Hi, Concerning Smart TV 55ub850V. I like that there are regulary updates of the Firmware/WebOS. I would appreciate if LG would supply a list of major alterations and bugfixes. It is very hard to find out improvements of a new release. I would appreciate such list i.e. in the online manual.  I am sure that with this lack many potential customers do not by this product because there are many wrong/old information on many fora.
    • By SHawk
    • By Sqwazy
    • By majorusa
      - 3.23.24 - Romania- 47LB730v
    • By сергей фролов
