I bought a 47 inch 650V TV a week ago and I noticed that this SmarTV has a huge potential but still lacks very basic features. So I hope that I don't regret buying this TV if a update don't gives us some really great improvements.
* First of all, WebOS it's slow. It really needs a huge performance improvement. Im not a BETA tester. If the system it's not ready, they should have hold it for a while and hire some inside beta testers.
* Youtube app doesn't play videos in HD. Compared to my AppleTV, the difference it's huge. This is a 1080p SmartTV and there's not a single option on Youtube to play everything in 1080p or at least, 720p.
* Audio Output only gives us a option to select one instead of a multiple sound output. Sometimes I use a Digital Out Surround Systems, and in my old LG TV, I could use the TV Speakers and this digital audio at the same time and only mute the TV. It's the fastest way to use both. In this new smartv, I have go to the audio settings to choose the audio output everytime. For a slow system, it's a really painful solution.
* This TV has Bluetooth built in, and there's not a single option to pair a Keyboard, Mouse or a Audio Device. It's locked to LGs proprietary Bluetooth devices. It's inaceptable since Bluetooth technology is standard and to use a Bluetooth Keyboard/Mouse/A2DP sound I have to get a pack that cames with a USB Bluetooth dongle. So all my BT keyboards and mouses that doesn't have that USB dongle can't be used.
* I own a LG G2 Smartphone and I cannot simple use the LG SmartShare. It's slow and crashes all the time, so sharing my videos and photos to TV it's simple mission impossible. The same goes for Wi-fi Direct. It simply doesn't work. And the same goes for the LG TV Remote App. It's very slow when we try to use the "mouse pointer".
* It's not possible to resize .srt subtitles and tags like <i> and <b> are not recognized by the TV. So not only I can't have Italic and Bold text, but those tags are also added to the subtitles like normal text...
And I notice this with just one week of usage, so obviously there's a lot more things to improve but this features are simple to use on my AppleTV and my LG can't handle them very well. I bought this TV and paid the extra money to get a good SmarTV compared to the 5700 model, with the intention to get rid off the Apple TV... but at this moment I just can't...
  • 3 months later...
Adding more Missing Features after learning more about LG WebOS.
* Favorite button should open the favorite channels in a list and not jumping from channel to channel. It doesn't even make any sense! It kills the "ease to use".
* Favorites should allow us to mix DTV channels, no matter the source (Antenna ; Satellite ... )
* Easy and fast way to change between Antenna and Satellite and even add a "All in One Place" option. Jumping from Antenna to Satellite it's a wast of time and kills the user experience.
* When using a computer mouse, they should add a function for the middle or right button with the same function of the "SMART" (home button) on the remote. That will allow us to use RF Mouses without the need of having the remote for just this simple function.
* Sound Output really needs to allow us chose multiple outputs instead of just one. I would like to use the TV speakers and HomeCinema (Optic) at the same time just like on older LG TVs.
* When searching for Satellites, it would help having a sound with different tones to to match the signal percentage.
* Allow us to DELETE channels. Hide them only makes everything a big mess, specially because when I try to move alot channels at the same time the WEbOS crashes (The low memory problem)
  • 6 months later...
Agreeing - satellite and terrestrial channels should be "mixable".
Favorites button - now I don't understand what it is doing...
Deleting channels should be an option.
And...webos 2.0 is still SLOW on my 50LF652V. I know this might not be the best TV, but it's good enough for me, but the system should not be so slow!
  • 5 months later...
  • 7 months later...
Audio With our older TV's (Aony Samsung) my wife is capable to switch music output to our soundsystem.
We our current LG TV, the LG programmer has decided to default switch of the (digital)  output and have no option to activate to select both output via the TV Speakers (wich you can mute) and the external audio output.
If LG had put a audio exit menu option under the mute button she would be able te handle it on her own but instead he menu is so complex - you have to be a computer specialist - to change the audio settings.
I informed LG that Samsung always has signal on the external audio output, informed that the current audio setup is to complex for a normal housewife who wants to switch the music to the audio device and asked them to make a software change.
Until now no result, may be the wife of the LG programmer can help/explain why a house wife friendly audio switch function should be a prio 1 ...../;-)
Urgent #Request for development to add a house wife friendly switch function from TV to external audio.
For instance put een extra menu under the mute button where you can select the audio output
    • By Serverokon
      I read LG QNED 55QNED80T6A  WebOS  version 24   on LG store can i find the app  MEDIA STATION X ?
      Also  this TV  support  Dual Audio Function allow to pair two Bluetooth devices to one TV on same time to watch movie ?
      Thank you!
      Platform Now Supports 180Hz VRR for Seamless, Smooth Gaming Experience
      SEOUL, Sep. 24, 2024 — LG Electronics (LG) announces that its webOS Hub platform is now available for third-party gaming monitors. This expansion follows the company’s previous rollout of the webOS Hub platform to third-party smart TVs and smart monitors, addressing the increasing trend of gaming monitors and smart monitors being equipped with OTT streaming services.
      The new platform features, customized for gaming monitors, include VRR 180Hz, providing gamers with an optimal environment free from stuttering or tearing. The platform also maximizes user convenience with various connectivity options, including wired and wireless keyboards and mouse, DisplayPort and USB-C type. Additionally, the Game Dashboard and Game Optimizer allow users to easily configure the optimal settings for each game. The Game card app provides easy access to content, including cloud games.
      On top of the new gaming features, the webOS Hub also continues to provide a comprehensive entertainment experience through streaming services and LG Channels. It also offers convenient music listening through the Card App Home Hub & Music and useful features optimized for document handling or video conferencing, accessible via the Home Office card app.
      The latest webOS Hub features are expected to be made available first on Acer’s upcoming Nitro GS272U M QHD 180Hz gaming monitor, with more partners to adopt the platform in the near future. By offering high refresh rates, VRR, diverse connectivity, rich content, easy document handling and a wide range of options, webOS Hub platform provides an exceptional user experience that will help expand platform usage on third-party smart monitors and gaming monitors.
    • By Lleuadwen
      Hi, I hope someone can help. I recently bought this TV but can’t find the Art Gallery app that is supposed to be part of the Home Screen.  I have searched in apps but only third party art gallery style apps show. What am I missing here?
    • By Flavio_S
    • By techguy noob
      My LG TV model number 32LM560BPTC is having an issue where the Sun NXT app is no longer available on the LG Content Store. I was able to watch it before, but starting yesterday, the app disappeared. However, on my other OLED LG TV, the Sun NXT app is still available in the LG Content Store. Is this issue specific to the 32LM560BPTC model TVs?
      Sarath
