Black Tie is a traditional Thai iced tea with a good bit of spice for kick. Today’s Black Tie LuneOS release has the traditional look and feel of webOS with a good dose of modern software technology for a kick!
We try to get the releases out on the first of each month but we had some pretty big hiccups to overcome this time. Sorry for the delay but hey, all good things to those who wait, right? Besides, we
 anyway! Read on for what changed and for the links, of course. :)
Black Tie Changelog
  • Upgraded Yocto to Dizzy release
  • Upgrade to beta release of qt 5.4
  • Upgraded QtWebKit
  • Mobile data connectivity is working again for N4 and TP4G (Ericsson f5521GW and Sierra MC77x0) (no UI implementation yet)
  • System menu is back
  • Various UI and app changes
  • Various fixes for the first use application and Language/Region selection added
  • HP TouchPad 4G supported now
  • PDF App: Using media indexer now
  • Browser: Now saves icons for bookmarks and launcher shortcut
  • Added high resolution graphics for system menu
  • Fixed button width bug in First Use application
WOSQI Update
Jason Robatialle has updated webOS Quick Install to version 4.6.0. The new revision includes support for ADB connections for use with LuneOS. .
Disclaimers, Important Stuff, and Links
All of the same disclaimers from previous  are still true.
Make sure you familiarize yourself with them and then to get started. Tenderloin and Mako remain our focus for now and the emulator works too. Other builds are there but won’t boot.
Installation instructions for and are on the .
We’re hiring more folks and still looking for more .
for testing LuneOS. In short, join the and , please. It only makes LuneOS better. Thanks!
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By TVNerd95
      Bought a new C4 OLED but i get black screens randomly when using internal streaming apps or just going back to the home menu. It seems as if WEBOS is crashing and i can only cut power and reboot when this happens...
      Is it a software or panel issue
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
      Company Announces Integration of Latest Intel Core Ultra Processor in the LG gram
      Lineup at Intel Launch Event, Marking Giant Leap Forward for Personal Computing
      SEOUL, Sep. 4, 2024 — LG Electronics (LG) is excited to announce that its newest LG gram laptop featuring the Intel® Core Ultra processor (Series 2) will be showcased at the Intel Core Ultra Global Launch Event from September 3-8. Renowned for its powerful performance and ultra-lightweight design, the LG gram series now integrates advanced AI capabilities powered by the latest Intel® Core Ultra processor. The LG gram 16 Pro, the first model to feature these new Intel processors, will be unveiled before its release at the end of 2024.
      As the first on-device AI laptop from the LG gram series, it offers up to an impressive 48 neural processing unit (NPU) tera operations per second (TOPS), setting a new standard for AI PCs and providing the exceptional performance required for Copilot experiences.* Powered by the latest Intel® Core Ultra processor, the LG gram 16 Pro is now more efficient thanks to advanced AI functionalities such as productivity assistants, text and image creation and collaboration tools. What’s more, its extended battery life helps users handle tasks without worry.
      The Intel® Core Ultra processor (Series 2) AI processor, which is three times more powerful than its predecessor, enhances a PC’s AI performance dramatically. With up to 48 NPU TOPS and up to 67 GPU TOPS, this next-gen processor offers up to 120 total platform TOPS to unlock new levels of productivity while maximizing user convenience. The new LG gram offers a smoother user experience, since the Intel® Core Ultra processor is optimized for Windows PCs.
      “Together with LG, we are bringing to market the next generation of AI PCs that offer incredible performance, power efficiency and security capabilities for consumers. The LG gram 16 is a great example of an ultra-lightweight AI PC, powered by the all-new Intel® Core Ultra processor, that delivers an outstanding and seamless experience for creators, working professionals and everyday users. We’re thrilled for people to experience the wide-ranging benefits these AI PCs can enable,” said Michelle Johnston Holthaus, Intel executive vice president and general manager, Client Computing Group.
      “Building on LG gram’s renowned ultra-lightweight design and powerful functionality, our newest model integrates Intel’s exceptional AI technology to push the boundaries of on-device AI laptops,” said YS Lee, vice president and head of the IT business unit of LG Business Solutions Company. “The enhanced performance and productivity offered by the latest Intel® Core Ultra processor is poised to enrich the LG gram user experience with AI, ushering in a new era of on-device AI laptops.”
      In line with the company’s AI vision of “Affectionate Intelligence,” an approach that seeks to understand customer needs and deliver differentiated experiences that go beyond traditional AI, LG plans to add more AI processor models to its gram lineup following the introduction of the LG gram 16 Pro with Intel® Core Ultra processors (Series 2).
      * Rolling out gradually in preview within the latest update to Windows 11 in select global markets. Timing of availability varies by device and market. Learn more here: aka.ms/WindowsAIFeatures.
      With the Theme of ‘Experience, Affectionate Intelligence Home,’
      LG’s IFA Exhibit to Highlight Company’s ‘AI Home’ Vision and AI-Powered Appliances
      SEOUL, Aug. 7, 2024 — LG Electronics (LG) is inviting consumers from around the globe to Berlin, Germany, to experience its latest AI appliance innovations at IFA 2024, taking place from September 6-10. Under the theme Experience, Affectionate Intelligence Home, the company will present its comprehensive and inspiring vision for the next chapter of the AI home.
      At LG’s large-scale booth, located in Hall 18 at Messe Berlin, visitors can experience the elevated quality of life made possible by the company’s diverse lineup of AI home solutions. In addition to introducing its newest offerings powered by Affectionate Intelligence, LG will demonstrate its considerable progress in realizing the AI home of the future and reaffirm its strong commitment to leading a new era of AI innovation.
      Those unable to attend IFA in person can still learn all about LG’s AI home appliance showcase through the LG Booth video, which will be available on the LG Global YouTube channel (
      link hidden, please login to view) starting September 6. # # #
