[pivotCE] Guide: Saving Apps From The App Catalog Part 2: HP Takeout
By Peter_T
By Pranay Mokida
By MNHL
By Tobin
Tobin
By Luka Pantsulaia
I bought LG smart tv. for some reason region selected was Africa and could only choose from african countries and had very little available apps in content store. I live in Georgia, so figured that changing region to EU would help so changed it to 3122 and selected service country UK because Georgia was not in the list. after that every app says that it is not available in current country. I have default region code saved so I guess could go back but wondering if any one can help me to get it working in EU. or if anyone have region code in which Georgia is available it will be helpful as well.
