Voice Recognition on 42LB6500
By Calvinder
Any suggestions
By SMKoch
I've had an LG OLED65C9PUA for years and have never had this problem until very recently.
Now every time I try to use the voice command to enter a search sequence, the "SPEAK NOW" activates and shuts off within half a second. It doesn't matter how I activate the voice command function or what app I'm using that has the function built in. Such as YouTube or even the Web Browser or whether I activate the voice search with the onscreen microphone icon or the microphone key on the remote. All voice command attempts shut down within half a second. There isn't even time enough for anything said to be recognized or even "not recognized".
Fresh batteries have no effect on the problem. Turning the TV off and back on has no effect on the problem. Removing and replacing the batteries has no effect on the problem. Reregistering the remote to the TV via the extended holding of the GUIDE button has no effect.
How do I restore the voice command function for the remote?
By Packard8
Hi folks, I just bought a new LG from Costco, a 65C3 evo, OLED. The unit's native voice sounds like a chipmunk, very fast and high-pitched (remember Alvin the Chipmunk from the 60s?).
I'm referring to the TV's voice when it responds to commands, like volume changes, etc. I've searched all the "sound" options in Settings and found nothing. All other sounds coming from the TV are normal pitch. I've checked for Firmware updates, and it reports "up to date" Any thoughts?
TIA
By Sherri H
“Voice not recognized” pops up on my screen when I have not, nor ever used the voice recognition. how do I get this to stop?
mottcorrea
Should we always press the Voice Recognition button on the remote control to start using this feature? What about an active listening voice recognition feature? Isn't it possible in 42LB6500 model?
