[pivotCE] News Crumbs 16 November 2014
So much has been happening lately, it’s hard to tell what’s a crumb, crisis or great news! Here is a selection:
  • 72ka updates his
    . Check the . A Preware feed update is hopefully due soon.
  • In his day job as a colour grader, developer, has won a award for his work on television pilot, ““. . Congratulations David!
  • In other movie news, last week saw the 100th anniversary of the birth of film star . to this site.
  • Another legend! Jason Robitaille, author of Homebrew gateway program, webOS Quick Install, . Jason plans LuneOS support as he awaits delivery of a Nexus 4. Congratulations are also due to Jason for his recent graduation.
  • There are problems with Photos posted to Facebook from the webOS app. The problem seems to be at the Facebook end and there’s no solution yet. .
  • Forum user, Mazzinia has been scouring the corners of the internet for webOS projects. Here’s some interesting and potentially useful stuff: , , , , , .
With this many crumbs, it’s clear that webOS is very far from being .
    • By Charlie F
      Charlie
    • By DeeDeee
    • By pivotCE
      3. Soldering iron and solder
      2. Items 2-4 above
      1.
      2.
      Prepare the Wires
      Final Thoughts
      #webos4ever
    • By pivotCE
      Tools for the Job
      – Needle nose pliers/tweezers
      – Flush cuts
      – Painter’s and kapton tape
      Trim the USB C Board
      Tape the USB C Board
      Where To Get Power and Data
      Put the Pieces Together
      Congrats, You Now Have USB C
      #webOS4ever
