[pivotCE] Accuweather broken and fixed
accuweather-hero
changed their links and discontinued their webOS redirects for the app. The TouchPad app seems largely unaffected but the phones app was rendered broken and bleeding as of a few days ago.
This has been corrected by the community. You can read the start-to-finish on the forums and then from the download thread.
Take that, Accuweather!
Unfortunately, Accuradio is suffering from a similar fate and early reports are to whether it can be patched.
Grab the patch and then thank the devs!
#webosforever
Image:
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
    • By netsplit
    • By Guy Mawson
      I can’t use my remote with the new update. 17. Something I think?
      OK my 55” is a few years old but it was working fine until an automatic update on an unsupported TV! I mean, why update unsupported tv’s with untested software?
      Planned obsolescence - making us upgrade? Well, it’s the last LG telly I will buy for sure
    • By pivotCE
      link hidden, please login to view hold a number of events. This year’s will be of interest to fans of webOS phones, tablets and other computing devices of the past. The festival is held at the and runs over three days from the 12th to 14th of April. The festival includes three elements:
      – some with modifications to function in the modern environment. and . . For readers of this blog, representation of webOS devices will be in two of those areas. Jon W of the is attending over the weekend and will give a 50 minute talk at 900am on Saturday the 13th. The consignment shop will have a small selection of webOS devices for those who are interested.
      So if you are in the area, why not go along?
      If you can’t make it, you can follow along via the and TouchPads are available remotely at
      Discussion is at the . You can read more .
      Picture Credit: .
