Follow Us On Google +
By Cody LUEN
Hi!
Version: 23.20.36
By 152bobby
I have been trying to get my Google Home and Nest Audio Speakers to turn my LG OLED65C24LA TV on and off. I have linked ThinQ to Google Home but it still wouldn't work. So plan B was to get a Chromecast to do this one simple voice activated request....I have no intentions of using Chromecast for anything else!
So this actually does work, however, when asking it to turn the TV on, it defaults to the home page of Chromecast TV, I want it to just open to my normal TV system, which is Sky Q. Ideally, I would like to disconnect the Chromecast and just get Google Home and ThinQ to do this !!
I have checked every setting and trawled the internet for a solution. I've posted on the AV Forum in the UK and the Google Forum and I'm waiting on a call back from LG Support UK.
I expected this to be a VERY simple task !!
Can anyone help with this ?
By Maor
Hi !
I am going to buy a new LG TV, probably - which comes with WebOS (not android TV). Now, one of the features I really liked with Android TV is the ability to set ambient mode with chosen google photos albums. Is it possible also with WebOS? (without connecting any external streamer, I prefer to use the TV operating system).
Thanks!
Maor
By ForbiddenDOnut
The title more or less says it. I got an LG C3 over the weekend. I have chromecast with google tv for the other TVs in the house so was hoping to stay within that ecosystem. The native apps work well (except that Plex won't play dolby vision), but I've noticed a strange quirk with the chromecast. It plays Dolby Vision just fine and without issues, but standard HDR content gets played in SDR. I've made sure that the "Deep Color" mode is enabled for that HDMI port, but I'm not sure where the trouble is coming form.
Any insights or things to try would be appreciated!
By AVTech
I have been in hi end AV technology for years and I have purchased a ThinQ "smart" TV. After finally finding a way to stop the ridiculous loud static start up now I want to find a way to have the TV start at an installed app (Google TV etc.) instead of the unused antenna or HDMI input. It seem this would be the default if not just an option on a smart TV when actually using installed apps. Have I been missing something or is this some bizarre epic fail?
- 1 answer
- 4,244 views
- 4 replies
- 33,274 views
- 2,650 views
- 6 answers
- 24,129 views
