer
    • By wallyricks
    • By u84six
    • By joepineapples90
      So I'm thinking about buying an oled65g46ls, however the included 'magic' remote would be useless to me, due to health issues (tremors).  So my question is, do any other LG remotes work with the G4?.
