Ah! There’s nothing like the aroma of freshly baked news to draw the readers in!
  • MojoWhatsup
    . It seems that Whatsapp will be implementing . It remains to be seen what impact this will have on the webOS homebrew app.
  • If you are trying to convince yourself that you really need a new TV this month, then you may be able to reduce any buyer’s remorse by checking ‘s , topped by the 55EA9800 from (who also made the runner up).
  • As promised, the latest version of has arrived. Updates for the Preware domain change, Novacom drivers & LuneOS support are all included.
  • In a matching update, , so you should now see the apps added to the webOS Nation app gallery over the last few weeks. Automated updates have just been fixed too.
  • Looking to the future, take a look at this from forum user and app developer, Warlord9159.
  • Finally, don’t panic if you are here looking for the next stable LuneOS build. It has so many major updates that the whole stability thing is taking a little longer.
Don’t forget all the above accept donations (A large & mandatory one in the case of the TV). Even pivotCE could do with the occasional crust.
    • By Charlie F
      Charlie
    • By DeeDeee
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
