Download error
By Marko00
only with cancel button.
How to fix it?
By leader6234
Hey guys !!!
Thanks in advance !!!
By Muser
By glendvd100
Hi there, I have the following tvs:
OLED55C26LD
OLED42C24LA
And I'm trying to change the area code using the service remote, so I can download apps from USA (I'm currently in the UK), such as Max, HULU etc. I'm trying the codes which are bandied around the internet, but the area just stays as EU. I've noticed on youtube videos etc that the older models with the older OS have no issued with this, but mine seems unable to change.
Does anyone know if perhaps the newer models have newer codes? I've used 1793, 1843 and 22287 (as found in this very forum). But nothing happens. Any help from users who may have got this working would be appreciated, thank you.
